Let's see pics of your stereo setup! - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 2918Likes
post #331 of 2639 Old 07-24-2011, 06:04 PM
kevinzoe's Avatar
Originally Posted by FOH View Post
Very, very nice.
I know we've corresponded via threads and PM, and discussed many things, however you're attention to all detailed aspects in your particular room is impressive. I'm particularly interested in the angled, redirected lateral reflection points. Typically, I prefer and recommend attenuation of ceiling energy between mains and the LP if appropriate, as I've found it tends to obfuscate some detail via smearing. However in your scenario, with the side panels redirecting lateral energy upward, I can see the interest in additional diffusion. Bottom line, I'd very much enjoy hearing your system in the environment you've created.
Also, as a fellow OmniMic user, I'm interested in your opinion of it.
Thanks and again, love the space.
Hello FOH! Nice to hear from you again, and thanks for your kind words. After having the room designed and built, I was appalled with how a bare room with only wall-to-wall carpet sounded despite having some pretty decent gear. That was the impetus for self-learning and study of small room physics/acoustics over the past several years. I caught the DIY bug and looked to design diffusers and bass traps that exceeded what was commercially available, at a considerable cost savings. My communications with Drs Sean Olive and Trevor Cox really were incredibly helpful.
Regarding the side wall reflective baffles, I built them to eliminate the flutter echo between the side walls, at the same time as likely reducing comb filtering of mid to lower frequencies. I plan on using OmniMic's Frequency, Impulse Response, and Reverb/Bass Decay charts to optimize what angles each row of baffles should be at. I'll try 20, 30 and 40 degrees for starters which gives me 27 different combinations to evaluate. This shouldn't take too long given that last week I took 99 measurements over two hours for all possible sub location combinations using my pair of subs. As you can see from the pictures, I'm using diffusion at ear level on the side wall first reflection points as I found that (i)reflection offered the best 'liveliness' but caused a reduction of musical details, and (ii)absorption sounded a bit unnatural but offered the best musical detail recovery, and (iii)diffusion was very close behind absorption for musical detail recovery but still offered the liveliness of reflection alone - kind of the best of both of the other two tools.
OmniMic is a terrific tool - very user friendly and offers the right amount of technical analysis for me for now. I'm still getting the hang of all its features. I don't particularily like its Reverb chart where you have to click along the decay trail to get a RT60 reading for a user specified frequency range. I would rather see a histogram (bar chart) with freq on the x-axis and time on the y-axis for easier comparison across the frequency bandwidth. Also, as RT60 isn't applicable to domestic rooms, I'd rather see an RT20 or RT30 calculation instead.
Now how about sharing some photos of your man cave?!
Cheers,
kevin
kevinzoe is offline
post #332 of 2639 Old 07-24-2011, 06:12 PM
dhoff01's Avatar
Liked: 24
Posted these elsewhere, but what the heck. Here's a few of my office space...
dhoff01 is offline
post #333 of 2639 Old 07-24-2011, 06:19 PM
kevinzoe's Avatar
Hey, I recognize that pooch. Looks like a nice work environment. I like the look of your main listening room too, although I might be tempted for a few more acoustical room treatments but that's just my obsesiveness. Enjoy!
kevinzoe is offline
post #334 of 2639 Old 07-24-2011, 06:26 PM
dhoff01's Avatar
Liked: 24
Thanks Kevin. Always been impressed with your listening space. I'll probably add some treatments to my own eventually, but for now all my dough is going to my record collection.
Enjoy your room as well!
dhoff01 is offline
post #335 of 2639 Old 08-13-2011, 07:49 AM
Rinkledorf's Avatar
Here's a few shots of my 2 channel setup. I incorporated it into my HT.
abatsky likes this.
