Check it out.
Amphony Pocket T-amp
Just wondering what you guys think? Of course the T-amp is no stranger to AVS but am wondering if this one is worth the price tag. Anyone who may have one or will soon please chime in. Im sure it would be cool enough to match up with some nice stereo speakers for music listening but what about plugging it to the stereo out of my TV. Just as a simple TV speaker setup.
Also as far as the specs go its as follows:
Technical Specifications
Output power:
Mono: 1 x 50 W (peak), 1 x 30 W (rms)
Stereo: 2 x 20 W (peak), 2 x 15 W (rms)
Dynamic range / signal-to-noise ratio:
Mono: 115 dBA
Stereo: 112 dBA
Frequency response: 1 Hz - 70 kHz @ 8 Ohms
Total harmonic distortion (THD+N):
Mono: 0.05 % @ 25 W, 1 kHz
Stereo: 0.05 % @ 10 W, 1 kHz
Power efficiency: 75 %
Channel separation: 85 dB
Idle power consumption:
Dimensions: 3-9/16 (W) x 3-7/16 (D) x 3/4 (H)
91 mm (W) x 86 mm (D) x 19 mm (H)\\
These can be found via pdf here: specs
How can it be compared to the Sonic Impact version of the T-amp. As far as Harmonic distortion and Signal to Noise Ratio it SEEMS better but what does it mean for real world performance.
Output power:
Mono: 115 dBA
Stereo: 112 dBA
