LG BH100 Combo Player Quick Review - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 368 Old 08-24-2007, 08:40 PM
Rutgar's Avatar
Originally Posted by The_Target View Post
Not sure if this has been mentioned, but all of the buttons ar on the TOP of the device. I mounted one of these in a Middle Atlantic rack with the custom faceplate, and it's impossible to eject, turn on, or play without the remote. Why on earth would you not put the freakin eject button on the front of a device that's bound to be put in a rack?
Just get a rack shelf and place the unit on it. I know someone else who has a Mid Atlantic rack, and that's what they did.
Rutgar is offline
post #362 of 368 Old 08-28-2007, 11:45 AM
The_Target's Avatar
Obviously you can do that, but when all the other equipment is in faceplats creating a nice clean "flat" front surface, it looks hokie to have a 2U shelf and a gap above it. That being said, form must follow function in that case. Or just program the remote to take care of it all for you
The_Target is offline
post #363 of 368 Old 08-30-2007, 05:07 PM
Officer Steve's Avatar
Is this LG the only combo player available right now? I know the samsung is coming out sometime this year, but just wondering.
Officer Steve
Officer Steve is offline
post #364 of 368 Old 09-15-2007, 02:57 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
I thinks its cool with the buttons on top.
nashou66 is offline
post #365 of 368 Old 09-17-2007, 07:06 AM
Super Moderator
markrubin's Avatar
Quoted: 1044 Post(s)
Liked: 2297
unstuck
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
post #366 of 368 Old 10-15-2007, 09:50 PM
GPowers's Avatar
Quoted: 43 Post(s)
Liked: 49
There is a current (10/15/07) problem playing some blu-Ray disks (Fantastic four 2). First the disk will prompt for a firmware update to be able to play the disk. After the upgrade the video will play but you get audio drop out. I have tried both DD5.1 and DTS audio tracks. Both have the audio drop out.
GPowers is offline
post #367 of 368 Old 10-17-2007, 10:05 AM
daMaster's Avatar
If I get this player, will it output HD-DVD and BluRay via component at 1080i resolution?
daMaster is offline
post #368 of 368 Old 10-17-2007, 12:14 PM
GPowers's Avatar
Quoted: 43 Post(s)
Liked: 49
Yes, but it will NOT upscale most std DVD. The upscaling and 1080p only work accross HDMI.
GPowers is offline
Reply Dual Format Players