Rinkledorf is offline
post #336 of 2639 Old 08-15-2011, 06:39 PM
kevinzoe's Avatar
Nice Revel gear Rickledorf. What make/model of subs are you using as they don't appear to be Revel stuff (I could very well be wrong)? Nice absorbers on the walls if that's what they are. Have you (thicker) bass traps also? Nice room. Enjoy.
kevinzoe is offline
post #337 of 2639 Old 08-16-2011, 05:54 PM
Rinkledorf's Avatar
Thanks Kevin. The subs are Paradigm PW-2200's. Next upgrade. Yes, they are absorptive panels. But no bass traps. I wanted to put corner traps in but my HT gear cabinet is in the right corner. Maybe I'll figure something out.
post #338 of 2639 Old 08-16-2011, 07:03 PM
kevinzoe's Avatar
Rinkledorf - good luck on the sub replacement; there are many good internet-direct companies now from which to choose. I use Rythmik so am partial to them for their musicallity. Regarding the DIY absorptive panels, bass trap potential and how to figure something out, I'd highly recommend Dr Floyd Toole's book. It's a great education and primer on room acoustics that should help you, if you're interested.
http://www.amazon.com/Sound-Reproduc...3546625&sr=1-1
kevinzoe is offline
post #339 of 2639 Old 08-17-2011, 03:37 AM
Weasel9992's Avatar
As Ethan Winer often points out, there are twelve corners in a room, not just four. The vertical corners are slightly more preferable, but trapping any of them will deliver positive results. You could also use 4" or 6" panels on the walls as well. Lots of options.
Frank Oesterheld
Weasel9992 is offline
post #340 of 2639 Old 08-18-2011, 11:35 AM
petechman1's Avatar
A little project thats been in the works for about 5 months:
Old but very good:
And my theater setup (or PC speakers, take your pic):
BufordTJustice likes this.
petechman1 is offline
post #341 of 2639 Old 08-18-2011, 04:43 PM
Rutgar's Avatar
I like the music server. What software are you using?
I just set up a Mac Book Pro, running Amarra and using an iPad 2 with Apple Remote just this week.
Rutgar is offline
post #342 of 2639 Old 08-18-2011, 05:34 PM
kevinzoe's Avatar
Rutgar,
Nice! What DAC are you feeding with your Mac Book Pro? Are you using its Firewire or USB outputs to connect to the DAC? Did you consider PureMusic rather than Amarra by chance? I've heard that it's less costly and just as good or better . . . just an idea as I know Amarra is very good.
Enjoy!
kevinzoe is offline
post #343 of 2639 Old 08-18-2011, 05:53 PM
Rutgar's Avatar
Rutgar,
Enjoy!
Hi Kevin.
I am using the DAC in my Playback Designs MPS-5, with thier proprietary USB-X external interface:
I did consider Pure Music (mainly because of price), but a friend of mine was already using Amarra with a MacBook Pro, and was able to help me get it all together. So being a novice in this area, I stuck with his advice. So far though, I'm very happy with the setup. It's almost 'too' easy being able to select any song from any album (that I have loaded), and not have to move one inch from my listening chair!
Rutgar is offline
post #344 of 2639 Old 08-21-2011, 01:18 AM
terry j's Avatar
kevin..nice room BTW, love that you use diffusion.
How high are the ceilings?? It looks lowish (esp when covered with diffusors) but that could be in part to the camera.
terry j is offline
post #345 of 2639 Old 08-21-2011, 04:12 AM
kevinzoe's Avatar
Hi Terry,
Thank you for your compliments. Diffusion was very much front and centre in my acoustical room treatment strategy, and the ability to try some DIY construction was a great learning experience.
The ceiling is only 7feet as it's a room in our basement, so yes it is kind of lowish. I use ceiling diffusion to help raise the apparent ceiling height which is helped by the upward angled side wall baffles that reflect sound upward to the ceiling diffusers.
Have you pictures of your room to share with us?
kevinzoe is offline
post #346 of 2639 Old 08-21-2011, 05:52 AM
terry j's Avatar
thanks kevin. seven foot is kinda low (not concerned about sound, I'll take your word for that) but now am curious about approval from the authorities on one that low!
ATM I only show pics of my room when I want to get laughs!
And it works haha. I am very much in the opposite camp from you, my ceilings are seventeen feet high!
Solid brick walls, so very reflective and a lot of slap echo. So to tame that (initially as an experiment..now so damned successful it is a stop gap measure till renovation) I just threw f/glass batts on the walls.
Massive massive improvement.
