Harman Kardon DMC1000 thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #181 of 218 Old 12-27-2010, 07:02 PM
OtherSongs's Avatar
Originally Posted by dsmith901 View Post
... The issues with the DMC1000 pale in comparision with making a PC work as a server in your listening room or hassling with noise or wireless issues, remote control, etc. Good luck.
I take it that you've never built your own PC to play stereo music?
Anyhow, maybe a few will find my thread ( "Build a Small and Quiet PC For Stereo Music" see: http://www.avsforum.com/avs-vb/showt...917&highlight= ) of some use.
BTW, several in the Home Theater Computers forum took issue with my calling it a "server" and I soon changed the title to drop that word.
FYI to all: I discovered a trick to getting GraceNotes info when it comes up zero on the initial search for the CD. In almost every instance GraceNotes will find the info on individual song titles, even if the CD itself is not located. You have to call up the CD using "Album" not "Artist," as in "Unknown Album No. 25." Then, go to see all tracks. For each track go to edit and do the search and 99% of the time it will locate the artist, album, album cover, and of course the name of the track. Often you will get more than one search hit so you need to be careful selecting the proper track info you want to save - you want all tracks ID'd from the same album. Hit "Done" and when you are taken back to the list of tracks do the same process for the newly highlighted track (the previous track will be removed). After you have completed all the tracks on the "unknown" album it will show zero tracks, so you can safely delete Unknown Album No. 25 (or whatever). Now when you search for the CD by Artist you should find it and usually (maybe not always) there will be the album cover art also.
Thank you for your above 2nd paragraph with useful followup on how to actually use the DMC1000.
Cheers
The best is the enemy of the good. Voltaire (1694-1778)
OtherSongs is offline
post #182 of 218 Old 01-03-2011, 06:12 AM
natchie's Avatar
Quoted: 28 Post(s)
Liked: 32
OtherSongs, nice thread on the DIY computer music "server" or collection. I am not sure if I can set up a dedicated computer just for this purpose, but I bought an el cheapo usb device that offers optical input and output to connect to my AVR. It's one way to do a simple connection from my laptop to AVR.
natchie is offline
post #183 of 218 Old 01-03-2011, 06:21 AM
natchie's Avatar
Quoted: 28 Post(s)
Liked: 32
DS-901,
I often resorted to using Find Information when the GraceNotes failed to provide the information. At best, it can provides the song titles from different albums, rather than an actual compilation album. And no album cover pictures!
There is one special 3-CD anniversary compilation of soundtracks and music for the Blade Runner. It identified the first CD as from the original soundtrack album, but the second CD with music not used in the movie, and the third CD with diffferent artists, are not coming up with anything.
Curious, how does your internet connection read? I wonder if the IP address has changed at the GraceNotes or if the HK's contract is up with GraceNotes, leaving us stranded?
natchie is offline
post #184 of 218 Old 01-07-2011, 06:27 PM
dRockHK's Avatar
natchie;
As far as I can tell, Gracenote access for our DMC 1000s is definitely still working. Since I have 'dug out' my unit a few weeks back, I have been using it frequently (today included) - no issues at all getting the information and cover art.
Do you still have the X'ed out internet connection test results (specifically "Web Connection") like you mentioned in this thread mid December? If so your unit does NOT have a connection to the internet / Gracenote online, and is relying solely on it's built-in database. Keep in mind, the unit's database likely only has content up to some time in 2006 or '07 - plus no cover art, only track/album ID. Cover art, or info for newer albums, must be obtained online / with a network connection.
