Need help, new to 2 channel... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-15-2008, 12:13 AM - Thread Starter
_Hotsauce_'s Avatar
Hi there,
I am currently in the market to put together a 2.1 system for the sole purpose of music. My music taste revolves more or less around trance, heavy on vocals and instrumental heavy trance.
My current system is a pre-boxed system, the Logitech Z5500's, information on the system can be found at the Logitech website, as I can't post URL's as I'm new
They are hooked up to my desktop, and do a sufficient job of reproducing music how I would like it, But, I am unhappy with the quality of the satellites, the music often gets drowned out by the sub.
I am very passionate about bass, but would like to move to something that sounds much clearer and crisper when it comes to the mids and highs.
With that in mind, I would like to pick up a receiver($250-$400 range), a pair of excellent sounding book shelves ($250-$750 price range) and a sub, which may come at a later time. I do not want to skimp out on a sub. For the sub I want the bass lines to be super smooth and accurate at all frequency's, as trance can throw a lot out there. I have music playing whenever I am at home, so it would be put to use.
Could anyone point me in the direction of where to start on this system? Even just a receiver + speakers for the time would be good. I leave a wide price range for the speakers, as I'm willing to spend more if needed, but would settle for something at a lesser price if it sounded how I wanted.
_Hotsauce_ is offline
post #2 of 7 Old 03-15-2008, 07:47 AM
dknightd's Avatar
I'd start by looking in the yellow pages for local stores that sold hifi gear. Then I'd put together a sample CD that contains some of the music I like to listen to. Next I'd go to all local stores and start listening.
Everything I say here is my opinion. It is not my employers opinion, it is not my wife's opinion, it is not my neighbors opinion, it is My Opinion.
dknightd is offline
post #3 of 7 Old 03-15-2008, 08:09 AM
twitch54's Avatar
Originally Posted by _Hotsauce_ View Post
Hi there,
As dknighted says.....get out and listen !
Now two cents worth of advise on bass (sub)......if music is the 'sole' reason for this set-up , then what you want is a 2.0 system that utlizes a 'servo based sub' in conjunction with a good eq set-up. For ease of installation and good value I recomend the "DD" series of subs from Velodyne. You merely run another set of I/C's from a second output of receiver or pre-amp to the sub and bring "it" in with respect to bass roll-off of your main L/R speakers, utilizing the buit in eq programing to facilitate this.
I know I somewhat beleagured the 'bass' point, but you seemed passionete about the need !
Good Luck !
twitch54 is offline
post #4 of 7 Old 03-15-2008, 09:04 AM
oldschool4life's Avatar
A good start would be to get an integrated amp from Cambridge Audio, Rotel, or NAD; the Pioneer Elite is the cheapest one available.
Speakers: Paradigm, PSB, & B&W are good brands to check out first.
Originally Posted by oink
Mr. Cialella is, without question, the AVS honorary MOST ADMIRED PERSON OF THE YEAR.:D
oldschool4life is offline
post #5 of 7 Old 03-15-2008, 11:43 AM - Thread Starter
_Hotsauce_'s Avatar
"Now two cents worth of advise on bass (sub)......if music is the 'sole' reason for this set-up , then what you want is a 2.0 system that utlizes a 'servo based sub' in conjunction with a good eq set-up. For ease of installation and good value I recomend the "DD" series of subs from Velodyne. You merely run another set of I/C's from a second output of receiver or pre-amp to the sub and bring "it" in with respect to bass roll-off of your main L/R speakers, utilizing the buit in eq programing to facilitate this."
So that more or less went right over my head. Could you explain it in um....a non-stereo person kinda way? :P
post #6 of 7 Old 03-15-2008, 11:45 AM
milaz001's Avatar
I'd have a look at an integrated amplifier from NAD or Marantz, or a stereo receiver from H/K, Marantz or Onkyo. You gave a wide price range for speakers. I'd have a serious look at the Concerta M12s from Revel.
We live in a society exquisitely dependent on science and technology, in which hardly anyone knows anything about science and technology.
milaz001 is offline
post #7 of 7 Old 03-15-2008, 06:41 PM
Lazonby's Avatar
I listen to a lot of EDM, particularly vocal trance, but I do like hard trance, house, and progressive. My suggestion would be Paradigm Mini Monitors for bookshelves, a higher-end Yamaha receiver (RXV series)--although I would highly recommend going separates (like a Rotel RC-1070 preamp & the small RB series power amp; both can be had for $700-800). The reason I mention that is that the SQ is way better and you can add a different amp. Sometime in the future I would highly recommend picking up a tube amp...these things work magic with EDM. As for the sub, I think a Paradigm PDR-10 would be entry level...they sound nice and blend well, but not quite as tight as you might be looking for and could get out of a Velodyne or B&W. This is where you'll probably need to visit a few shops and listen to various models.
Lazonby is offline
Reply 2-Channel Audio
