Displays that support 1080p/24 signal at multiplies of the original frame rate - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 151 Old 08-18-2008, 12:07 PM
lzpoof's Avatar
I supposed best way to test 24p support would be to set somethign in regular motion on your pc and force output to 1080p24. MY ATI card allows that but unfortunately my PC is an entirely different room of the house at the moment and I ahve no other 24P sources.
I'm a little annoyed at the thought that the A630/650 might not be doing full reverse 3:2 to reconstitute the 24p source from the 60i signal and then usign 5:5 on it to display.... it's be pretty moronic to just do a 60i to 30p conversion and preserve the judder then just tell customers to use AMP to try to smooth it. Why not jsut due to the little extra work and get it right ?
lzpoof is offline
Reply Dual Format Players