This would explain your difficulty obtaining cover art or the correct album choices, especially considering the specific album set you are referring to was released very late in '07
Fix your connection issues, and I'm sure it will work fine.
dRockHK is offline
post #185 of 218 Old 01-09-2011, 01:38 PM
natchie's Avatar
Quoted: 28 Post(s)
Liked: 32
Originally Posted by dRockHK View Post
natchie;
Thanks for the heads up...apparently I just tried again to connect with my DSL (Verizon) box...what I don't get is that the internet is fine with my computer, videophone and wireless points. What is your recurring IP address? Mine stays with 192.168.1.37 for the first IP address...Only shows ethernet box as checked. I switched the ethernet cable that works for other devices...and still no connection. I am tempted to go back to factory restore, but I have the firmware version 04.06.04 now. Don't want to have to change that...The other option is to leave it connected and go without it next to my bed. In the past, It seemed to work when I leave it connected for over 24hours...weird.
natchie is offline
post #186 of 218 Old 01-09-2011, 03:44 PM
dRockHK's Avatar
When set to dynamic, the IP address will depend on the DHCP address range set within your router. E.G., my router's IP is 192.168.0.1 - which is the standard pre-programmed address for most D-Link routers. I have the DHCP range to go from 192.168.0.10 to .50
The IP assigned to the DMC 1000 (or any other device) by the router can be anywhere within this range and is normally assigned in order they were connected, and will normally stay the same until the router is unplugged / rebooted for whatever reason. I believe the current IP assigned to my DMC is 192.168.0.14 (it was one of the first few devices I powered up since the router was last unplugged, hence the low number to DHCP IP start range)
You can do the reset settings to factory default within setup menu to undo any changes. You don't have to worry about the firmware update, it will not be changed/lost, only the user settings (which aren't many to start with) are reset.
Without digging into any of the network settings for your router or DMC, what I would try:
Unplug DMC lan connection. Go to setup, reset factory defaults (takes no time at all). Once done, fully shut down DMC. Turn off master power switch.
Unplug router power cord, wait about 10 seconds, then reconnect. Wait for router to boot and connect.
Reconnect DMC lan connection. Turn master power switch back on.
DMC should automatically start up, but if not manually power the DMC back on (Note: On start-up, you will likely see a new IP address - good) Go to the network settings setup, make sure it is on dynamic. Use the test connection function. If you get all checks, or at least a check next to ethernet and web connection, you are good to go and can access Gracenote online
(I should note, I always get an X for DHCP - but since everything works just fine I don't care about looking into it further)
If that doesn't work, the fix will be a little more involved than just unplugging things You will probably have to change settings within the router and/or assign a static IP to the DMC.
dRockHK is offline
post #187 of 218 Old 01-10-2011, 01:22 PM
natchie's Avatar
Quoted: 28 Post(s)
Liked: 32
Hi DRockHK...apparently the dynamic IP address remained the same after following your directions: I shut down and turned on everything after two whole minutes. I might have to shut down the router all day and let that boot up cleanly....as for my DMC, this number seemed to be stuck...so will have to try again tomorrow and shut down the router while I'm at work.
Thanks for your review.
natchie is offline
post #188 of 218 Old 03-06-2011, 10:44 AM
natchie's Avatar
Quoted: 28 Post(s)
Liked: 32
Under the Advanced Network, no matter how many times, I cannot get check box for DHCP server nor the Test Web Connection.
Any CDs after 2009, is listed as unknown album etc. The GraceNote icon shows up then fades out.
I did the unplugging, turning off, plugging back, turning on...and went to DOS prompt and release and renew the ipconfig...still to no avail.
I have Verizon DSL modem (Westal) and suspect that it does not provide DNS for attached equipment...
Would getting a new DSL modem be the best solution>?
natchie is offline
post #189 of 218 Old 03-12-2011, 02:44 PM
dRockHK's Avatar
You DID try the Reset settings to factory defaults at least once during all this, right? (It only resets your settings - no content (or upgrade) is erased)
That seems ridiculous - I'd contact Verizon for information on configuring your router and/or if a 'hard' reset is possible (erasing all your existing network settings, will have to be re-configured)
Sorry I can't be of more help
dRockHK is offline
post #190 of 218 Old 10-17-2011, 03:21 PM
manny115's Avatar
has anyone found a way to change the software to store DVDs or blu rays on the HD?
manny115 is offline
post #191 of 218 Old 05-07-2013, 03:32 PM
grasshoppers's Avatar
Quoted: 861 Post(s)
Liked: 562
Just wanted to check up on DMC-1000 users and see how
Things are going. I have 2 units, one a refurb,the other a new
Unit bought on close out.
