LG BH200 PAL Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-10-2011, 09:35 AM - Thread Starter
zombi3's Avatar
I had a question regarding PAL playback on the BH200. Sorry if this has been addressed already, but I haven't been able to find a definitive answer.
Anyway, I've read that the BH200 outputs PAL/50hz content at 60hz and that the player allows NTSC-only TV sets to display PAL properly at 60hz. So my question is does the fourth field in the EEPROM setting have to be set at 00, or 80, in order to play SD PAL DVD content on a non-50hz capable TV?
Thanks in advance...
Go ahead, take a Chill Pill.
zombi3 is offline
post #2 of 3 Old 02-11-2011, 12:21 AM
champer's Avatar
Originally Posted by zombi3 View Post
i had a question regarding pal playback on the bh200. Sorry if this has been addressed already, but i haven't been able to find a definitive answer.
Anyway, i've read that the bh200 outputs pal/50hz content at 60hz and that the player allows ntsc-only tv sets to display pal properly at 60hz. So my question is does the fourth field in the eeprom setting have to be set at 00, or 80, in order to play sd pal dvd content on a non-50hz capable tv?
80
SONY 32XBR6
SAMSUNG 46C6500
BD 40
HD DVD 28
champer is offline
post #3 of 3 Old 02-11-2011, 10:39 AM - Thread Starter
zombi3's Avatar
Thanks. I was thrown off by this from the FAQ thread:
If your TV doesn't support PAL, use these alternate codes (if you're unsure, use these codes!): Region A - 00, Region B - 20, Region C - 26
zombi3 is offline
Reply Dual Format Players
