What audio setting for the LG BH200? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 09-01-2008, 08:04 PM - Thread Starter
RandallA's Avatar
I bought this player from Best Buy for $339.00 last Sunday and I love it so far. I have a question regarding the Audio setup. My AV receiver is a Sony STR-DG810, it will not decode True-HD but will play back uncompressed PCM audio from Blu-Ray/HD DVD movies as long as the player can decode.
My question is, what setting do I use in the BH200? PCM Multi-Ch or Primary Pass-Thru? I've tried both and they both kind of sound the same to me but I want to make sure I'm using the correct setting.
In the movie Happy Feet when set to PCM Multi-Ch my AV receiver shows "PCM 48" and when set to Primary Pass-Thru it shows "Dolby Digital EX 3/2.1". My HD-A3 player used to display PCM 48 when playing HD DVD movies so I'm a little confused which one to use.
RandallA is offline
post #2 of 11 Old 09-01-2008, 09:25 PM
Megalith's Avatar
Quoted: 20 Post(s)
PCM Multi-CH = Internal decoding.
Megalith is offline
post #3 of 11 Old 09-01-2008, 10:05 PM - Thread Starter
RandallA's Avatar
Thanks. I just finished watching The Bourne Ultimatum (HDDVD) with that setting and the sound was excellent.
RandallA is offline
post #4 of 11 Old 09-01-2008, 10:37 PM
tripleM's Avatar
I have the same setup with the 810.
Not sure what Primary Pass Thru does though since it we are not passing anything HD audio wise.
I think the only reason u would be getting that DDEX status is that the 810 does decode audio below DTHD and that u are receiving 3/2.1 because u have no rear surrounds but do have a subwoofer.
So the 810 just defaults to decoding DDEX since it has no capability to decode DTHD.
Panasonic TC-P60ST60 + Sony STR-DG810 + LG BH200 + JBL L830's x2 + JBL LC1 + JBL Loft40 x 2 + Polk PSW10 + Harmony One
tripleM is offline
post #5 of 11 Old 09-02-2008, 07:55 AM
SKoprowski's Avatar
Quoted: 13 Post(s)
"Pass-thru" will send the bitstream of all codecs to your receiver. "PCM-multi-ch" will decode all the codecs (with the exception of DTS-HD MA) and send it multi-channel pcm over HDMI. You will get TrueHD decoding with this method and the core 1.5mbps DTS from DTS-HD MA. You also have the option to have all codecs re-encoded to 1.5 mbps DTS- which sounds great too. This is useful if you have a receiver that does not do bass management for Multichannel-PCM.
NE Ohio HT Nutt
SKoprowski is offline
post #6 of 11 Old 09-02-2008, 08:40 AM - Thread Starter
RandallA's Avatar
Thanks, great info. I tried the DTS Re-encode option and it didn't sound as good as PCM-Multi ch so I think I'll keep it there for now.
"I think the only reason u would be getting that DDEX status is that the 810 does decode audio below DTHD and that u are receiving 3/2.1 because u have no rear surrounds but do have a subwoofer."
I do have surround speakers and sub. I had it on pass-through so the 810 could only encode DDEX and not TrueHD.
RandallA is offline
post #7 of 11 Old 09-02-2008, 01:03 PM
bradavon's Avatar
That is correct, if your connection type is HDMI.
DTS Re-encode transcodes everything from HD-DVD/BD into 1.5Mbps Lossy DTS. As others have said you want PCM Multi-Channel, that way everything is sent out at the highest bitrate as PCM (except for DTS-HD where you can only get the 1.5Mbps Core).
Primary Pass-thru is for Amps that support TrueHD and DTS-HD, it is also the only way to listen to the Uncompressed DTS-HD HR or MA.
bradavon is offline
post #8 of 11 Old 09-02-2008, 07:28 PM
enormus's Avatar
I know not everyone can afford to upgrade their receiver, but for those who don't have an HDMI receiver capable of decoding TrueHD and DTS-MA via bitstreaming . . . you just don't know what you are missing. True, not every track is done well, but those that are done well are simply astounding.
enormus is offline
post #9 of 11 Old 09-02-2008, 08:15 PM
tripleM's Avatar
I'll take your word for it, but the PCM isn't shabby at all.
tripleM is offline
post #10 of 11 Old 09-02-2008, 08:48 PM
Megalith's Avatar
Quoted: 20 Post(s)
Assuming that the PCM signal is not processed in some way, there is no audible advantage to bitstreaming.
I would imagine that a lot of people who claim that bitstreaming sounds better have PS3s (although that would mean that there are a couple of players out there that do send out a degraded PCM signal, since the PS3 can't bitstream, and it is the one player where the audio sounds significantly worse).
Megalith is offline
post #11 of 11 Old 09-03-2008, 12:34 PM
bradavon's Avatar
Much better than the audio down sampled to 1.5Mbps DTS?
My plan was always to upgrade my Amp, hence why I waited until a Combo Player came that could do the HD Audio business but right now I really cannot afford one. I need a Full HD TV more too. I also currently live in a smallish flat and cannot play movies at the volume I really like due to my neighbours, that only hinders being able to tell the difference.
bradavon is offline
Reply Dual Format Players