I had an issue with the refurb unit this past summer,noticed the blue
Power status light was flickering. Sure enough it wouldn't turn on.
Unit was out of warranty,but I called HK who referred me to an
Authorized service center. After they had it a few weeks they
Called me to tell me that HK did not have the parts available to
Repair my unit!!
Well, I was bummed to say the least. A few days later I noticed a
Refurb unit on eBay for sale,but, considerably more than the $150
I paid for mine. I called the repair shop and expressed my concerns
That somebody was repairing them, referencing the HK store on eBay.
The shop owner gave me an email address of a person that I should talk
To. I sent him an email explaining my situation and my willingness to
PAY for repairs. He actually called me direct and offered me what was an
Outstanding solution to my issue.
He shipped me the refurb unit at NO charge in exchange for my unit
Sitting in the repair shop. All I had to do was pay to ship my unit to HK!!
I was flabbergasted to say the least and whole heartedly accepted his
Deal.
That is GREAT customer service!
When my new unit arrived I checked it out and the HD was about half full
Of someone else's music! LOL.
If your unit fails please don't expect a similar resolution. I got very lucky
And my timing was perfect to say the least. I can't remember the last time I saw
A refurb unit available.
How you enjoyed my little story.
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is offline
post #192 of 218 Old 12-14-2013, 07:34 AM
natchie's Avatar
Quoted: 28 Post(s)
Liked: 32
GH,
THanks for sharing your story. If you can give me the contact name, that would be great. I recently saw that HK is announcing exchange program and thought about contacting them but to find the receipt of the sale at HK Audio store online is not easy...
My problem is that the internet does not work, and I suspect it is due to defective internet card/part...I don't want to lose the music on my machine...but if I can get a working model, that would be great.
Natchie
natchie is offline
post #193 of 218 Old 05-22-2014, 01:24 PM
MisterWayne's Avatar
I want to transfer the entire contents (boot data, HK programs, Music) of my DMC1000 250 GB internal hard drive to another 250 GB internal hard drive as a backup- not only for the data (music) but also in case of a hard drive failure, I could replace the bad drive with this backup drive-- Since mine is almost 4 years old.
Can anyone tell me how to do this?
grasshoppers likes this.
MisterWayne is offline
post #194 of 218 Old 05-22-2014, 03:46 PM
setter's Avatar
Cloning the hard drive using a special tool that does a byte-by-byte copy should work without wrecking the original. Do not access the DMC1000 hard rive with any computer. The tool will not access the data, just blindly copy every byte regardless is the byte has data or is blank. These tools are readily available for $25 and up. Please post your results for others to share!
setter is offline
post #195 of 218 Old 05-22-2014, 11:03 PM
The problem is that the HK DMC 1000 does NOT use windows. Per mickint, a veteran member on the site, the DCM 1000 uses QNX4.x 3rd partition. (QNX is a POSIX (Portable Operating System Interface for Unix)-certified, microkernel, distributed, fault-tolerant Operating System for the 386 and later, including support for the 386EX in embedded applications.)
How do you mirror a drive when the operating system on that drive is different than the operating system and PC you are using to perform the operation?
Any experts out there who can help?
post #196 of 218 Old 10-21-2014, 06:43 AM
setter's Avatar
I use my Aleratec HDD PortaCruiser to clone hard drives from proprietary OS systems like TiVo and Yamaha MCX-2000 as well as Mac and Windows platforms. They all work perfectly - the hard drives are identical and interchangable. These cloning machines don't care what is on the hard drive, they just copy each bit of data from one drive to another making an exact copy. The partition remains the same regardless of hard drive size. There are tools to fiddle with repairing data and changing partitions, but I never mess with them. I suspect a cloning tool like this will work on the DMC-1000.
setter is offline
post #197 of 218 Old 12-24-2014, 04:46 AM
natchie's Avatar
Quoted: 28 Post(s)
Liked: 32
Question QNX from BlackBerry to DMC 1000?
