Best firmware version for LG BH200? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-27-2008, 09:19 PM - Thread Starter
SJI10's Avatar
Just bought one today (february 2008 build).
SJI10 is offline
post #2 of 9 Old 08-27-2008, 09:57 PM
BallsDeepX's Avatar
I personally think the latest is the best. Some think the previous one is better. Guess you will have to try it out for yourself and see.
BallsDeepX is offline
post #3 of 9 Old 08-28-2008, 07:39 AM
pobff's Avatar
Is it true the latest one disabled BD-R and BD-RE read capability?
pobff is offline
post #4 of 9 Old 08-28-2008, 08:06 AM
bradavon's Avatar
Some sadly say it does .
Personally I'd install the latest firmware (June), it is 99% the same as the April firmware though, still it does fix some defects in the April firmware (see the change log).
The January firmware also plays some discs that don't work in the March, April or June firmware.
My advice: Install the June firmware and see how you go.
bradavon is offline
post #5 of 9 Old 09-03-2008, 03:27 AM
foxer37's Avatar
Yes .
foxer37 is offline
post #6 of 9 Old 09-03-2008, 06:29 AM
bradavon's Avatar
Was it ever officially supported?
bradavon is offline
post #7 of 9 Old 09-03-2008, 06:53 AM
billbillw's Avatar
Not according to any of the manuals that I've seen.
If it ain't in HD, it ain't worth watching!
billbillw is offline
post #8 of 9 Old 09-03-2008, 07:07 AM
sivartk's Avatar
If you current firmware is functioning as you need it to why upgrade? I'm at the April version just because I needed to bitstream the HD codecs. Until I see a problem, I'm not upgrading.
At no point in your rambling, incoherent post were you even close to anything that could be considered a rational thought. Everyone in this forum is now dumber for having read it.
My Little Theater
sivartk is offline
post #9 of 9 Old 09-03-2008, 08:13 AM
T2k
T2k's Avatar
Never heard of it.
T2k is offline
Reply Dual Format Players
