Damn bluray burners - AVS Forum | Home Theater Discussions And Reviews
Old 07-06-2010, 07:33 AM - Thread Starter
Rayza1's Avatar
I have a gbw-h10n blu ray drive. My op Vista.
I have had the unit for awhile now and it works fine as a player of all things dvd and Bluray..and burns dvd ok...but cannot burn a bluray using multiple softwares and medias including the disc supplied with the unit.
I built a home theater system hoping to utilise a good cpu etc etc.to do some heavy HD movie editing and burning. Waiting to buy a decent HD cam I have used the drive without a problem ..until now.
I have used Nero...write errors...Pinnacle.sees the disc but won't burn .
PMB that came with my Sony cam cannot detect a burner.
As I said the unit burns DVDs through Pinnacle (not PMB)and the rest but when it comes to Blu ray media it fails.
I tried some cmcmags.cn2 rewrites...no go.
I upgraded the firmware to glo6.
Has anyone else had this problem?
I'm just about ready to give up.
Rayza1 is offline
Old 07-06-2010, 04:15 PM
Quoted: 21 Post(s)
Un-install that junk software, and use ImgBurn.
It will either burn perfectly, or give you a log file with clues as to why not.
Laserfan is offline
Old 07-06-2010, 09:58 PM - Thread Starter
Rayza1's Avatar
Ok tried Image burn...it wrote an image to the disc supplied with burner (verbatum)(waste of disc ..cannot see what I wrote on it..should have burnt a fiule..my mistake.)....will not work on rewritables ? I tried Ritek and cmcmag.
says cannot read media?
I have ordered a couple of verbatim bd-re 's , maybe this will work.
PS getting hard to find Bluray media...places like Kmart, JB Hifi don't stock it anymore.
The main thing I need to know is , does anyone else have the same burner as me and are they having the same problems .
Rayza1 is offline
Old 07-08-2010, 06:04 PM - Thread Starter
Rayza1's Avatar
Have fixed the problem. it seems the burner only wants to look at Verbatim Blu ray media....
Rayza1 is offline
Old 07-27-2010, 08:04 PM
jvcarter6's Avatar
jvcarter6 is offline
