Denon DP-DJ151 Turntable - What am I doing wrong? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-25-2009, 08:11 PM - Thread Starter
moorerobt's Avatar
I picked-up a Denon DP-DJ151 digital turntable off of eBay.
The analog connection works great, but I can't get the digital output to work. It has a coax output and I have it hooked to a coax input on my Denon AVR988, but I get nothing.
What am I doing wrong? I plugged the coax cable into an input that was working with another component, so I'm at a loss.
I would be greatful for any help.
Bob
moorerobt is offline
post #2 of 3 Old 02-26-2009, 07:50 PM
Knucklehead90's Avatar
Quoted: 385 Post(s)
Liked: 332
Sounds like you need to take this issue up with your seller. They may have known it had this issue.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #3 of 3 Old 01-26-2013, 08:00 PM - Thread Starter
moorerobt's Avatar
Back from the dead!
It only took four years to figure out what I was doing wrong (And replacement of the receiver).
The DP-DJ151 has a built-in phono pre-amp for receivers that don't have a phono input. I just bought a new receiver without the phono input, so I flipped the switch on the bottom of the turntable and hooked it up with both analog and digital outputs, and low and behold the digital out was recognized-- finally success.
This turntable always sounded good, but I think the digital output has some sort of "crackle" filter; the first record I played sounded louder and didn't have that turntable noise.
Now I have to learn how to properly balance the tone arm.
Reply 2-Channel Audio
