BH200 Help!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-12-2008, 01:56 AM - Thread Starter
adamcyc's Avatar
I bought the player and play the bul-ray and HD DVD is normal, buy oneday, when i play my HD Disc, loading the screen before HDlogo in top left, just hold and on other response. before that , i try my all HD DVD have that situation but play bul-ray, audio CD and DVD movie is ok.
My firmware is 0702.
Please help
adamcyc is offline
post #2 of 3 Old 10-12-2008, 04:06 AM
bradavon's Avatar
Have you tried upgrading the firmware?
0702 is the driver not firmware. What firmware do you have? I'd be surprised if it's firmware related though. It sounds broken.
bradavon is offline
post #3 of 3 Old 10-13-2008, 01:21 AM - Thread Starter
adamcyc's Avatar
My firmware is june, but i find a new problem is I can not upgrade or downgrad filmware of the player, I try to USB, CD or DVD-R same to hold the screen of the upgradeing when display installation of the panel.
adamcyc is offline
Reply Dual Format Players
