BH200 Wireless Ethernet Bridge? - AVS Forum | Home Theater Discussions And Reviews
Old 10-08-2010, 10:43 PM - Thread Starter
jiggawhat's Avatar
Has anyone got one to work with this player?
If you have, do you mind letting me know what you might have done to set it up?
jiggawhat is offline
Old 10-10-2010, 02:19 PM
kevntrace's Avatar
I used to have a wireless bridge a few years ago when I was using a media player set top box to stream content from my PC. It really wasn't very reliable for me - I often got lost signals, and everytime the microwave was used that also disrupted the signal.
I have since moved on to powerline ethernet to provide internet access to the a/v area in our main room. I use that to provide an internet connection to the LG BH200, and it works a treat. The BD-Live stuff works very well this way.
The powerline unit I am using is a Netgear XAVB101. They probably have newer models available now. One tip - make sure you do not plug the units into a powerstrip or surge protector.
kevntrace is offline
