*** The LG BH100 HD Super Multi Blue Player *** official owner's thread - Page 47 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #1381 of 1394 Old 06-07-2010, 01:59 PM
as1serge's Avatar
Does new firmware support BD-R BD-RE disks? Any ideas?
as1serge is offline
post #1382 of 1394 Old 10-01-2010, 02:00 PM
teamatt74's Avatar
Originally Posted by whate View Post
After upgrading to the new firmware, BH01100329A - My LG bh100 wont play hd dvd - giving diskerror and reject dvd. It plays regular dvd, blu ray just fine.
Does anyone has similar experience?
I am having the same problem. LG won't say they don't support HD DVD issues but tell me its my HD DVD laser. I have not used the HD DVD capability in about 2 years because it stopped working after an LG update. Anyone with suggestions?
aescalle likes this.
teamatt74 is offline
post #1383 of 1394 Old 10-03-2010, 06:19 PM
Skynet79's Avatar
Excuse for mine английски I write through the translator
At me a problem for a long time has bought LG BH100 but not for a long time has bought writing a drive too marks LG has written down 50 шт disks but not one isn't read by my stationary player an insertion updated but doesn't help on other players are read without problems
Prompt please that to me to do
Skynet79 is offline
post #1384 of 1394 Old 11-04-2010, 05:42 AM
Skynet79's Avatar
all Death ?
Skynet79 is offline
post #1385 of 1394 Old 01-18-2011, 09:57 PM
VinnyS's Avatar
Liked: 54
Hey Guys, I've been reading this thread to play a Region 2 BD and trying to access the EERPOM screen, tried the Pause, 1,4,7,2 and nothing happens. Can someone please tell me what I'm doing wrong.
Get all your A/V News at: AVS Latest News
Like AVS Forum on Facebook
Follow AVS Forums on Twitter
AVSForum
Bringing the AV Community Together
VinnyS is offline
post #1386 of 1394 Old 01-25-2011, 02:46 PM
repulsion's Avatar
1. open disc tray (eject)
2. Pause, 1,4,7,2
repulsion is offline
post #1387 of 1394 Old 01-06-2012, 08:21 PM
narcopolo's Avatar
I've seen a used LG100 for sale. Should I pick it up or stay far away?
narcopolo is offline
post #1388 of 1394 Old 01-28-2012, 08:54 PM
Tweaked05's Avatar
Quoted: 41 Post(s)
Liked: 26
I have recently hooked up my BH-100 to use as a CD player in a 2 channel listening setup however every disc I put it only results in "Disc Error". Is this something that was fixed in a firmware update? I did a quick search and see that there was an update released nearly 2 years ago. I can't remember if the is the update I've already done or not. I have had this player for quite a long time and no longer use it to watch movies because it was having issues with newer BD's.
Tweaked05 is offline
post #1389 of 1394 Old 01-29-2012, 12:47 PM
shawnmos's Avatar
I don't think this player can play cds.
shawnmos is offline
post #1390 of 1394 Old 01-29-2012, 08:49 PM
Tweaked05's Avatar
Quoted: 41 Post(s)
Liked: 26
Can anyone confirm that the BH-100 doesn't play CD's?
post #1391 of 1394 Old 01-28-2013, 09:16 AM
Lanurd's Avatar
I see nothing in the Owner's Manual that indicates it can play CD's. Mine also gives an error when using my Laser Lens cleaner CD.
Lanurd is offline
post #1392 of 1394 Old 09-27-2016, 03:55 PM
Lanurd's Avatar
Smile
This thread might be as dead as my BH100 was. Been dead for a couple years and I even separated out my HD DVDs but decided to crack open the cover. Found a replaceable SATA drive and a replacement in Canada. $54.35USD It is working like new!!!!!
Lanurd is offline
post #1393 of 1394 Old 10-17-2016, 05:41 PM
Liked: 0
Hi. My LG BH100 won't load HD format disks, just gives "No Disc" message. Have you had this message? Can you clarify that you replaced the LG drive with a SATA drive? I thought the LG drive was something special.
Regards, David.
daviddsailor is offline
post #1394 of 1394 Old 10-17-2016, 07:01 PM
Lanurd's Avatar
Regards, David.
Yep, that's the same message I got. The drive was made by LG and the drive itself was labeled HL-01P and is definitely a standard SATA drive. This is where I bought it from. I bought the only one in stock but you should be able to find another one. Take out the 3 screws in the back and the top will come up for access.
http://www.tvparts.ca/tvdetail.php?id=5178
Lanurd is offline
Reply Dual Format Players
