Reliable player? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-07-2010, 08:01 AM - Thread Starter
potdot's Avatar
Can anyone please recommend a good quality and reliable dual format player? I have tried one, but it played neither back to satisfactory quality. It seems silly to have two competing formats, I guess one will win out in the end, as VHS did?
potdot is offline
post #2 of 3 Old 08-07-2010, 10:28 AM
Gixxxerman001's Avatar
Well, assuming you're serious (the format war was decided more than 2yrs ago) the best 2 (and only 2) fully spec'd multi-format players are the Samsung's BD-UP5000 and LG's BH 200.
I have the LG BH 200 and have nothing but praise for it, I know owners of the Samsung feel similarly.
Either one will probably suit you, your problem is more likely to be finding a really nice one at a suitable price.
Gixxxerman001 is offline
post #3 of 3 Old 08-12-2010, 12:01 PM
Actionable Mango's Avatar
Quoted: 24 Post(s)
Liked: 30
I'm curious what you tried that didn't play back with satisfactory quality?
If you want a combo player, the two mentioned above are definitely the only choices. However, many will say you are better off with separate BD and HD units.
Actionable Mango is offline
Reply Dual Format Players
