Stereo input to a single speaker - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-09-2008, 06:50 PM - Thread Starter
b-ruse's Avatar
Hello to all. I am attempting to set up a multi room system in my wife's salon. I am not looking for symphony quality sound, mostly just background noise for the stylists. I bought an Onkyo receiver and a monster speaker selector from Circuit City, and a few pairs of speakers. My question is, is there any way to adapt the left and right output into a mono output to send to the speakers?
b-ruse is offline
post #2 of 9 Old 03-09-2008, 07:35 PM
cavu's Avatar
Is there a "Mono" switch on the Onkyo???
"The greatest obstacle to discovery is not ignorance  it is the illusion of knowledge." - Daniel Boorstin
"Our lives begin to end the day we become silent about things that matter.
" - MLK
cavu is offline
post #3 of 9 Old 03-10-2008, 06:47 AM - Thread Starter
b-ruse's Avatar
No, unfortunately it isn't that easy. It is a lower end receiver, as we are trying to start a business, it only has tone, bass, and balance for audio controls.
b-ruse is offline
post #4 of 9 Old 03-10-2008, 06:57 AM
cavu's Avatar
Does it hsve 'tape' out/in ?
" - MLK
cavu is offline
post #5 of 9 Old 03-10-2008, 08:04 AM
whoaru99's Avatar
Liked: 69
Speaker-level stereo to mono converter
Dunno how the load matching works on the transformer output though. I'd image you'd have to connect the speakers in a series/parallel arrangement to present roughly an 8 ohm load - unless your speaker switch is an impedance-matching type.
Just for background music, it might be easier to return all this stuff and look into a small 70v distribution system.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #6 of 9 Old 03-10-2008, 08:21 AM - Thread Starter
b-ruse's Avatar
It does have tape 1 and 2 inputs. Thanks for the link on the converter.
b-ruse is offline
post #7 of 9 Old 03-10-2008, 08:30 AM
Miney's Avatar
Can you return the speakers?
Several companies make "Stereo Input Speakers" for such applications as yours. I installed one in the kitchen and wife's office... do a nice job.
Check these out.
http://www.crutchfield.com/S-OhyBFcD...tereo%5FInputs
Miney is offline
post #8 of 9 Old 03-10-2008, 03:18 PM
cavu's Avatar
Does it have a "tape (rec) output"???
If so, get one of these for $4: (2xRCA male to 1xRCA female)
and one of these for $8: (2xRCA male to 1xRCA male)
  • Plug the two adapters together.
  • Plug the two RCA connectors on one end to the Tape OUT (Rec).
  • Plug the two RCA connectors on the other end to the Tape IN (Monitor).
  • Press/select the "Tape Monitor" on your receiver.
Everything will now be in MONO.
" - MLK
cavu is offline
post #9 of 9 Old 03-21-2008, 05:00 AM
oldschool4life's Avatar
NO!!!
...do not combine line-level inputs without isolation.
On line-level, you use a summing circuit; 1Kohm 1/4 watt resistor on the center conductor is the important part; I built one once with a plastic project box & 8 jack rca piece; it allowed me to have a mono output which I doubled for my purpose.
http://www.mobileaudio.com/rac-faq/r..._5.html#SEC106
Originally Posted by oink
Mr. Cialella is, without question, the AVS honorary MOST ADMIRED PERSON OF THE YEAR.:D
oldschool4life is offline
Reply 2-Channel Audio
