Installing 4 sets of speakers with one receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-29-2008, 09:42 AM - Thread Starter
a_spreadhead's Avatar
I am finishing my basement and plan to have 4 pairs of Polk RC80i's in various rooms..My plan is to have 3 seperate in-wall volume controls (1 per pair for each of 2 seperate pairs and then have 2 pairs off of the same control). I dont know a whole lot about this but really want to install the system myself. I figure I can save on installation labor which will allocate more money from my budget to better equipment....
I guess my questions are:
Can you effictively run multiple pairs off of one volume control? (looking at the Niles VCS100R and the Channel Vision CV-300W) thoughts on these? Do the volume controls evenly dispurse the power to the speakers?
Would my best option be to have an 8-channel amplifier to run all of these speakers? was considering the Speakercraft.....is this too much amp?
My plan was to use a basic receiver/tuner. This application will only be for music (totally seperate system for my theater)....
I am wiring mid next week so any thoughts, suggestions, recomendations would be very very much appreciated!
a_spreadhead is offline
post #2 of 6 Old 04-01-2008, 07:05 PM
bluewaves's Avatar
Quoted: 16 Post(s)
How bout a speaker selector to help split up the load and that should take care of most of your problems.
bluewaves is offline
post #3 of 6 Old 04-03-2008, 12:20 AM
the rick's Avatar
I would recommend going to a distribution amplifier with multiple channels. A personal favorite is the SI-1230 from niles for great reliability and good sound.
I would put a volume control in each room/area, one per pair of speakers.
the rick is offline
post #4 of 6 Old 04-07-2008, 09:34 AM
Miney's Avatar
A distribution amp is optimal, but if on a budget a 2 channel receiver with a speaker selection switch like the Niles HPS-4 will do the job. I see these on eBay for $50.
If you go with a selection switch config, the receiver needs to have a decent amount of power since you are sharing it in up to 4 places simultaneously.
I agree with individual volume control for each pair of speakers, unless you wanted to get into IR Distribution... which can be a pain.
Good luck with your installation.
Miney is offline
post #5 of 6 Old 04-07-2008, 03:42 PM
Raymond Leggs's Avatar
There's nothing like 4 pairs of speakers cranked all at once!
Raymond Leggs is offline
post #6 of 6 Old 04-07-2008, 08:49 PM
Condar's Avatar
Even if you are running 2 ch amp you should be able to 4 sets of speakers. According to theory you should be able wire the 1 + 2 set in series and the 3 + 4 set in parallel. This would allow your AVR or amp so see the same ohms and not overload it.
Reguardless, if you have ample wattage is another story....
Professional Practitioner of Obsolete Technology & Repository of Useless Information
I keep pointing my remote at my turntable but, it never advances to the next track.
Condar is offline
Reply 2-Channel Audio