Talk about desperation! Just found a reference to the mysterious OS used with DMC-1000 from C/NET report on BlackBerry's "recovery" in smartphone business. Here is what I learned about QNX:
The operating system behind BlackBerry's latest operating system, QNX, which many people are surprised to learn powers the infotainment systems in many cars, has many compelling features.
The link is from http://www.cnet.com/news/readers-rea...tag=CAD5920658
Any hope to combine the two "dying" technologies?
natchie is offline
post #198 of 218 Old 02-04-2015, 11:23 AM
natchie's Avatar
Quoted: 28 Post(s)
Liked: 32
Well, just to report here that I am planning to use J-River software on a laptop...wondering if there is a way to move the music files from DMC 1000
to computer via J-River program...looks like it should be possible to do, but am still learning the rope with the program.
For some reason, my DMC 1000 will occasionally shift into an autistic mode, and not respond to any command via remote or player buttons. Does not even shut down unless I switch it off from the back.
I love the DMC, but am a little wary. Anyone else doing the migration to J-River?
natchie is offline
post #199 of 218 Old 10-24-2015, 01:45 PM
natchie's Avatar
Quoted: 28 Post(s)
Liked: 32
DMC 1000 on its dying bed?
Flickering Blue Light (5 seconds ON- 5 seconds OFF)...my DMC 1000 does not turn on after rebooting.
Is this the end of DMC 1000...is this the final curtain, the death thrall...bummer to the MAX! Any solution to revive this monster DMC 1000?
natchie is offline
post #200 of 218 Old 10-25-2015, 06:44 AM
Quoted: 861 Post(s)
Liked: 562
My eBay refurb unit did this also. The warranty had expired.
I sent it it for repair but parts were unavailable.
Try unplugging the unit from the wall completely for
A day and see if if you can boot it up.
Good luck!
Rythmik F12 subs
post #201 of 218 Old 10-26-2015, 08:10 AM
natchie's Avatar
Quoted: 28 Post(s)
Liked: 32
Good luck!
Hi GH! Glad to hear from you. That would be sad if there is nothing I can do...but following your advice for now and see what happen when I return home to test it out again. It was fun while it lasted...
natchie is offline
post #202 of 218 Old 10-26-2015, 08:12 AM
natchie's Avatar
Quoted: 28 Post(s)
Liked: 32
Hi GHpper,
I was afraid to hear that it might be kaput! Thanks for letting me know...I powered it off for now. See what happen when I get home.
In the meantime, will have to learn more about the new database, J something.
Cheers,
Tony
natchie is offline
post #203 of 218 Old 10-26-2015, 04:53 PM
Quoted: 861 Post(s)
Liked: 562
Hi GHpper,
Cheers,
Tony
Let me know what happens. One of the
Guys that owns one PM'd me asking if
I was interested in buying his unit for $300.
He posted a lot in this thread. If your interested
And with his permission I could forward that msg
To you.
'JRiver' ...nice product.
Rythmik F12 subs
post #204 of 218 Old 10-29-2015, 02:38 PM
natchie's Avatar
Quoted: 28 Post(s)
Liked: 32
Ghopper,
GOod news! Followed your suggestion and left it unplugged for three days...replugged it and had to wait awhile, but no blinking light...but also no action...impatient I turned it off and on and somehow later, I saw the start up and felt hopeful...sure enough, eventually the system worked.
Not sure what would explain this but also wondering if it's a sign of digital mortality here
Many thanks for restoring my faith...
natchie is offline
post #205 of 218 Old 10-29-2015, 05:01 PM
Quoted: 861 Post(s)
Liked: 562
Ghopper,
That's great. My eBay refurb unit is sometimes exhibiting
Very slow start up.
I don't use it everyday..maybe a couple of times a week
If that. What I do is power the unit down completely using
The remote control. When I see the dim blue light I power
It down using the master power switch on the back. I then
Unplug the unit from the wall.
