LG Bh100 problem-question? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 41 Old 09-23-2007, 05:57 AM
Jack D's Avatar
Originally Posted by taken View Post
Receiver is just an old Sony STRDE945. Oh well. Thanks for trying Jack.
Do you have another receiver around that you could try?
Jack D is offline
post #32 of 41 Old 10-01-2007, 11:55 PM
pacpisces's Avatar
Thought to put here.
I guess we're are going to have a problem watching The Day After Tomorrow now. Or will this be all new BD+ discs? Wonder when the next firmware is?
pacpisces is offline
post #33 of 41 Old 10-02-2007, 04:01 AM - Thread Starter
taken's Avatar
Sorry for not getting back Jack. Email notification never came through. I will ask a friend when I get a chance and give your suggestion a try. Also watching for the next firmware pacpisces.
taken is offline
post #34 of 41 Old 10-04-2007, 10:28 PM
SamEdwards's Avatar
This doesn't seem to work on my macbook pro with latest system updates. 'The following disk images failed to mount'. How do you get them to mail you a disk?
Sam
SamEdwards is offline
post #35 of 41 Old 10-04-2007, 11:21 PM
pacpisces's Avatar
Call and ask for new firmware disc. To my knowledge, the last firmware was in May... so we are still waiting. October 31st is the deadline for BD players to become compliant to standards I believe, so by then if no new firmware I will be calling again.
post #36 of 41 Old 10-05-2007, 10:16 AM
Jack D's Avatar
Originally Posted by pacpisces View Post
800-243-0000
No they updated the FW on July 11th.
Jack D is offline
post #37 of 41 Old 10-06-2007, 12:15 AM
pacpisces's Avatar
The July 11th won't correct this issue. Supposedly the new firmware disc was made October 5th and they will be sending them out soon for LG.
post #38 of 41 Old 10-29-2007, 05:02 AM
warhascome's Avatar
I talked with the service ppl on Sat. I just had bought silver surfer and flashed with what they had on the site the week before to fix my Surf's up issue. That was fixed but Silver Surfer still required an upgrade. From what LG told me, they made a new one, but the sound was messed up and that they pulled it from the site again. I was told roughly 10 days until they have a new one that is done. They are testing right now on a beta that they have completed. If it makes it thru their tests, then they will release it to the web.
Approximately around the 10th of Nov I am guessing. So I would either watch the mail if you requested the disk or the site.
warhascome is offline
post #39 of 41 Old 10-30-2007, 04:51 PM
GPowers's Avatar
Quoted: 44 Post(s)
Liked: 49
Sam
Did you burn to a DVD as an ISO IMAGE not a file?
GPowers is offline
post #40 of 41 Old 04-13-2008, 05:55 AM
Airdale2k's Avatar
Originally Posted by Jack D View Post
I'm not sure what you mean. If you mean that there are lip sync problems, I assume that you are experiencing that using the analog audio connections. You should search the sticky thread on this player as there is discussion of this issue there. It appears to occur only when you stop or pause a disc and then restart. It is not a common issue for the delay to occur when using the digital audio.
The latest FW is July 11, 2007.
For what it's worth... I have the bh100 with F/W update and I've noticed that when I pause movies (not consistantly on all movies) and then start the movie again, it will be out of sync. When I pause the movie gain the press play, it's re-sync'd.
Airdale2k is offline
post #41 of 41 Old 04-13-2008, 07:08 AM
Rutgar's Avatar
This happens a lot to me. I just run the movie back a little in reverse fast scan and hit play. It usually syncs back up.
Rutgar is offline
Reply Dual Format Players
