Are all Oppos created equally for 2-channel - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 45 Old 03-10-2008, 05:20 AM
thehun's Avatar
Quoted: 640 Post(s)
Liked: 529
Secret's lates Oppo 983 review, that "targets" the sound by JJ.
http://www.hometheaterhifi.com/dvd-p...the-story.html
De sagittis Hungarorum libera nos, Domine!
The Hun
thehun is offline
post #32 of 45 Old 03-11-2008, 10:53 AM - Thread Starter
jmcomp124's Avatar
My 983H arrives tomorrow
jmcomp124 is offline
post #33 of 45 Old 03-13-2008, 05:43 PM
Quoted: 73 Post(s)
Liked: 112
Nice! I have the 980 myself and it has been nothing but excellent
rnatalli is offline
post #34 of 45 Old 03-14-2008, 09:03 PM - Thread Starter
jmcomp124's Avatar
Did some limited listening to the 983H with a couple of SACDs (Dire Straits, Audiophile voices) through my bottlehead tube pre-amp in pure 2-ch. All that I can say right now is that it was about half an hour of beautiful music, that made me smile throughout. I have to say, I haven't done such listening in almost a year and the bottlehead pre had some bad connection last night I had to debug and solder but after it was done, Oh my, what pure listening pleasure. This is the first time, I get to listen to SACDs with an analog section geared towards audiophiles. Simply astounding performance!
I will be listening more in multi-ch shortly, but there is that magic of 2-ch that is hard to explain. I love it!
Get a 983H if you can!
post #35 of 45 Old 03-14-2008, 09:05 PM - Thread Starter
jmcomp124's Avatar
One more thing, if you play multi-ch SACDs through HDMI, then make sure to set the resolution (yes I mean video) to a higher resolution (see manual for that limit). If not, what you get is 2ch FL and FR that goes to your pre (something to do with the HDMI spec for bandwidth that is kind of weird). I first thought something was wrong with the 983H but it was the resolution and down-mix to be set to 5.1. Enjoy!
post #36 of 45 Old 03-24-2008, 05:58 PM
Homosapien's Avatar
I do not understand the purpose of preamp in this case:
1. OPPO has it's own volume control;
2. Preamp can not improve the sound - the sound as good as analog part of OPPO.
Am I missing something?
Thank you.
Homosapien is offline
post #37 of 45 Old 03-25-2008, 10:30 AM
Blindamood's Avatar
It does? Which one? I have the 980H and I'm not aware of a volume control.
Brad
Blindamood is offline
post #38 of 45 Old 03-25-2008, 11:00 AM
sivadselim's Avatar
Quoted: 163 Post(s)
Liked: 154
Yes, it has an output level trim.
And to answer Homosapien, it's not the best way to control the volume. And preamps do other things besides control the volume.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #39 of 45 Old 03-25-2008, 03:58 PM
Blindamood's Avatar
Sorry, I don't really consider that an adequate (if even usable) volume control. Either way, you're right, there is much more to a preamp than volume control.
Brad
post #40 of 45 Old 03-25-2008, 04:36 PM
Homosapien's Avatar
I have OPPO 971 connected directly to amp and controle volume on remote. I just ordered OPPO 980 and assumed that it also has volume control. What else can I gain ( I do not switch sources) adding analog preamp?
Thank you.
post #41 of 45 Old 03-25-2008, 05:04 PM
sivadselim's Avatar
Quoted: 163 Post(s)
Liked: 154
a knob?
(yes, the 980 has an output level trim)
post #42 of 45 Old 03-28-2008, 06:12 PM
thehun's Avatar
Quoted: 640 Post(s)
Liked: 529
Thank you.
It's more like a gain control[Oppo], and it should be set to the max to achieve the standard 2v output. A typical preamp will provide much more then that which will give better S/N ratio.
The Hun
thehun is offline
post #43 of 45 Old 03-28-2008, 09:11 PM
Homosapien's Avatar
OK, thank you.
Do you think it make sense to get high end tube preamp for OPPO 980 with HT bypass (I am going to have multichannel pre/pro later)?
The rest of the system is EAD PM1000 and Proac 1.5.
Thank you.
post #44 of 45 Old 03-28-2008, 09:23 PM
thehun's Avatar
Quoted: 640 Post(s)
Liked: 529
I can't comment on that, as I'm very happy with my Integra Pre/Pro, but I would recommend you to buy the MCH Pre/Pro first, and if you're not happy with the 2 ch sound, maybe you can invest in a dedicated 2 ch preamp.
The Hun
thehun is offline
post #45 of 45 Old 04-10-2008, 12:38 AM
Darthfunk's Avatar
Guys I am using 983 mainly for 2 channel analog listening and it sound excellent. I feel that the sound is a big improvement over 980 especially with the new upgrades.You can check out my mini review on the 983.
Darthfunk Mini Review
OPPO DV-983H
Darthfunk is offline
Reply 2-Channel Audio
