Audiophile quality out of a pc - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 08-15-2008, 11:01 PM - Thread Starter
HossinLV's Avatar
I am posting here since the HTPC forums primarily deal with surround sound and that is not what I am into. Does anyone know of an Audiophile quality 2ch sound card for a pc.
Any help is welcomed and appreciated.
HossinLV is offline
post #2 of 26 Old 08-15-2008, 11:11 PM
westcoastman's Avatar
You can have a look at this one from M-Audio
http://www.m-audio.com/products/en_u...e192-main.html or http://www.echoaudio.com/Products/PCI/MiaMIDI/index.php from Echo
There are other manufacturers you just need to run a search on digital audio cards.
westcoastman is offline
post #3 of 26 Old 08-16-2008, 05:24 AM
Rutgar's Avatar
Those can't possibly be Audiophile grade... they don't have any vacuum tubes.
Rutgar is offline
post #4 of 26 Old 08-16-2008, 05:59 AM
kouack's Avatar
Too late the audiophiles had their fingers in computer as well
http://www.retrothing.com/2007/07/vacuum-tube-pc-.html
Warning to prevent risk of injuries, you should always be smarter than the equipment you are about to use.
kouack is offline
post #5 of 26 Old 08-16-2008, 06:14 AM
Rutgar's Avatar
That's funny. Especially since the author mentions the desire for a vacuum tube sound card.
Rutgar is offline
post #6 of 26 Old 08-16-2008, 04:12 PM
dknightd's Avatar
I'd suggest putting your soundcard outside the computer. If you can afford it the Benchmark DAC1 is a nice unit. Google it. There are lots of other options. Basically it boils down to what you want and how much you have to spend.
I don't know how the discussion got sidetracked by tubes. Nothing wrong with tubes. At least when they distort they do it with nice even order harmonics,
Everything I say here is my opinion. It is not my employers opinion, it is not my wife's opinion, it is not my neighbors opinion, it is My Opinion.
dknightd is offline
post #7 of 26 Old 08-16-2008, 04:32 PM
Rutgar's Avatar
it was a joke.(didn't see the big smilely face, eh?)
Rutgar is offline
post #8 of 26 Old 08-16-2008, 05:59 PM
wrat's Avatar
just get a sound card that can do "bit perfect" digital out and feed it to your dac of choice
wrat is offline
post #9 of 26 Old 08-16-2008, 09:37 PM
Comp.Audiophile's Avatar
Use a Lynx AES16e card to output digital to a nice DAC via AES and you'll be extremely happy.
Chris Connaker
Founder
Computer Audiophile
Comp.Audiophile is offline
post #10 of 26 Old 08-17-2008, 09:28 PM
scorch123's Avatar
I have an RME Digi 96/8 PAD, and it sounds great.
Make sure your sound card's drivers are supported by your OS.
USB DACs can sound very good, too. What is your budget?
- Steve O.
scorch123 is offline
post #11 of 26 Old 08-28-2008, 01:23 AM
Veda's Avatar
Quoted: 125 Post(s)
Liked: 90
A regular el-cheapo Sound Blaster that has digital 96/24 out would suffice. Just use it to stream PCM to a DAC or receiver of your choice which in my case is an Onkyo TX-L55 with PSB Alpha B1's.
Veda is offline
post #12 of 26 Old 08-28-2008, 02:08 PM
Ugly1's Avatar
I think the thing that the truly hard core will look down there nose about with this solution as it is not the optimal solution for dealing with the inherrent PC clock jitter and thus suggestions for using things like AES or asynchronous USB etc.
However I am getting by quite nicely with a similar solution that uses a PLL reclocker on the PCM strereclocks it to a much lower jitter clock source than what comes out of my PC. Not that I claim to be an expert in identifying audible jitter artifacts but that this was necessary in order to get my preamp to lock on to the 96k/24bit stream from my PC consistently and reliably.
Ugly1 is offline
post #13 of 26 Old 08-28-2008, 03:32 PM
WallyWest's Avatar
I use the Emu 0404 USB.
http://www.digit-life.com/articles2/...-0404-usb.html
I've heard the 0404 compared favorably with DAC's costing thousands more. It may not the be the absolute best solution, but it's a fantastic value. USB is usually very jittery, but that's because of the way Windows handles it. The 0404 has it's own USB drivers that fixes that problem, and it's a reclocking DAC. Plus it has phantom power for a microphone if you want to use your PC to do room measurements, speaker calibrations, things like that.
WallyWest is offline
post #14 of 26 Old 08-28-2008, 03:37 PM
Grandarf's Avatar
If you output digital from the computer you should be in business. The analog signal from the computer is usually the weak link. So if you output digital, and use a good DAC (digital to analog converter), you'll get very near perfect sound out of your pc. Soundcard wise, any with digital out should be good, the improvement in quality usually affect the analog signal, but since you're outputting digital, any card can easily output the 0-1 perfectly.
You don't need a crazy DAC like the DAC1 either, even a Behringer DEQ2496 does the job perfectly, and it's like 300 bucks I think. From there, you just output to your pre or integrated amp, or even directly through a power amp... Woila, audiophile grade sound from the computer.
http://209.85.171.104/translate_c?hl...Pf2xulC9mfmglw
Now making the computer 100% silent is another matter!
