Aric audio, anyone tried them? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-22-2008, 11:34 PM - Thread Starter
dbacksfan51's Avatar
Has anyone tried one of there Tube preamps? Price is really cheap, so it has caught my eye. After sending a few emails They can build a tube preamp, with HT bypass, and a seperate Subwoofer volume control for around $250. My reason for wanting to try this is, My Integra DTC 9.8's with Audyssey running for Stereo, does not seem to have much going to the subwoofer. So the sound is very bad. Now if I switch to direct, it sounds fine, but this bypasses the sub. All I want to do is be able to use my sub with my Turntable, and my current setup, does not mesh well.
dbacksfan51 is offline
post #2 of 2 Old 03-23-2008, 11:51 PM
scorch123's Avatar
Contact Don Allen in Phoenix - he specializes in tube audio gear and will give you advice...
scorch123 is offline
Reply 2-Channel Audio
