Samsung BD-UP5000 Firmware 1.4 Released Report BUGS\FIXES - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 395 Old 11-15-2008, 12:18 AM
shawnmos's Avatar
I doubt they'll ever fix it. I'm probably just going to ebay the disc. I think the Blu-ray version works.
shawnmos is offline
post #92 of 395 Old 11-15-2008, 12:32 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Yea, I've been waiting for a good deal on the disc...have not seen one but will certainly be picking up the BD over the HD (unless I can find it for dirt cheap, say $5 or under ).
vinnie97 is offline
post #93 of 395 Old 11-15-2008, 03:09 AM
AdamWL's Avatar
Holy crap! I just got it to work again. I wouldn't give up on this b*tch. After at least 25 power cycles, changing every conceivable setting (even unplugging the Ethernet cable thinking it was some network content freeze), nothing worked. I then pulled out the NIN HD DVD and put in another HD DVD (Chronicles of Riddick) and it did the exact same thing!! Froze when reaching the menu. After my heart skipped a beat, I power cycled the player and when it came up again, it properly loaded the Riddick HD DVD. I then ejected the Riddick disk and put in the NIN disk and it fully loaded!!
I'm watching it right now! It brought up NIN with three menu choices to the right "North American Winter Tour 2006", "Additional Content" and "Setup". After selecting Dolby True HD I selected the feature. It then brought up a "Play All" as well as all the individual song names for selection. It works like a charm!
I'm set up as 1080P, 24fps, in bitstream (audiophile) mode. So, is the trick to first load a known working HD DVD waiting for the menu to load, ejecting it and then immediately inserting the NIN disk?!?
AdamWL is offline
post #94 of 395 Old 11-15-2008, 04:12 AM
AdamWL's Avatar
Originally Posted by AdamWL View Post
NIN. So, is the trick to first load a known working HD DVD waiting for the menu to load, ejecting it and then immediately inserting the NIN disk?!?
So that's it. I was able to duplicate the success in getting it to play. First load another HD DVD to the menu, eject it and then put in the NIN disk. It should load up and perfectly!
(If you access the title menu while the feature is playing... you can only exit the menu by selecting "Main Menu". If you select anything else the player will continue playing without responding to the remote.)
AdamWL is offline
post #95 of 395 Old 11-15-2008, 06:50 AM
tbase1's Avatar
Quoted: 43 Post(s)
Liked: 66
Holy crap...if i have to do this when i want to play a hd-dvd i'm keeping my two player setup and send my up5000 back to the company i bought it from within a week.
tony4k
tbase1 is offline
post #96 of 395 Old 11-15-2008, 07:13 AM
AdamWL's Avatar
Well luckily, the NIN HD DVD is the only title I know of that has this type of quirkiness. Most titles do play just fine, but there are a handful out there that do have some issues. It's still a fairly nice hybrid player and there are only "two-of-a-kind" out there...
AdamWL is offline
post #97 of 395 Old 11-15-2008, 11:46 AM
shawnmos's Avatar
That is the only HD DVD I've ever had any problems with. Not worth getting rid of the player for one title.
shawnmos is offline
post #98 of 395 Old 11-15-2008, 12:04 PM
shawnmos's Avatar
Ok, I got the NIN HD DVD to work with your work around. And yeah, if you use the pop-up menu the player stops responding to commands.
BTW, is the TrueHD track stereo? I can only get 5.1 with DD.
shawnmos is offline
post #99 of 395 Old 11-20-2008, 04:50 AM
Jascias's Avatar
Ok, I have used image burn for all my firmware burns, an I have used it for firmware 1.4. Goes on my player fine, but here is the catch. Can no longer play Blu-rays??. It will still play SD and HD DVDs but will just spit out any blu-ray. Downgraded the player back to 1.3 and plays blu-rays fine. Any ideas??
