Denon PRA-1100 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-11-2009, 11:07 PM - Thread Starter
mrevo's Avatar
Hi,
I just got a Denon POA-2200 and a PRA-1100
I'm happy with the sound, but want to get the PRA-1100 manual to get some ideas on my connection options.
Can anyone help?
MR
I'm eager to make things better, sound better and perform better.
mrevo is offline
post #2 of 7 Old 12-20-2009, 04:39 PM - Thread Starter
mrevo's Avatar
Hi
Dear fellow audiophiles,
After a long search, I have the manuals for both of the units I just mentioned.
If you need an answer for any of the installation or settings let me know.
MR
mrevo is offline
post #3 of 7 Old 12-27-2010, 02:15 PM
smokinone's Avatar
Would it possible to get a scan of your manual for the PRA-1100? I'm looking to get one but the seller has no manual. Thanks
smokinone is offline
post #4 of 7 Old 01-06-2011, 09:33 AM - Thread Starter
mrevo's Avatar
Hi I PM'ed you...
mrevo is offline
post #5 of 7 Old 09-09-2013, 06:37 PM
Gwalters's Avatar
I know your post was a couple of years ago, but I have a friend with the Denon PRA1100 and the POA2200 and he's looking for the manuals and having great difficulty. Is there a chance you would still have them ? Thanks
Gwalters is offline
post #6 of 7 Old 09-10-2013, 03:52 PM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1142
^^ try HiFi Engine.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #7 of 7 Old 09-12-2013, 07:54 PM
Brownstone322's Avatar
Quoted: 42 Post(s)
Liked: 108
This is of no value to you, but my first reaction was, "Wow, I used to own a PRA-1100!"
Alas, not true. I thought about it for a while, and I recalled that I actually owned a PRA-1500, which included balanced outputs that I never used. I mated the Denon preamp with a classic Adcom GFA-555 power amp, and that was the heart of my two-channel system for 14 years. That gear -- at a very reasonable price -- was and is as good as any two-channel electronics made by anybody. I miss it.
Brownstone322 is offline
Reply 2-Channel Audio
