HD DVD vs BlueRay - AVS Forum | Home Theater Discussions And Reviews
Old 08-25-2010, 01:26 PM - Thread Starter
BW4me's Avatar
Don't know if this is the right place for my questions, but this is it:
What's the difference between HD DVD & BD?
Does HD DVD look better on BD player than standard player or HD DVD player?
Will HD DVD look better on Intergra 5.5 standard player than a SD DVD?
Steve
BW4me is offline
Old 08-25-2010, 05:13 PM
Actionable Mango's Avatar
Quoted: 24 Post(s)
Liked: 30
The most important difference is that HD-DVD is a dead format and BD is still supported. There are many other technical differences, but they really don't matter any more.
HD-DVDs are incompatible with BD players and DVD players. You can only play HD-DVDs on hardware designed specifically to work with HD-DVDs.
Yes, HD-DVDs will look better than SD-DVDs played through your Integra receiver. You will need an HD-DVD player.
My recommendation is that if you aren't already invested in HD-DVD, just get a BD player instead.
Actionable Mango is offline
Old 08-25-2010, 07:06 PM - Thread Starter
BW4me's Avatar
BW4me is offline