Jascias is offline
post #100 of 395 Old 11-20-2008, 05:13 AM - Thread Starter
SpenceJT's Avatar
Quoted: 25 Post(s)
Liked: 27
Try resetting to defaults and flashing again?
SpenceJT
"Someone ever tries to kill you, you try to kill 'em right back!"
- Malcolm Reynolds, Capt. "Serenity" -
SpenceJT is offline
post #101 of 395 Old 11-20-2008, 06:55 AM
Jascias's Avatar
Yup, did that but still the same. I'm at a loss, makes no sense.
Jascias is offline
post #102 of 395 Old 11-20-2008, 09:09 AM
aschnare's Avatar
Another title with a similar problem is the French import of Brotherhood of the Wolf HD DVD. Again it's just the menu, because the movie plays fine.
aschnare is offline
post #103 of 395 Old 11-20-2008, 05:51 PM
tbase1's Avatar
Quoted: 43 Post(s)
Liked: 66
If there a list of movie that this player can not play? I just got my player today and I'm watching jumper right and all is well so far. How can I tell which firmware number I'm running?
tony4k
tbase1 is offline
post #104 of 395 Old 11-20-2008, 10:44 PM
vampira22's Avatar
hi Foxbat,
I thought firmware 1.4 is the current version....?!?! Right after I bought the 5k from CC, I hooked up the ethernet and downloaded ASAP version 1.4. Does this version now support now DTS MA 7.1? How do I confirm this or see this on the player's menu/screen or, one just assumes it's outputting 7.1 discrete channels of audio..... As far as I know, there isn not a test disc out there that does DTS MA HD 7.1 yet.... My old receiver is able to do a Test tone and all 7.1 discrete channels are up and running fine....but unfortunetley, test tones come from the receiver and has nothing to do with the BD player....
Hey guys, besides Pan's Labyrinth's...there are other BD movies out there with DTS MA HD 7.1 audio tracks for u to enjooy such as the SAW movies, the new Rambo Movie (amazing sound and gritty action!) and the just released Hell Boy 2 (The Golden Army).....enjoy!!!!
PS3 also has a dragon game called LAIR with the only known 7.1 discrete audio track.
vampira22 is offline
post #105 of 395 Old 11-21-2008, 01:27 AM
Ph8te's Avatar
Quoted: 4545 Post(s)
Liked: 3978
HTe thread titled "Problem Discs" would probably be a good start ...
http://www.avsforum.com/avs-vb/showthread.php?t=1007434
1st page there is a link maintained by vinnie.
Ph8te is offline
post #106 of 395 Old 11-21-2008, 01:31 AM
Ph8te's Avatar
Liked: 3978
Originally Posted by vampira22 View Post
hi Foxbat,
1.4 IS the latest firmware and there have been no updates as far as audio capabilities go since 1.3. If you take a look at the 1.3 thread youll see the audio decoding available.
Ph8te is offline
post #107 of 395 Old 11-21-2008, 04:51 AM
tbase1's Avatar
Quoted: 43 Post(s)
Liked: 66
I can't play any hd-dvds ( erroe message) ,but blu-ray works great with 1.4 firmware. What can I do besides calling samsung or sending this unit back to the company that sold it to me?
tony4k
tbase1 is offline
post #108 of 395 Old 11-21-2008, 05:26 AM - Thread Starter
SpenceJT's Avatar
Quoted: 25 Post(s)
Liked: 27
Any titles in particular? I have twenty or so titles, and while I haven't gone through each and every one of them after updating to 1.4. I had recently been viewing the HD DVD version of Charlie & the Chocolate Factory (at the request of my daughter). The title played just fine, however I was unable to set it to repeat a chapter (my daughter loves the "Chewing Chewing" song after Violet B turns into a giant blueberry). I have yet to see if the repeat chapter works on any other HD DVD, or SD or Blu-ray for that matter.
