*** The LG BH100 HD Super Multi Blue Player *** official owner's thread - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #1261 of 1394 Old 05-15-2009, 10:47 AM
mercurythewhite's Avatar
Hey guys,
I got my bh100 to play region 2 pal discs but the image is stuttering...
is there any setting I can use to have it play back correctly?
It is outputing at 1080i...anything I can do?
Thanks!!
mercurythewhite is offline
post #1262 of 1394 Old 05-18-2009, 04:01 AM
robert007's Avatar
Originally Posted by mercurythewhite View Post
Hey guys,
Thanks!!
Yes, you can use julios hack to enable the multiregion option for DVDs. You can find more information about it earlier in this thread. As to BDs playback, there is a setting from meli15 (previous page) which enablebles either multiregion or easy switching. have fun
robert007 is offline
post #1263 of 1394 Old 05-19-2009, 01:42 PM
robert007's Avatar
check out this thread: http://www.engadget.com/2008/06/26/f...ers-available/
it starts with Lopez' post... have fun
post #1264 of 1394 Old 05-27-2009, 12:01 PM
So, basically if my HDTV doesn't support 50hz just 60hz and 24, I will not be able to play pal dvd's or blu-rays encoded at 1080i@50hz correctly? The bh100 cannot convert 50hz to 60hz? The same scenario occurred with the region b blu-ray of the three burials of Melquiades Estrada--the player reads the disc fine but the output stutters because of the 1080i@50hz output...help....
post #1265 of 1394 Old 05-27-2009, 10:29 PM
meli15's Avatar
Hi,what tv set are you using......It may not be the set........Have you set your player to my specs from previous page....Mel
meli15 is offline
post #1266 of 1394 Old 05-29-2009, 06:56 PM
Hi...first thanks for responding Meli...I have a Samsung 37" LnA550; I tried your settings from the previous page with the 4 byte set to 90; basically my set shows No Signal, though the disc is being played. I have not done the Julios Hack because I do not have a DVD burner. So, maybe this is the problem then? The same thing happens with my reg. 2 pal dvd's...disc plays but image stutters. I have the output set normally on 1080@24 but then of course the player downscales to 1080i...
post #1267 of 1394 Old 05-29-2009, 07:18 PM
Actually Meli, trying the 4th byte at 90 just gives me region A and region 1---trying my region b locked blu-ray gives me the "wrong region" screen...
post #1268 of 1394 Old 05-30-2009, 12:01 AM
meli15's Avatar
Hi, Did you also change the first two bytes...It's very important,mine was stuttering too.Until I Changed the first two bytes........Try it let me know..After you should be able to play regionfree Pal.......and bluray region B.........Mel
meli15 is offline
post #1269 of 1394 Old 06-03-2009, 08:31 AM
Yes, I changed the first 2 as well. Maybe it has to do with dvd hack?
post #1270 of 1394 Old 06-03-2009, 04:28 PM
shingdaz's Avatar
You have to chnage the first 2 bites as well? I did not think they where applicable. Only the 4th bite.
shingdaz is offline
post #1271 of 1394 Old 06-03-2009, 09:21 PM
meli15's Avatar
Hi,for some reason leaving the first 2 bytes (US specs) with the 4th byte at 90, Pal dvd playback was choppy.Changing the first 2 Bytes(I believe UK specs)Pal and Ntsc playback,played with no problem.Also for some reason I could also play Rce disk with no problem.And bluray region A and B.......Shingdaz is your unit from the US?
Mel
meli15 is offline
post #1272 of 1394 Old 06-03-2009, 09:25 PM
meli15's Avatar
That is a most for regionfree.
Mel
meli15 is offline
post #1273 of 1394 Old 06-04-2009, 03:41 PM
shingdaz's Avatar
Mel
Yes it is U.S. model.
Ok, so change the first 2 bytes to UK model specs (which should be noted on this thread)...and then 4th bite to 90?
I thought the 4th bite was changed to 02? To make it region free Bluray and DVD for North American players etc.
shingdaz is offline
post #1274 of 1394 Old 06-04-2009, 06:30 PM
meli15's Avatar
Hi, I tried 02 but Pal playback was choppy and also some Fox disc would not play.Try these settings and let me know what you think.Also the dvd hack is needed for regionfree Dvd.
