LG GGC-H20LI Hybrid Bluray/HD-DVD Reader (PC Drive) is out and cheap! $299! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 11-01-2007, 10:39 AM
Baccusboy's Avatar
Here it is in Korea. A bit more expensive here:
http://www.icoda.co.kr/i_product/pro...901&is_enuri=1
Around $430 US.
I can barely read that it comes with PowerDVD.
"Any reviewer that didn't rail against this [Young Guns Blu-ray encode] should be sued, and Lionsgate should be ashamed of themselves. " - msgohan
Baccusboy is offline
Old 11-01-2007, 10:46 AM
JediFonger's Avatar
Quoted: 51 Post(s)
for $400 bux you can start to buy HD media burners.
LG GGC-H20N (note the last letter) will be the model that burns BOTH HD DVD+Blu-Ray... so for $400 that's what you can buy.
think about it: $300 vs. $400 is reader vs. burner of both HD media.
i'd rather wait for that GGC-H20N so i can ALSO burn!!! either 30GB or 50GB is a LOT of nice data for backing up!!!!! =)
to the edge of eternity and depth of infinity, stupidity knows no bound.
JediFonger is offline
Old 11-01-2007, 11:26 AM
HPforMe's Avatar
$430? Not interested.
HPforMe is offline
bezoar's Avatar
Actually if I'm reading the specs right the H20N reads both HDDVD and Blu-ray but only burns Blue-ray. Personally I don't see any need for burning both anyway but I'm sure that will happen eventually.
Unfortunately for right now the only standalone that does both that is available now (LG) costs over $1000. You can always buy two separate standalones but then you'll still spend more than the $300 the H20L costs right now. The biggest draw back I see at the moment is that there is now way to output DTS-MA or DolbyTrueHD audio from your sound card since powerdvdultra downrez's all the audio to 48/16.
bezoar is offline
Old 11-01-2007, 12:09 PM
JediFonger's Avatar
Quoted: 51 Post(s)
meh i don't mind that. uncompressed still sounds beefier than DD+ anyways. most movies do not take FULL advantage of the dynamic range anyways. there's simply not enough source of movies out there to fully exploit the technology. plus, one day these issues will be resolved by either hackers or legitimate patches.
PS burning either HD DVD or Blu-Ray is fine by me. it's still a ton more space than DVD9 =P
Old 11-01-2007, 12:55 PM
jsl_80's Avatar
No, GGC-H20N is the same as GGC-H20L but without support for LightScribe labeling. They can burn CD/DVD but not the HD formats.
The drives with support for burning Blu-ray (but not HD DVD) are GGW-H20N and GGW-H20L (the latter with support for LightScribe).
See here for details.
jsl_80 is offline
Old 11-01-2007, 06:40 PM
Blur2u's Avatar
you guys should keep checking the newegg link
http://www.newegg.com/Product/Produc...k=lg%2bggc
they had it yesterday for an hour before they sold out..it went again "in stock" today for about an hour before it sold out again..but i was able to get my order in...it says eta 11/06/07..but i'd check newegg again tomorrow if you're interested in getting one
Blur2u is offline
Old 11-01-2007, 08:45 PM
nowandthen's Avatar
Originally Posted by bezoar View Post
Just got my order in this morning at newegg. Apparently they are in stock at the moment. PcAlchemy also has them in stock but for about $20 dollars more. From the comment on newegg it still looks like the powerdvdultra is only the trial version, no cd code included.
Mine came with an OEM CD of PowerDVD, so I would think you will get the same. It is not a trial version.
nowandthen is offline
Old 11-01-2007, 10:15 PM
Baccusboy's Avatar
The Korea price over $400 is not the same as you would probably pay in the USA. Everything hi-def here is overpriced.
We still pay over $1,000 for last year's Samsung 1000 model Blu-ray player!
Old 11-02-2007, 06:52 AM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
http://www.newegg.com/Product/Produc...3&Tpk=lg%2bggc
I sugguest pressing the "Auto Notify button
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is offline
Old 11-02-2007, 09:48 AM
deviationer's Avatar
it is a trial. If you had the trial of powerdvd installed at any time say in the past 6 months then the "OEM" on the cd asks for a cd key.
deviationer is offline
Old 11-02-2007, 10:13 AM
JediFonger's Avatar
Quoted: 51 Post(s)
hi jsl,
i had gone back and reviewed it, yesh you are correct. ggw's are the ones... but they are still $400 (once they arrive), which is around $100-130 more than the reader only. i'd still spend it =P. besides BDR has more disc space on the dual laye anyways.
Old 11-03-2007, 03:57 PM
B Leisle's Avatar
The OEM copy of Power DVD Ultra that comes with the GGC-H20L is NOT a trial version.
