BUG REPORT THREAD - BD-UP5000 Firmware Ver1.0 - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 84 Old 01-22-2008, 01:49 PM
ephilman's Avatar
The subtitles aren't showing up on the French HD DVD of Le Pacte des Loups (Brotherhood of the Wolf). The 5000 says they are, but they aren't. And trying to toggle or change them locks it up.
Pan's Labyrinth HD DVD plays fine, with subs. Weird, eh?
If stupidity got us into this mess, then why can't it get us out?
ephilman is offline
post #62 of 84 Old 01-25-2008, 09:59 PM
carljanderson's Avatar
Originally Posted by carljanderson View Post
I have to call Tech Support Level 2 tomorrow.
Well, I ran out of time to call Samsung on Monday, since I had to catch a plane to Dallas.
I call them today, and they have to open another transaction and patch me to level 2. The woman I was working told me that they she knows they are working on a firmware, but doesn't know when it will be released. She said we, the customers, find out about a new firmware before they do.
Waiting for my 2012 upgrade...
carljanderson is offline
post #63 of 84 Old 01-25-2008, 11:51 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Not that weird...Pan's Labyrinth wouldn't even play prior to the update. My guess is they actively sought to make this one functional due to complaints. Definitely call Samsung about the title you're having difficulties with.
vinnie97 is offline
post #64 of 84 Old 01-26-2008, 10:24 AM
zens's Avatar
with anynet+ on the menus go bonkers. I have a samsung 71 series connected to it. also with the reencode feature on the sound drops out all the time. with the audiophile audio on it works fine.
zens is offline
post #65 of 84 Old 01-30-2008, 01:30 PM
Brett_L's Avatar
I am not sure if it has been reported by anyone else (though I thought I had seen it somewhere) but I am intermittently getting audio dropouts, like it just mutes for a few seconds with my BD-UP5000.
I have a very basic setup:
A Panasonic plasma directly connected to the BD-UP5000 via HDMI. No receivers or anything.
I have only tested standard DVDs and a few BD, I think the issue is mainly happening with DVD though.
I have updated to the most recent firmware and the issue is still happening.
I am considering taking the thing back and getting the LG BH200 but I am not sure if that may have more problems.
Any recommendations?
Brett
Brett_L is offline
post #66 of 84 Old 01-30-2008, 01:47 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
I have the 61 series from Samsung with Anynet enabled and the same spasmodic menu behavior. Thanks for reporting your findings.
vinnie97 is offline
post #67 of 84 Old 01-31-2008, 08:25 PM
JJ93rx7's Avatar
I am sure this has been reported before, but this is the first time that I have noticed it. While watching Sin City, SD DVD, the audio would drop out for a second and then continue to play normally. This happen about a dozen times during the movie. Will the new firmware be addressing this problem? This is the first time that it has happen to me while watching a SD DVD.
JJ93rx7 is offline
post #68 of 84 Old 01-31-2008, 09:32 PM
ScottTX's Avatar
Which audio track (DD or DTS) was selected?
I tried the DD track and watch for about 15 minutes and had no audio dropouts. I then skipped chapters forward watch a little of each and still no problem.
I then switch to DTS and there was a crackling sound in the background. I skipped chapters forward and the disk froze.
HD DVD: 101 Blu-ray: 39 DVD: 393
Samsung BD-UP5000 - TrueHD & DTS-HD MSTR : HD-D2 : PS3
ScottTX is offline
post #69 of 84 Old 02-01-2008, 12:46 AM
lalittle's Avatar
I haven't tried this particular disk, but in my experience with DD tracks on SD DVDs, there can be a good half hour or more in between dropouts, and they are not repeatable (like they are with DTS tracks.)