Oh what the heck,. may as well have a few laughs eh?
As the room is so big, only a partial shot, but enough to show how cheap, quick and easy it can be to experiment
Whilst I have that page open, and seein as how you are into diffusion, here are some diffusors I have built along the way.
first a 2d qrd, standing behind the LP
Don't use that now, moved on to 2d PRDs of my own design (well, manufacture I guess, the maths stay the same)
That was my test one, don't think I have any pics of the current ones.
DIY speakers (active four way plus a pair of subs)
Did not intend to hijack your post, but what the heck eh? Once I was there may as well.
So, the room has to be renoed and completed. Will have more bass trapping, plus huge frickin diffusors of the prd design!
terry j is offline
post #347 of 2639 Old 08-27-2011, 06:14 AM
ctantra's Avatar
I set up this system couple years ago, here is the list of components:
Main Components
Lindemann D680
Audio Research Reference Two
GamuT D 200 MK3
Usher BE-718
Richard Gray's RGPC 600S
Speaker Cables and Interconnects
Audioquest Extreme Clear
Tara Labs THE ONE
Tara Labs RSC Air 1
Power Cords
Cardas Golden Reference
Marigo Resolution
Marigo RMX Reference C Prime
Miscellaneous
Lovan Sovereign "T" Hifi
Shun Mook Mpingo
Shun Mook Power Amp Base
Soundcare SuperSpike
Harmonix TU-303EX
Harmonix TU-210ZX "Golden Toe"
Cable Tower DIY
This is my bedroom "ghetto" 2 Channels setup, how do you like it?
Playstation 1 SCPH-1001
Primaluna Prologue One
Avenue Acoustic Signature One
IXOS Gamma Audition II Interconnect
Nordost Blue Heaven Speaker Cable
OEM Power Cable
tdogroeder and abatsky like this.
ctantra is offline
post #348 of 2639 Old 09-02-2011, 11:46 AM
Jazzer's Avatar
Sorry for the mess
abatsky likes this.
Jazzer is offline
post #349 of 2639 Old 09-04-2011, 03:58 AM
kevinzoe's Avatar
Ctantra,
Nice looking room, lighting, and of course equipment! I see that you're using a computer media server elsewhere in your home - why not for your 2channel setup? I also like what looks to be a poly diffuser that I'll guess is filled with fiberglass to act as a bass trap in each of your front wall corners. And of course the curtains add as high freq absorption - do you find that the front wall curtains deepen the apparent sound stage depth? Great pictures! Enjoy!
Main Components
Lindemann D680
GamuT D 200 MK3
Usher BE-718
Tara Labs THE ONE
Tara Labs RSC Air 1
Power Cords
Marigo Resolution
Miscellaneous
Shun Mook Mpingo
Harmonix TU-303EX
Cable Tower DIY
abatsky likes this.
kevinzoe is offline
post #350 of 2639 Old 09-04-2011, 04:06 AM
kevinzoe's Avatar
Bonjour MrAcoustat,
Wow are those ever tall speakers (or you're really short . . .)! I bet they cast a great soundstage. Love the looks of the Chord gear - looks like audio jewelery!
I see you're a fellow Canuck - did you make it to the Son & L'Image show in April or the Montreal Jazz festival this summer? Happy listening.
Originally Posted by MrAcoustat View Post
Here is my Keep It Simple system.
PS: You may also see pictures of the making of my Acoustat 1+1 all steel frame speakers in my Flickr galery. http://www.flickr.com/photos/mracoustat/
Chord CPM-2600 integrated amplifier
Chord One Cd player
Acoustat 1+1 Speakers ( 1984 ) modified
DIY Audio Rack
kevinzoe is offline
post #351 of 2639 Old 09-04-2011, 04:10 AM
kevinzoe's Avatar
Jazzer - what an impressive music collection! Looks like your 'mess' is screaming to be copied to a hard drive to reduce the amount of dusting you have to do I've heard great things about your speakers so congrats on owning them. I bet it's kind of hard to view the fire in your fireplace with all that expensive gear in front of it . . .ha ha
Originally Posted by Jazzer View Post
Sorry for the mess
kevinzoe is offline
post #352 of 2639 Old 09-04-2011, 06:45 PM
Jazzer's Avatar
Thanks for your comments.
