HELP with cable - 3.5mm to RCA - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-17-2008, 01:04 PM - Thread Starter
spideytech's Avatar
Where can I find a stereo 3.5mm (female) to two RCA (female) y cable (6 or 8 inches long)? Similar to the one attached.
Dale
spideytech is offline
post #2 of 7 Old 03-18-2008, 09:04 AM - Thread Starter
spideytech's Avatar
Help, anyone know of where to get one?
Dale
post #3 of 7 Old 03-18-2008, 09:26 AM
fsu jd's Avatar
radio shack, best buy, circuit city, possibly walmart
fsu jd is offline
post #4 of 7 Old 03-18-2008, 12:06 PM - Thread Starter
spideytech's Avatar
Thanks but have checked all those and then a ton of obscure internet ones. Only place I can find it is cyberguys.com and it is perpetually out of stock there. Was hoping someone here could point me some where.
Thanks again
Dale
post #5 of 7 Old 03-19-2008, 08:51 PM
Comp.Audiophile's Avatar
Comp.Audiophile is offline
post #6 of 7 Old 03-19-2008, 09:20 PM
whoaru99's Avatar
Liked: 69
Monoprice.com product ID 666 + product ID 678 = $1.19 plus shipping.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #7 of 7 Old 03-20-2008, 12:42 PM - Thread Starter
spideytech's Avatar
Thanks guys for the help. Yeah I can use two connections and make it work. Was just trying to keep things simple and connections to a minimum.
Dale
Reply 2-Channel Audio
