Preamp with HT bypass or volume at fixed position - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-10-2008, 01:50 AM - Thread Starter
vinodk's Avatar
Quoted: 84 Post(s)
Liked: 33
I am trying to find a preamp within reasonable coast(approx $500.00) to integrate in my HT system. Do I need a preamp with HT bypass or can I get any preamp & place the volume knob at 12 o'clock position & calibrate the levels for front Lt/Rt from the processor & use that as the setting for HT.
Vinod
vinodk is offline
post #2 of 9 Old 03-10-2008, 02:21 AM
Summa's Avatar
Quoted: 104 Post(s)
Liked: 274
Pretty sure you can do either. I did a lot of research on this issue before buying my preamp a few months ago, and from what I learned you can get by with either. I went with a bypass, though, because this way I can keep the preamp off and not wear down the tubes when I'm not using it for music.
Summa is offline
post #3 of 9 Old 03-10-2008, 08:49 AM - Thread Starter
vinodk's Avatar
Quoted: 84 Post(s)
Liked: 33
Thats what I am debating but if I can get by without HT bypass option then I have a chance of looking at more preamps before purchasing. Would leaving the volume knob at fixed position & calibrating levels for front speakers be same as using HT bypass?
Vinod
vinodk is offline
post #4 of 9 Old 03-10-2008, 08:53 AM
Kal Rubinson's Avatar
Quoted: 685 Post(s)
Liked: 468
You can do that but it would more accurate and consistent if the preamp had a stepped volume control to assure you that you really could place the control in the same spot each time.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #5 of 9 Old 03-10-2008, 08:57 AM
deeppurpleman's Avatar
I have a Musical Fidelity A3cr preamp and that's how I do it. Set it at 12 o'clock. Not too hard to do.
deeppurpleman is offline
post #6 of 9 Old 03-10-2008, 09:04 AM
Summa's Avatar
Quoted: 104 Post(s)
Liked: 274
Vinod: If you find a preamp that you really like but it doesn't have an HT bypass, check with the company/designer about adding one. Sometimes they don't include one in the stock model, but many of them can add it for a small additional fee.
Summa is offline
post #7 of 9 Old 03-10-2008, 10:10 AM - Thread Starter
vinodk's Avatar
Quoted: 84 Post(s)
Liked: 33
I am looking for a used high end preamp therefore a new one with HT bypass is my second chioce.
Thanks Kal for the suggestion, I will look for something with stepped volume control.
Vinod
vinodk is offline
post #8 of 9 Old 03-10-2008, 02:44 PM
Amnizu's Avatar
couple models to consider, the Adcom GFP-750, and the Primare PRE-30, the Primare is going to be a fair bit more expensive than the adcom. Krell also makes a couple of models that have HT bypass in both a pre and integrated amp options. Take a look over on audiogon for pricing..
Amnizu is offline
post #9 of 9 Old 03-11-2008, 09:54 AM
70chevelle's Avatar
If you are looking for tubes or hybrids, Anthem/Sonic Frontiers (basically the same company) produced pre's with an SSL, or surround sound loop. They go on audiogon for $350-$700 +/-. Rogue also made the 66 and 99 magnum, but the HT bypass may have been an option, so you'll have to look closely. I also went thru this, and decided to go the dedicated 2 channel route.
70chevelle is offline
Reply 2-Channel Audio
