Audio decoding question for bh200 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-24-2008, 09:54 PM - Thread Starter
bimmerfreak0's Avatar
Quoted: 14 Post(s)
so does the bh200 fully decode dd plus, truhd, dtshd AND dtsma internally??? I'm confused and need a straight answer ( assuming the software is up to date). I have an hdmi 1.1 reciever so I need it all decided internally and I don't really care if it bitstreams. Can someone tell me?
Ryan
bimmerfreak0 is offline
post #2 of 4 Old 09-24-2008, 11:49 PM
oilblue's Avatar
For an HDMI connection, the BH200:
- "Fully" decodes: DD+ and TrueHD
- Decodes the "core" of DTS-HD (HR and MA).
- Bitstreams all of the above (though that's not relevant for you).
Hope that helps.
oilblue is offline
post #3 of 4 Old 09-27-2008, 04:24 AM - Thread Starter
Quoted: 14 Post(s)
will it ever decode, i thought it was harder for it to bitstream than decode???
post #4 of 4 Old 09-27-2008, 12:09 PM
oilblue's Avatar
Other way around actually. Bitstreaming involves taking the audio track off the disc and streaming it out, bit for bit (processing the stream is left for whatever is connected by HDMI). Consequently, bitstreaming takes less "work" than decoding.
Only LG knows if they'll ever decode DTS-HD. Obviously it would be a welcome addition, but I wouldn't count on it. BTW, decoding DTS-HD is a more intensive process than decoding Dolby TrueHD (as has been discussed in other threads).
oilblue is offline
Reply Dual Format Players
