WOW.... What a difference in Amps!! - Page 23 - AVS Forum | Home Theater Discussions And Reviews
post #661 of 664 Old 01-09-2010, 06:18 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
Originally Posted by edwyun View Post
+1
If you change you PS capacitors around after 10 years or so, a SS amp should be good for a real long time, especially with amps that have a conservative design.
Generally not needed. I've checked a ton of SS amps that were 20 or more years old that still meet origional spec for 20 Hz power, which is a good way to evaluate PS caps.
For example, the Pass SA4 that I mentioned in a previous post showed absolutely no deterioration of the power supply caps in bench tests. I believe the build date was more than 15 years ago.
arnyk is offline
post #662 of 664 Old 01-10-2010, 09:27 AM
RWetmore's Avatar
Quoted: 364 Post(s)
Liked: 202
That's interesting. I wouldn't have guessed they would last that long.
RWetmore is online now
post #663 of 664 Old 01-10-2010, 07:16 PM
edwyun's Avatar
i believe nelson pass recommends 10-15 years. i would change before they "pop". my SA4/e and 3.9/e were changed at about 13 years. i did notice an improvement (though some other parts were changed as well as the caps).
edwyun is offline
post #664 of 664 Old 01-14-2010, 02:37 AM
Veda's Avatar
Quoted: 124 Post(s)
Liked: 90
Originally Posted by A9X-308 View Post
Well simply buy a Pro amp. Well made if usually not pretty and tons of power for modest $. There has been very little 'new technology' in AB1 amp designs for ages. The only possibility for the future is probably class D.
Pro amps are cool but ugly as hell and not Class D which is what I'm into. Still waiting for NAD M2's tech to become way cheaper...
Veda is offline
Reply 2-Channel Audio