The real mess is behind the left speaker
Jazzer is offline
post #353 of 2639 Old 09-13-2011, 04:18 PM
Videoz's Avatar
Quoted: 62 Post(s)
Liked: 30
Thanks for all the pics everyone. Seriously nice systems, but after reading all 12 pages I see no mention of Audio Research, ProAc(loudspeakers)or Theta which is what I have. Even though I can't post pics I'm hoping I can list all of my components.
What say you. Can I list my gear???
Bob (Retired)
__________________
Samsung UN55H8000 TS02
Dish VIP-211K
Sony BDP-S6200
Videoz is offline
post #354 of 2639 Old 09-15-2011, 02:35 PM
brianle's Avatar
Here is mine simple setup
Rodrigues_Brazil likes this.
brianle is offline
post #355 of 2639 Old 09-15-2011, 04:27 PM
coolsax's Avatar
gorgeous and simple.. what are those speakers?
coolsax is offline
post #356 of 2639 Old 09-15-2011, 08:43 PM
brianle's Avatar
Thanks. Those are the Usher Mini Dancer 2
brianle is offline
post #357 of 2639 Old 09-19-2011, 02:43 AM
ThaiBoxing101's Avatar
Hi all,
I'm up to about version 2.2 of my music room acoustical treatments and the gear is as follows:
* old crumby Sony 5 disk CD player
* Lightspeed Attenuator (fabulous passive preamp from Australia)
* Art Audio PX25 SET amp (6watts/ch.)
* FAB Audio Model 1 (97dB efficient left/right main speakers)
* Two Rythmik Audio F15 subs (15" aluminum drivers, 370watts Class A/B each, servo controlled)
* OmniMic acoustical measurement tool
* TG Audio interconnects and speaker cables; Audience power cords
Acoustical treatment strategy: diffuse and/or reflect mid/high frequencies to maintain sense of 'liveliness', and absorb low frequencies. Have invested in RPG Skylines (ceiling) and GIK Tri-Traps and Monster Bass Traps and their D1 diffusers. Have built several curved hemi-cylindrical diffusers that double as bass traps and also a largeish Skyline diffuser using wooden 2"*2"'s. Have built reflective side wall baffles that open-close betweeen 0-90 degrees and have three rows of them on each side wall so that different ones can be opened different amounts. Many hours of thought, design, and trial and error.
Hello everyone. I loved everything I've seen so far, but Kevin's diligence took the cake for me.
I'll upload only a few pics at first. Mains are a set of unfinished Milton-Bailes T103TTLs. Currently run with a TP-30. Shortly the Firestone ILTW DAC will be in line before the DCT-100 and TP-21 (to test the two amps). Searching for a Constantine DAC.
Last two pics are shown when I was testing the T103TTLs against the T166RLHs.
More will come later.
ThaiBoxing101 is offline
post #358 of 2639 Old 09-20-2011, 05:36 PM
kevinzoe's Avatar
Thank you for the kind words Thaiboxer. Your room is about 50% of the sound so why not treat it appropriately?! Most interesting speakers. I'm not familiar with them - are they using a Fostex full-range driver? Will you be using subs too? I see that was your first post to AVS so welcome!
kevinzoe is offline
post #359 of 2639 Old 09-20-2011, 08:36 PM
ADiSKOTEC's Avatar
I like your bulldog. I want to get one after I move.
ADiSKOTEC is offline
post #360 of 2639 Old 09-20-2011, 08:38 PM
ADiSKOTEC's Avatar
Holy massive speakers batman!
Reply 2-Channel Audio
Arcam , Auralex , B W , Denon , Emotiva Xpa 2 Stereo Power Amplifier , Infinity , Kef Ls50 2 Way Speaker System , Marantz , Mcintosh Labs , Nad , nikko , Onkyo Tx Nr807 , Pioneer , Polk Audio , Polk Audio Rti A9 Floorstanding Speaker , Psb , Rega , Sansui , Sonos , Sonus Faber , Velodyne , Vienna Acoustics
