Best player for blu-ray, mkv, avi? - AVS Forum | Home Theater Discussions And Reviews
Old 11-05-2010, 05:24 PM - Thread Starter
flyboy320's Avatar
I haven't bought a player yet, although the TV I might buy is throwing in a Samsung BD-C6900 for free. So my dilemma is should I stick with the BDC6900, or perhaps get something else? What I want to do is play avi and mkv files, as well as blu-ray disks. It would even be a bonus if it could do this wireless off my home network.
I know the BDC6900 can do most of this, but a quick look in the thread on this player, some people are reporting problems playing some mkv files (via usb or streaming). Some also reporting audio sync problems, although that may be a mkv/avi file problem, I don't know.
I will also at some point be getting a gaming box, no idea which one, PS3, XBOX, Wii. Would any of these do what I want?
flyboy320 is offline
Old 11-05-2010, 06:11 PM
shinksma's Avatar
Location: Wandering the intertubes, on the way to damnation
Quoted: 80 Post(s)
Liked: 54
This forum is for players that play both HD DVD (may it Rest In Peace) and BD. Not regular BD players (that also play DVD).
I suggest you browse the BD player forum, specifically this thread:
http://www.avsforum.com/avs-vb/showthread.php?t=959985
Do not just open a new thread like you did here - it will get locked or merged into the above thread immediately.
Just out of interest, since it happens more than a non-zero number of times: what made you think this was the right forum to start a new thread and post that question? Not being mean or a jerk: it just seems weird to me that a forum right "next door" labeled "Blu-ray Players" would not be the one selected to browse/post. Perhaps there is a key word the Mods need to use to re-label this forum.
shinksma
My opinions are my own, and do not necessarily reflect those of my captors.
shinksma is offline
Old 11-05-2010, 06:21 PM - Thread Starter
flyboy320's Avatar
Thanks for the guidance shinksma. Thought I had clicked on the Blu-ray players forum, but obviously not ...
Oh, and thanks for the link....
Old 11-17-2010, 02:44 PM
champer's Avatar
shinksma
someones trying to get the mod tag i see
SONY 32XBR6
SAMSUNG 46C6500
BD 40
HD DVD 28
champer is offline