Spence
SpenceJT
SpenceJT is offline
post #109 of 395 Old 11-21-2008, 10:21 AM
tbase1's Avatar
Quoted: 43 Post(s)
Liked: 66
Does anyone know how to fix a error code 0x000000ff (can't read HD-DVD's) or should I just paythe $85.60 for labor to samsung to repair the unit?
tony4k
tbase1 is offline
post #110 of 395 Old 11-21-2008, 11:57 AM
shawnmos's Avatar
Sorry, but your drive is bad. It will have to be replaced.
shawnmos is offline
post #111 of 395 Old 11-21-2008, 02:10 PM
tbase1's Avatar
Quoted: 43 Post(s)
Liked: 66
oh well...back to the store it goes.
tony4k
tbase1 is offline
post #112 of 395 Old 11-21-2008, 06:24 PM
Zlat's Avatar
They should have at least have included the update for the bonus view popup since it one of the things that people wanted to have the most.
Zlat is offline
post #113 of 395 Old 11-21-2008, 06:36 PM
Steckz18's Avatar
I talked to a representative earlier this week and he said an update for the bonus view as well as a few other things should be coming within the next couple of weeks.
Steckz18 is offline
post #114 of 395 Old 11-21-2008, 06:39 PM
Ph8te's Avatar
Liked: 3978
?? Not sure what you mean here as the player works with 1.1 material......THe only caveat is that you will always see the Bonus View icon, unless you turn off screen messages. Remember Samsung thought this was a feature before, it is up to the consumer to educate them otherwise....
Ph8te is offline
post #115 of 395 Old 11-21-2008, 06:41 PM
Smarty-pants's Avatar
Quoted: 747 Post(s)
Liked: 623
...it is up to the consumer to educate them...
That right there says it all. ...and then there's the falling on deaf ears part.
Smarty-pants is offline
post #116 of 395 Old 11-21-2008, 06:44 PM
Ph8te's Avatar
Liked: 3978
Well if "enough" people speak up on an issue it will be fixed (we have seen evidence of that). Its a matter of getting enough voices to be heard.
Ph8te is offline
post #117 of 395 Old 11-21-2008, 08:12 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 399
You can add all BD-P1500, BD-P2500 and BD-P2550 users to those who dislike Sammy's handling of Bonus View Icon issue. We are not alone and falling to deaf ear is probably the only explaination.
Foxbat121 is offline
post #118 of 395 Old 11-22-2008, 12:16 PM
jylavmtlcda's Avatar
Hi. When I loaded the disc, I went and checked something on my PC, came back and there was a screen I haven't seen before ever, it was kind of the fbi warning you see always except it was written: it may not be possible to play this disc unless you update your firmware, etc... it looked like a copy of the little notice we get in each BD's. At bottom there was a 'continue', I hit enter then I end up on the movie menu page, but no menu on left and only 'Die another day' on upper right. Had to power off then power on and all was okay afterwards. Furthermore, around the 1h30m mark, the screen turned all snow (same as when you load a standard DVD). Had again to power off then on and go back to that exact spot and it played perfect until the end. Tried a few of the special features, no problem at all. This is with fw 1.4. Ah I also had a few hiccups on the audio, nothing major though. With 1.4, I watched this one and 'For yr eyes only' also. This last one played flawlessly. Ah to finish, I watched 1st part of 'Band of brothers' BD right before loading 'Die another day'.
Jean-Yves--HD DVD's: 17--BD's: 111--65vt25--bd-up5000--ps3
jylavmtlcda is offline
post #119 of 395 Old 11-22-2008, 02:34 PM
Zlat's Avatar
I sure hope they fix it since i was planning on buying either a 1500 or a 2500 and im seriously thinking of buying the LG instead if this is not fixed.
Zlat is offline
post #120 of 395 Old 11-22-2008, 03:34 PM
shawnmos's Avatar
All you have to do is turn off on screen messages. It's not a big deal.
shawnmos is offline
Reply Dual Format Players