Larry
lalittle is offline
post #70 of 84 Old 02-01-2008, 09:40 AM
kshipman's Avatar
Playing 300 on HD-DVD. Frustrated with the 2 channel True-HD audio over HDMI, I tried the multichannel analog outputs to my Denon AVR-3808. The audio was a good 3 to 5 seconds out of sync.
kshipman is offline
post #71 of 84 Old 02-01-2008, 09:54 AM
kshipman's Avatar
Nice to note despite all of the issues people are having with this play with all of the disparate titles, Samsung lists only one known issue on their site - 3:10 to Yuma.
kshipman is offline
post #72 of 84 Old 02-01-2008, 10:03 AM
I don't recall any alerts before the 1st firmware was released on 1/17 or 1/18. I also noticed this is dated the 17th.
post #73 of 84 Old 02-08-2008, 09:46 PM
Old AV Buff's Avatar
Even after firmware update, with 24Fs set to on, the UP5000 on my Westinghouse 47" LCD shows "no input signal" & the Input select display stays on, and I still can see the movie. It does not do this when playing regular DVD or 60Fs discs, BD or HD. If I switch the 24Fs off it goes away. I did not have this problem with a Sony BDP-S300 I had set to auto for 60Fs to 24Fs. For the money this thing cost, some of this should not have got to production
Old AV Buff is offline
post #74 of 84 Old 02-09-2008, 01:22 AM
Ph8te's Avatar
Quoted: 4799 Post(s)
Liked: 4346
??? This looks like more of a connection problem since others have not had this issue with 24fps on their displays. Have you tried using a different HDMI cable? changing the input and going back to reset the handshake?
Ph8te is online now
post #75 of 84 Old 02-09-2008, 04:01 AM
I've tried a couple HDMI,s cables I had. The Samsung has a 1.3 HDMI output. Could there be a problem there? I'm not sure what you mean by "handshake".
post #76 of 84 Old 02-09-2008, 09:02 AM
Choptop's Avatar
thats because alot of the problems arent repeatable.
I've yet to have a problem with ANY discs I've played on mine. Including ones that others have claimed a myriad of problems with.
Choptop is offline
post #77 of 84 Old 02-09-2008, 10:10 AM
I swapped the deck & still have the same problem. The TV input & No Signal display go away if I play standard DVD's or an HD disc that is not 24Fs ( doesn't matter if its a BD or HD DVD). I just bought a HDMI cable that is 1.3 compliant and will give it a try. I'll let you know. Just tried it. No difference.
post #78 of 84 Old 02-09-2008, 11:05 AM
mike.elmes's Avatar
I would doubt that your LCD is capable of 24 fps signal. There is a very short list of tv's that are.
mike.elmes is offline
post #79 of 84 Old 02-20-2008, 07:54 PM
Problem solved. Went back to BB & traded for a Panasonic DMP-BD10a.
post #80 of 84 Old 02-20-2008, 07:56 PM
Laserjock1963's Avatar
I hope it wasn't an even trade.
Laserjock1963 is offline
post #81 of 84 Old 02-20-2008, 09:14 PM
Got the BD10a for $375.00. Saved me some cash. I'll just use my Toshiba A1 until they get the bugs worked out & the price drops alittle. For a bonus the 10a also plays DVD-Audio discs. Nice.
post #82 of 84 Old 02-29-2008, 06:02 PM
ConradWS's Avatar
The January firmware update did not fix the problems with the Star Trek TV series HDDVD boxed set. Some of the episodes still lock-up the 5000 (as reported in the 5000 Problem Disk thread,
Just for the record because I've seen several Star Trek complaints.
The standard definition (TOS) DVD boxed sets also had problems. Freezing in the menus...not being able to select episodes from the menu...forcing rebooting of the DVD players.
I think Paramount needs to work a little more on quality control and a little less on copy protection.
I haven't had the time to see if the SD disks still exhibit problems in the 5000.
Later, Conrad
ConradWS is offline
post #83 of 84 Old 03-03-2008, 07:20 PM
Version 1.1 on website now. Looks like some playback issues of some movies may be fixed.
post #84 of 84 Old 03-04-2008, 04:15 AM
kshipman's Avatar
I finally broke down and returned my 5000 over the weekend. For the money, it was simply too temperamental and it was just not what Samsung committed to. I finally broke down when I still could not play Ratatouille without difficulties, and had the reset the player three times trying to play standard DVD's for family members who were in town visiting. I'm going to invest in a Pioneer Elite player. Good luck to all who hold on to these units.
Ken
kshipman is offline
Reply Dual Format Players