You need to uninstall the trial version if you installed it. You can usually then clean out your registry of all things PowerDVD and your Application Data directories to get rid of all references to the trial version and install the OEM version. If that doesn't work contact Cyberlink and they should be able to help you resolve.
B Leisle is offline
Old 11-03-2007, 09:52 PM
nowandthen's Avatar
I have never had PowerDVD before. It did not ask for a key. Are you saying it will expire soon? On the face of the CD that came with the drive it says Bundle Only. Not for resale. I am still going to maintain that it is not a trial version. I get no warnings that it is going to expire. My understanding it that it is slightly crippled. If you want 7 channel analog then you have to buy the full version. Not saying I am 100% sure but I have not seen anything on screen warning me that it is about it expiring.
Old 11-03-2007, 09:54 PM
nowandthen's Avatar
I guess I should read all posts before I reply.
Old 11-04-2007, 11:16 AM
ericeash's Avatar
in stock at bestbuy.com. i'm still waiting til it hits $250 or lower
"Everybody thinks they have a sense of humor, even if they don't."
ericeash is offline
Old 11-04-2007, 11:20 AM
nc88keyz's Avatar
Quoted: 153 Post(s)
Liked: 78
and it will sooner than later
HT1: UN78JS9500, AVR: AVRX-7200WA, AMP: UPA-7, SPKRS: L/R: Veritas 2.3I C: 2.0CI SUR: V2.0R,, SUB: SVS SB13Ultra x2 ATMOS: 4X RC-6C, NUC i5/KODI, ChromeBox/KODI, ShieldTV
HT2: LC80LE844U, AVR: AVR4311CI, SPKRS: L/C/R: Veritas 2.2C, SUR: RC-RCRx2, SUB: 10.3x2
STORAGE: DS1812, DX513 x 2 - 4TBx18 Hybrid Raid, (It Just Works!!) R/C: HarmonyOneX2, Harmony880x1
nc88keyz is offline
Old 11-04-2007, 11:55 AM
ericeash's Avatar
that's why i'm still reluctant to buy, especially when there is such limited stock and such high demand. plus my theater's not done yet.
ericeash is offline
Old 11-04-2007, 12:54 PM
jmorris644's Avatar
Thanks. I was waiting for NewEgg but got one here. Ended up paying tax though.
Joe
A Proud Father >
Daughter's Music
jmorris644 is offline
Old 11-04-2007, 11:22 PM
ericeash's Avatar
Joe
tax, what's that.
sorry, i live in Delaware, no sales tax. but i'm a resident of Florida, no state tax. and every month i fly into a place that is tax exempt, no federal tax. i haven't paid any taxes since may.
ericeash is offline
Old 11-05-2007, 12:43 PM
mlmflip's Avatar
FYI. GGC-H20L just became back in-stock at Newegg. Just placed my order minutes ago. Get'em while they're hot.
mlmflip
mlmflip is offline
Old 11-06-2007, 12:57 PM
jmorris644's Avatar
Stupid Best Buy. I just got an email that it is backordered and not expected in for 2 weeks.
So now I even missed the availabilty at NewEgg.
Just one more reason not to buy from WorstBuy. I continue to have bad experiences with them.
Joe
A Proud Father >
Daughter's Music
Old 11-06-2007, 04:15 PM
infocusx1's Avatar
just ordred mine through newegg last night with over night shipping shoule be here tomorrow
Blu-ray/HD HTPC
infocusx1 is offline
Old 11-06-2007, 04:16 PM
jmorris644's Avatar
Oh yeah, thanks a LOT. That makes me feel real better
Joe
A Proud Father >
Daughter's Music
Old 11-19-2007, 02:40 PM
foxdie's Avatar
I checked to see what retail companies pay for this item, ready?
$220 Cost! thats nuts.
foxdie is offline
Old 11-21-2007, 05:07 PM
jmorris644's Avatar
Anyone have any more stores that are selling this? Newegg had it today but I missed it again.
The crappy Best Buy still has it on backorder!!!
joe
A Proud Father >
Daughter's Music
Old 11-21-2007, 05:11 PM
Davinleeds's Avatar
newegg is acting like amazon, I asked for notify, not.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
Old 11-22-2007, 06:58 AM
jmorris644's Avatar
Same here.
A Proud Father >
Daughter's Music
Old 11-22-2007, 06:42 PM
Tong Chia's Avatar
I got it from NCIXUSA.com. Cheaper than NewEgg, email notify works and they get my orders right (unlike NewEgg)
Tong Chia is offline
Old 11-26-2007, 09:34 AM
JediFonger's Avatar
Quoted: 51 Post(s)
i got it from ncix as well. i already installed the drive last wed (before thxgiving). it is AWESOME to play both ratatouille and WB HD DVD's that i already had. this is incredible, playing both formats AND the burner! =). me luv combo =).
