LG BH200 and Below Black or Black Enhance - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-26-2007, 04:35 PM - Thread Starter
Kurtis Bahr's Avatar
Quoted: 49 Post(s)
Liked: 25
I currently own the BH100 and the one complaint I have is that you cannot select Below Black or Black Enhance for the video signal.
Did the BH200 include this?
If not then I'll probably keep the BH100 for now and wait another year as I don't have to have HDi (though this would be nice) or the Blu-Ray new profiles for Live interaction as long as LG updates the BH100 SW to play the newer Blu-Ray discs.
Kurtis Bahr is offline
post #2 of 2 Old 10-26-2007, 10:52 PM
HyPyke's Avatar
Here is the option in the menu. It only applies to component BTW.
"Black Level
You can enhance the black level of the output signal
for picture.
[Off] - Select this when video is output from
VIDEO OUT jack.
[On] - Select this when video is output from
COMPONENT VIDEO OUT jack with the 480i
video resolution."
Note there is no "Black level" adjustment for any other resolution or connection type. It is not needed.
HyPyke is offline
Reply Dual Format Players
