Blu Ray and HD-DVD Playback Software - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-24-2011, 11:17 PM - Thread Starter
silentwind96's Avatar
I have a dual format drive for my pc which is running Windows 7. Can anyone confirm if the latest iteration of TMT supports both HDDVD and Bluray? If not, can someone please steer me to something that can? I was one of the five people who actually owned the xbox 360 hddvd add-on and have quite a few movies i dont want to re-purchase.
silentwind96 is offline
post #2 of 3 Old 04-25-2011, 08:47 AM
Gixxxerman001's Avatar
I might be behind the times but Arcsoft's TMT 3 Ultimate does playback HD DVD & Blu-ray.
PowerDVD 7.3 was the last of theirs to play HD DVD back without and messing around but PowerDVD 8 can be made to.
I use PowerDVD 8 myself without any triuble.
See here - http://www.digital-digest.com/articl...DVD_page1.html
Gixxxerman001 is offline
post #3 of 3 Old 04-28-2011, 02:27 PM
Actionable Mango's Avatar
Quoted: 98 Post(s)
Liked: 86
Yes TMT Platinum does work for both formats. I use it on Win7 with an LG combo drive.
On HD-DVD in TMT there is no bitstreaming support for one of the advanced audio codecs, either TrueHD or DTS-HD/MA. I cannot remember which one works and which does not.
If you really want to ensure it works with your setup, just download the software and try it. There is a free trial period.
Actionable Mango is offline
Reply Dual Format Players