To power it on I plug it in, and then hit the master power
Switch on the back. It then usually fires right up.
I've been ripping my CD's to a Mac Mini as a back up
If my dmc bites it. Looking at JRiver too.
I also have a Yamaha CDR-HD1500 with all my music
Stored on it. The GUI isn't near as nice as the HK's though.
http://usa.yamaha.com/products/audio...1500_black__u/
Rythmik F12 subs
post #206 of 218 Old 02-04-2016, 06:16 AM
natchie's Avatar
Quoted: 28 Post(s)
Liked: 32
All solemn now...(Playing Tap)
My ol' DMC 1000 ain't powering up anymore. Out of patience, I opened the top of the case, and fiddled around, looking for anything obvious...saw a cracked capacity near the power and pushed it together...no luck. Switched the circuit board battery from a nearby computer's board, and whoa! the light came back on...but that was all. It did not move past the initial announcement of self identity: DMC 1000. Remote did its best to communicate but nothing. Unplugged and then plugged the beast a few times in an ER mode, but alas, no life afterward.
I wish there was a place to swap out the power supply, as I am sure it is mostly related to it.
How else can I salvage the hard drive coded in that weird proprietary Unix-derived language...bummer.
Thank you for the viewing....
natchie is offline
post #207 of 218 Old 02-04-2016, 02:22 PM
Quoted: 861 Post(s)
Liked: 562
Sorry to hear about your mis-fortune.
You should look at getting a Mac-Mini and filling
It up with music. You can use iTunes (of course)
Or Jriver for the Mac.
natchie likes this.
Rythmik F12 subs
post #208 of 218 Old 02-05-2016, 06:50 AM
natchie's Avatar
Quoted: 28 Post(s)
Liked: 32
Hi G-Hopper!
Thanks for your help in the past and support for now. Yeah , I am reviewing my options and one of them is to fill up my new refurbished HP desktop with songs and videos. Will switch in my ASUS PCI Xonor card Express soundcard from my ol' dying computer now croaking. But the soundcard is PHENOMENAL with my K701 headphones.
Keep in touch!
Natchie
natchie is offline
post #209 of 218 Old 01-19-2017, 07:21 AM
manerac's Avatar
In case anyone else out there is still trying to keep their DMC1000 alive:
When my power supply died recently I replaced it with a Mini ITX computer supply (FSP Group FSP270-60LE) I picked up for ~$10 on ebay. I had to remove the supply from the case, and it took a bit of hacking to fit it in the DMC case, but it did the trick.
Also, the remote control had stopped working a while before the supply died. While I had it apart I probed the IR sensor with an o-scope while pressing the remote buttons and saw no response. Then I wiped the sensor off and it started working. I'm pretty sure I removed a tin whisker growing from the IR sensor frame to one of the terminals. I coated the terminals with nail polish for insurance.
John
natchie and grasshoppers like this.
manerac is offline
post #210 of 218 Old 07-11-2017, 07:56 PM
Liked: 0
Harman Kardon DMC 1000 - Power Supply Module Issue
Hi. I know this is an older unit, but I have to ask. Does ANYONE here know where I can get replacement power supply modules for the HK DMC 1000 units? I have two DMC 1000's and they have both failed after serving me faithfully for a few years. The culprit - burnt power supply module.
I have auditioned other Digital Media Centers, but came away dissatisfied with the sound, as well as the cosmetic look. What I liked so much about the HK DMC 1000 units were the richness of the midrange... a "bloom" in just the right frequencies to give it a rich, almost buttery tube-like output that I can't seem to find in other units under $2000. It was also a very "pretty" unit and I fell in love with the DMC 1000 acoustically as well as visually.
I would really prefer to locate and replace the power supply modules (maybe even rebuild them if possible?) then purchase another unit. Yes, I know the HDD is only 250GB, but that is okay by me as I can add external HDD through the USB ports.
Any help would be greatly appreciated.
BizmanJoe is offline
Reply 2-Channel Audio