44 45 00 90 00 05 00 40
Mel
meli15 is offline
post #1275 of 1394 Old 06-19-2009, 06:17 AM
Peopleselbowpad's Avatar
Hi Folks,
Watching an BH100 on Fleabay at the minute but before I bite the bullet can someone please confirm if it will play AVCHD? Lots of info but lots of contradictions.
Peopleselbowpad is offline
post #1276 of 1394 Old 06-19-2009, 06:54 AM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
Samsungmaster, when is the new firmware update to fix the X-files movies going to come, its been a few months now since LG confirmed it wont play.
Athanasios
nashou66 is offline
post #1277 of 1394 Old 06-19-2009, 07:37 AM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
Originally Posted by Peopleselbowpad View Post
Hi Folks,
I dont think it does.
nashou66 is offline
post #1278 of 1394 Old 06-19-2009, 09:30 AM
shawnmos's Avatar
How do I get this player to output 5.1 PCM to my new Denon 3808Ci over HDMI? I can only get 2.0. I know this player can't bitstream, but I was under the impression that it could output 5.1 PCM.
shawnmos is offline
post #1279 of 1394 Old 06-19-2009, 12:38 PM
larrimore's Avatar
Quoted: 94 Post(s)
Liked: 41
It can- from the Home screen, choose settings then audio. Make sure HDMI audio is set to 5.1 PCM
Living the HT Dream in 4D.
3D DLP Cinema 110"@9ft w/5.4.2 Atmos Sound and 6 Aura Bass Shakers
larrimore is offline
post #1280 of 1394 Old 06-19-2009, 03:14 PM
shawnmos's Avatar
I don't have an HDMI option, just SPDIF. When I set that to PCM all I get is 2.0 out of the HDMI. When I set it to Bitstream I just get Dolby Digital.
shawnmos is offline
post #1281 of 1394 Old 06-20-2009, 01:19 PM
meli15's Avatar
Hi Folks,
Sad to say No.......no avchd and no B-re or B-r....sorry, am in the same boat
meli15 is offline
post #1282 of 1394 Old 06-21-2009, 04:38 AM
Thanks, do any of the combo players pay AVCHD?
I think I know the answer.
Cheers
post #1283 of 1394 Old 06-27-2009, 06:11 PM
meli15's Avatar
Cheers
I've got the Bh200 to play Avchd and B-re with the April firmware.But instead of the 4th bite at 80 I set mine to 90,same as the Bh100.With the setting at 80.Avchd and B-re would not play.Strange,any ideas anyone as to why this is happening.
meli15 is offline
post #1284 of 1394 Old 06-28-2009, 08:13 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
What hapens if you change the forth byte to 90 with the current firmware ? will it play AVCHD also?
Athanasios
nashou66 is offline
post #1285 of 1394 Old 06-29-2009, 05:06 PM
meli15's Avatar
Athanasios
What firmware do you have....Change the fourth byte to 90 and let me know.........with the april and the 90 setting it plays avchd and b-r and b-re.
meli15 is offline
post #1286 of 1394 Old 07-08-2009, 04:15 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
When is the X-files fix coming Samsungmaster?
Athanasios
nashou66 is offline
post #1287 of 1394 Old 07-09-2009, 03:33 PM
annaepi's Avatar
Athanasios
Indeed, for several months and I expect to see x files. Blessed when it comes out this firmware?
annaepi is offline
post #1288 of 1394 Old 07-10-2009, 05:48 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
Samsungmaster sent me a PM saying he will look into what is taking so long for ti to be released.
Athanasios
nashou66 is offline
post #1289 of 1394 Old 07-11-2009, 07:17 AM
annaepi's Avatar
And since January that I bought x files I want to believe, and expect the new firmware to view. Then there are high hopes that soon leaves the firmware, which solves the titles dela fox?
annaepi is offline
post #1290 of 1394 Old 07-11-2009, 10:32 AM
jhazeldene's Avatar
UK enthusiasts may be keen to know that a UK seller has 3 'refurbished'
BH100s up on Ebay at the moment; item # is 330336639290. I have no affiliation with the seller
John
jhazeldene is offline
Reply Dual Format Players