Grandarf is offline
post #15 of 26 Old 08-29-2008, 10:13 AM
scorch123's Avatar
I have demo'd USB dacs in my PC-based system and have not heard major audible differences between them and my PCI-based RME card. "Very jittery" needs to be backed up with jitter/Thd measurements, IMHO.
- Steve O.
post #16 of 26 Old 08-29-2008, 06:22 PM
/dev/null's Avatar
What kind of budget are we talking about, and do you want 'good' quality, or 'audiophile' quality?
Peter M
******This space for rent******
/dev/null is offline
post #17 of 26 Old 08-29-2008, 07:25 PM
Veda's Avatar
Quoted: 125 Post(s)
Liked: 90
Originally Posted by scorch123 View Post
"Very jittery" needs to be backed up with jitter/Thd measurements, IMHO.- Steve O.
I was about to say that as FLAC depends on the quality of the CD used to rip as well. So jitter issue is the least on my mind especially when their audible effect are arguable as well.
Veda is offline
post #18 of 26 Old 08-30-2008, 08:49 AM
WallyWest's Avatar
- Steve O.
If you want to get technical there are several different modes USB can run in, based on the Windows drivers. The really horrible one is synchronous mode. Which many cheap USB devices use. There is zero error correction of any kind used in this mode. And it uses a fixed clock which makes it virtually impossible to generate 44.1Khz. It's essentially fixed at 48Khz. Jitter in this mode is off the charts, and that has been backed up many times. I agree that in general jitter is an overblown issue, but this is extreme jitter. If you care at all about audio quality stay far far away from devices using synchronous mode. Which can usually be identified by running only at 48Khz.
Asynchronous mode, which is very flexible and allows any clock speed you want, would be great. Too bad nobody uses it.
Adaptive mode is what most decent devices use. It's better than synchronous, but still not great.
Or you can do what Emu does and throw all that out the window. They wrote their own standard which runs in what is essentially asynchronous mode with some fancy error correction, and they reclock the data at the other end. This is probably overkill, and I wouldn't pay a premium for it. But the 0404 is pretty cheap.
As for proof I've heard it many times myself. The 0404 supports ASIO, but only through it's own drivers since the timing is totally different. Using the standard ASIO drivers in Winamp produces all sorts of clicks and pops and dropouts. That's an extreme case where the source is completely out of sync with the card, but I've heard many people complaining of the same thing with cheaper synchronous USB sound cards.
post #19 of 26 Old 08-30-2008, 01:47 PM
Ugly1's Avatar
The latest Wavelength Audio DAC's all run in asynchronous USB mode. They are supposed to be pretty good sounding too from what I've been told. The biggest hurdle is the price of entry is a bit steep for my blood.
Ugly1 is offline
post #20 of 26 Old 09-02-2008, 08:14 AM
scorch123's Avatar
Hi WallyWest,
I read another post on a different forum about USB jitter. It's just as technical sounding as your post, again with no examples of actual USB Dac products w/ measurements to back it up. I am still skeptical, especially since your post is a condensed version of this:
http://www.audioasylum.com/forums/pc...ages/7719.html
I am not saying you or that other poster is wrong, however. I am going to do more digging and see if I can get someone to provide real-world examples of synchronous, adaptive, and asynchronous mode USB dacs.
- Steve O.
post #21 of 26 Old 09-02-2008, 01:25 PM
Ugly1's Avatar
For an example of adaptive look at DAC1.
For examples of Asynchronous look at Wavelength stuff.
Both seem to be pretty well regarded.
Ugly1 is offline
post #22 of 26 Old 09-02-2008, 07:40 PM
rockboy2001's Avatar
OK so how about "Good Quality" for 150.00 or less, for us beginners? I just want good music around the house with my "music computer" as the source.
Thanks, rockboy2001
rockboy2001 is offline
post #23 of 26 Old 09-02-2008, 08:24 PM
penngray's Avatar
Liked: 47
m-audio sound cards are fine your purpose...actually USB cards or Motherboards with digital audio out is actually find for you. Several post here will try to give you info on something that you are remotely interested in and the "Just want good music" is an extremely subjective topic that will go downhill fast because some of these guys spend thousands on just cable and wiring alone. Obviously you are not interested in opinion from those types.
I use a m-audio 1010 card to send music from on PC to 8 zones around my house and I can play many song simultaneously in different zone I a choose too using my home audio distribution software (charmedquark).
penngray is offline
post #24 of 26 Old 09-02-2008, 08:45 PM
Veda's Avatar
Quoted: 125 Post(s)
Liked: 90
BTW, do you guys know Onkyo makes some fine PCI soundcards?
Veda is offline
post #25 of 26 Old 09-02-2008, 08:51 PM
Veda's Avatar
Quoted: 125 Post(s)
Liked: 90
No kidding but it would be more cheaper to get a soundcard that can output 192 and have it routed to a standard HT receiver that has 192/24 DAC.
Veda is offline
post #26 of 26 Old 09-07-2008, 08:07 PM
Megalith's Avatar
Quoted: 22 Post(s)
I just use an Audiophile 192 with studio monitors.
FLAC played back through Foobar, using ASIO.
Megalith is offline
Reply 2-Channel Audio
