Sub on HK 3490: is this perfect connection? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-01-2008, 07:59 PM - Thread Starter
Karmin's Avatar
Hello, I just bought a subwoofer, see there http://precision-acoustics.com/hds10.html for my Harman Kardon 3490. I wonder if I connected it perfectly though. I could only connect an RCA plug from 3490 to sub. On the HK there are link switches and trigger outputs. I can't find anything to connect to these outputs from the sub (see photo). So if I understand well, some subs have trigger inputs and some don't. Mine obviously don't. As for the link switch, well...I read the instruction manual and I still can't get it. OK time to laugh! BTW, this Precision Acoustics sub is from the same company that carries Harman Kardon (Jam Industries). They also carry EuroDesign and Sinclair Audio brand. Products all are rebranded. Go to http://precision-acoustics.com/index.html have a look at the picture in the center, you can see clearly a Harman Kardon AVR and newer models of Precision Acoustics speakers. Anyway, is my connection OK? Also, are there some difference in the rendering of the bass when a sub is connected to a 2 ch audio, not an AVR amp like the HK x54 series? Thanks a lot for your hints. Karmin.
Karmin is offline
post #2 of 10 Old 12-02-2008, 12:25 PM
ndskurfer's Avatar
Quoted: 39 Post(s)
Liked: 52
You sound fine. You only need one of the "mono" sub outs rca to rca connected to the sub. As for the trigger, don't worry about it. This is only a convenience trigger to activate the power upon powering up the receiver. I'm not too familiar with your sub, but it may have a sensor to turn the sub on when it is fed a signal or you may simply have it on at all times - don't worry about it though, you are fine.
ndskurfer is online now
post #3 of 10 Old 12-02-2008, 10:58 PM - Thread Starter
Karmin's Avatar
Thanks friend. Something I find odd though. The sub nevers turns itself off. Instead it puts inself in waiting mode, same as the HK 3490 does when I turn it off. I know now the sub is waiting for a signal to go on from the receiver. So, when I turn off the receiver, the sub puts itself in waiting mode. I know cause when it's on the "Precision Acoustics" letters turn blue and when it's on waiting mode, they turn orange. Is it something I should worry about now that I don't worry about the rest
Karmin is offline
post #4 of 10 Old 12-03-2008, 12:13 AM
Knucklehead90's Avatar
Quoted: 385 Post(s)
Liked: 333
Your sub is doing exactly as it is designed to do.
Quit worrying and enjoy the music.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #5 of 10 Old 12-03-2008, 08:52 AM - Thread Starter
Karmin's Avatar
Hi friends, thanks so much for your input. Now, let's enjoy!
K.
Karmin is offline
post #6 of 10 Old 02-21-2012, 08:33 PM
YseanY's Avatar
I hate to bring up an old thread, but after searching it seems like most subs only have a single line input. I just picked up a MartinLogan DYNBLD Dynamo from a friend and the sub has a bit of different inputs. After reading the manual (http://www.martinlogan.com/pdf/manua...ual_dynamo.pdf), it seems like to use the sub's low pass filter, I have either use the speaker level inputs or RCA L/R inputs to keep the sub's internal low pass filter active, if i use the LFE, it will bypass the sub's low pass filter. So right now, I have used RCA cables to connect both of the HK3490 sub outputs to the RCA inputs on the sub (obviously, right to right and left to left) with both speaker 1 and 2 on (I only have one pair of bookshelf connected to speaker 1). Is this correct? Or should I be using a Y splitter and only connect the L/R of the sub to the bottom sub out of the HK3490?
YseanY is offline
post #7 of 10 Old 02-25-2012, 12:55 AM
YseanY's Avatar
anyone? should i use both sub outputs on the hk3490 or should i be getting a Y splitter and only using one sub output?
YseanY is offline
post #8 of 10 Old 02-25-2012, 12:35 PM
filecat13's Avatar
Quoted: 34 Post(s)
Liked: 101
Use both RCA sub outs to your sub, L to L and R to R. They function just like full range pre outs, which is what the sub needs.
Set the 3490's LINK SW switch to ON.
Adjust your sub according to its manual. (Thumbnail below.)
If you don't have any speakers connected to Speaker 2, then turn it off. The 3490's sub outs will be active as pre outs and have nothing to do with the speaker selector, which controls which speaker outputs (1, 2, or 1 and 2) receive power from the built-in amps. If there are no speakers wired to them, then don't send power to them.
What I can afford, when I can afford it...
filecat13 is offline
post #9 of 10 Old 02-25-2012, 11:23 PM
YseanY's Avatar
Thanks! I don't have any speakers connected to speaker 2, but I noticed that if i turn them on, there is more volume/bass fed to the subwoofer, which made me wonder if I should only be connecting the subwoofer to only one of the sub outs with a Y splitter as each sub out seems to correspond to the to each speaker selection speaker. Also, if I turn off speaker 1 and leave speaker 2 on, the subwoofer is still getting signal.
YseanY is offline
post #10 of 10 Old 03-19-2012, 05:25 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
The sub will receive a signal even if you don't have any speakers connected. Or have both off.
The sub outs have nothing to do with the 1 or 2 speaker outputs.
Also with only one sub, you have to make sure its connected to the mono sub out.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
Reply 2-Channel Audio
