Cerwin Vega CLS-12's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-09-2008, 09:17 PM - Thread Starter
tkbrooklyn's Avatar
I am looking into getting a pair of the Cerwin Vega CLS-12's. I am not sure exactly what to buy in terms of an external amp or receiver that will allow me to drive the speakers to there max/best ability. For some reason I can't find the impedance for these speakers on the company's website either. Anyways, the specs provided are shown below, any help would be appreciated. Thanks!
Per speaker:
Frequency Response: 28 Hz - 20 kHz
Peak Power Handling: 300 watts
Sensitivity (1w/1m): 92 dB
6 1/2" Midrange with Fiber Impregnated Cone
1" Soft Dome Tweeter with Ferro Fluid
12" Cast Frame High Excursion Woofer
Proprietary Mid and High Frequency Waveguide
Fuse Protection
Elegant Black-Ash Enclosure
tkbrooklyn is offline
post #2 of 4 Old 03-12-2008, 04:07 PM - Thread Starter
tkbrooklyn's Avatar
Ok thanks guys. Got it! Haha.
post #3 of 4 Old 03-13-2008, 10:16 AM
Jim85IROC's Avatar
so what was it... 4 ohms? Most of the "red surround" Cerwin Vega speakers were 4 ohm speakers. That's partly why they had such high sensitivity. I have an old pair of 280SE speakers which were one of their rare 6 ohm units. However, even those were a fairly difficult speaker to drive. Most of my cheap receivers that I've had over the years would always go into protection mode even at modest volume levels. Get a good robust amp that loves 4 ohm loads and those speakers will absolutely crank. I dj small parties with mine.
Jim85IROC is offline
post #4 of 4 Old 03-15-2008, 05:43 PM - Thread Starter
tkbrooklyn's Avatar
They are rated at 8 ohms. I found an amp that puts out 210 watts per channel at 8 ohms. It's the cv-900 made by Cerwin Vega. Not sure if this would be a good amp or not. Haven't found anything that is a 2 channel amp closer to 300 watts. I was told that underpowering the speakers may damage them. Is that true? It doesn't seem to make sense at all to me.
Reply 2-Channel Audio
