For those who own both formats, which do you prefer? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 99 Old 08-06-2007, 04:11 PM
BRYKOS's Avatar
I own the HD A2 & the PS3. The PS3 allows me to see flicks in 1080p whereas I can only access 1080i thru the Toshiba. I'm not sure I see a whole lot of difference to be honest, but I've only had the PS3 for a couple of weeks & haven't done enough comparing.
Clearly though, the audio from the PS3 is markedly superior to that of the A2. I'm connected via optical on both.
BRYKOS is offline
post #92 of 99 Old 08-06-2007, 07:08 PM
highdefsw's Avatar
HD DVD as it's menus and extra features are better.
highdefsw is offline
post #93 of 99 Old 08-07-2007, 02:40 AM
No_U-Turn's Avatar
what can i say....
if you watch hd dvd or bluray via one player (like a htpc) they look exactly the same. I have never spotted any difference pq wise, i could account to one format. If they "look" different on a htpc, it´s a software related issue (for example power dvd using different renderers and therefore different video levels for each media) and this can be adjusted.
dooooooooooooooooooooooomed!
No_U-Turn is offline
post #94 of 99 Old 08-07-2007, 11:45 AM
dude2006's Avatar
Quoted: 21 Post(s)
I'm a bit confused guys. Does anyone know if it's possible to get "true" "DTS HD" with a receiver that can internally process it (like the Onkyo 875) when using the Toshiba HD XA2? I ask because the specs on the XA2 say that it supports DTS HD "core only", but I think this refers to the PLAYER'S ability to decode it. If that same signal is sent to the receiver (like the 875), which supports DTS HD, would it then not be limited to the "core" signal only? (which I understand means it's not "lossless"). Hope that my question makes sense
dude2006 is offline
post #95 of 99 Old 08-07-2007, 04:05 PM
Grampa's Avatar
I'm in the market for a DVD player to be used with a new Sony 40" XBR2. The TV will be put in a room where we exercise rather than in our primary viewing area. Also, we generally rent movies rather than buy them, and we like older classics rather than the glitzy action films that are used to show off these HD players. From this discussion, it sounds like it would make more sense to get an inexpensive SD player now, and to wait until things shake out (and prices drop) before buying either type of HD player.
Any thoughts?
Grampa is offline
post #96 of 99 Old 08-07-2007, 05:31 PM
Caurus's Avatar
Thats strange. Because using the optical out the audio from the PS3 is a lot inferior to the Toshiba A2. The PS3 delivers PCM 5.1 only as PCM 2.0 via optical. Not nice. Well even though it usually finds some 640k DD track that it can output through the optical. The A2 in contrast is able to transcode lossless sound into a 1,500k DTS track. The A3 kicks a*** in the audio division.
Maybe the PS3 sound is perceived as better because the volume level is higher. Thats a very old trick to sell mediocre audio equipment.
Format neutral! (prefering HD DVD which is build on quality while blu-ray is build on marketing)
CETERUM CENSEO BLU-RAYEM ESSE DELENDAM!
Caurus is offline
post #97 of 99 Old 08-07-2007, 06:24 PM
rbunnell's Avatar
The PS3 is noticeably inferior to the A2 when it comes to sound. Brykos, please educate yourself before posting false information. It makes you sound like a Blue-Ray nuthugger.
rbunnell is offline
post #98 of 99 Old 08-12-2007, 10:37 PM
jedimastergrant's Avatar
Quoted: 665 Post(s)
Liked: 418
I own the Tosh XA-1 and the PS3.
I also have some audio issues with the Tosh. I think it will be remedied once I upgrade to an hdmi receiver, but for now the audio is better from the PS3. I can't wait to upgrade. Hopefully sometime in the next 4-8 months.
There is no difference in video quality from these players. NONE.
Right now I prefer to use my PS3 because it is faster than the achingly slow Tosh and because of the already mentioned audio issues.
The remote on the Tosh is not so good, and neither is using the PS3 controller.
jedimastergrant is offline
post #99 of 99 Old 08-12-2007, 10:57 PM
BTBuck1's Avatar
Quoted: 13 Post(s)
WTF are either one of you talking about, both on optical, so long as the bit-rate of the movie is the same...they sound the same...
HDDVD owner: 360 add-on, HD-A30, HD-A2, A1
Blu-ray disc supporter: ubp-x800, XB1s,ps3-60gb, Oppo BDP-93, ubd-k8500
TV's: xbr55x850b/kdl55hx729/un49ks8000
Audio: Denon/Polk, Onkyo/Klipsch-Sony, Samsung SB
BTBuck1 is offline
Reply Dual Format Players
