Let's see pics of your stereo setup! - Page 49 - AVS Forum | Home Theater Discussions And Reviews
 3106Likes
post #1441 of 2740 Old 01-17-2016, 01:59 PM
Tharbamar's Avatar
Quoted: 29 Post(s)
Liked: 47
Originally Posted by bgtighe23 View Post
Have you shown her the Art Panels from ATS/GIK?
http://www.atsacoustics.com/ATS-art-...ic-panels.html
Those are very nice, Now I can have something that both of us be happy with.
Thank you so much.
Tharbamar is offline
post #1442 of 2740 Old 01-17-2016, 02:45 PM
bgtighe23's Avatar
Quoted: 1640 Post(s)
Liked: 949
Thank you so much.
Sure thing. You are able to use any picture you like and they can turn that into an Acoustic panel.
_____ _____ _____ _____ _____ _____ _____ _____
Receiver : Denon x5200
Front Stage : Martin Logan Motion 60XTs/Elac Debut F5 Center
Surround Speakers : HTD Level 2 and 3 Towers
Subwooferage : Dual UM-18s/6 SI HT18s
Born in 1995 and still continuing my HT journey
bgtighe23 is offline
post #1443 of 2740 Old 01-17-2016, 03:02 PM
ambesolman's Avatar
Quoted: 1098 Post(s)
Liked: 921
Many of us here have had great results going the DIY route for the same thing and much cheaper. @nickbuol has also helped folks with image editing.
http://www.avsforum.com/forum/19-ded...1316623?page=1
Sent using Tapatalk since the mobile version is still
ambesolman is offline
post #1444 of 2740 Old 01-17-2016, 03:46 PM
Tharbamar's Avatar
Quoted: 29 Post(s)
Liked: 47
Awesome!! I will be doing the thing as I love DIY and I do have some nice images.
Thank you.
post #1445 of 2740 Old 01-17-2016, 06:52 PM
polbit's Avatar
Quoted: 39 Post(s)
Liked: 30
Originally Posted by justthinking View Post
Thank you for the reply, I am about to order some treatment from GIK and will have my room treated very similar to yours
(the main difference is shutter blinds windows are on rear wall for me so I can only treat front wall with 244)
I am debating between stacking tri trap or soffitt..
Big fan of GIK myself. Their tri traps and 244 traps look great, but foremost they really make a big difference is sound, and for the money, they can't be beat. I have a dedicated, treated room for the first time in my life, and WOW. What a difference. All I have is a "cheap" pair speakers for $1.5k, and they sound amazing. The sound stage and clarity are just superb now. Every time I sit down and listen to music now, I loose track of time.
B&W 683 S2 Front Speakers
SVS SB2000 Subs
Marantz SR6010 Receiver
Pro-Ject Debut Carbon Esprit SB turntable
Onkyo DX-390B CD Changer
polbit is offline
post #1446 of 2740 Old 01-17-2016, 08:24 PM
ceptorman's Avatar
Quoted: 317 Post(s)
Liked: 473
It's nice to relax to good sounds and lose time.
polbit and dashpuppy like this.
650cc on the track
1000 cc on the street
800cc on the snow
ceptorman is offline
post #1447 of 2740 Old 01-17-2016, 08:26 PM
dashpuppy's Avatar
Quoted: 408 Post(s)
Liked: 241
Did that once, lost track of time, and had to call customer and book the call for the next day :P
azz7686 and ceptorman like this.
dashpuppy is offline
post #1448 of 2740 Old 01-17-2016, 08:44 PM
IntelliVolume's Avatar
Quoted: 1487 Post(s)
Liked: 701
Sat down just now with a recently dusted-off (and thoroughly-cleaned, with mild dish soap and water) two-LP set from circa 1990, Phil Collins: Serious Hits...LIVE! as seen here:
Funny enough, even with a good, deep soap-and-water cleaning, these records still sounded shrill, sibilant and almost unlistenable (with regard to, specifically, the last tracks on each side); I don't recall these LPs ever sounding this poor (I bought the album brand-new back in '90), with end-of-side tracks like "Separate Lives" coming across particularly harsh on the vocals...
Still, it was a nice listening session, if definitely bested by my sit-down with the freshly remastered (and awesome-sounding) Def Leppard: Rock of Ages the Definitive Collection CD....
IntelliVolume is offline
post #1449 of 2740 Old 01-18-2016, 05:43 AM
MATT0404's Avatar
Quoted: 31 Post(s)
Liked: 115
McIntosh C32 Preamp
Adcom GFA-555 Amp
Dahlquist DQ-10's
Monitor Audio ASW-210 Sub
Great sounding combo.
McIntosh C32 by Matt Krepp, on Flickr
MATT0404 is offline
post #1450 of 2740 Old 01-18-2016, 06:27 AM
ceptorman's Avatar
Quoted: 317 Post(s)
Liked: 473
^^Very nice^^
650cc on the track
800cc on the snow
post #1451 of 2740 Old 01-20-2016, 12:44 PM
Here is my Marantz system with Monitor Audio Bronze 2's. As you can see the room is packed & limited on space so I had few options as to where to mount the Bronze 2's. Additionally, the listening position is 16' away and the speakers are set 14' apart and mounted 77" from the floor to the top of the speakers. For a couple of weeks I played around with speaker positioning as much as possible until I settled on where they are currently mounted.
I am very happy with this setup! To get the down angle and toe-in set, I was only able to compare the sound of this positioning to the 8' triangle positioning that would normally be ideal for this setup. With eyes closed, imaging is nearly perfect with vocals coming from the center. The Marantz PM8005 pushes the sound to the deep parts of the room and sounds very similar to the 8' triangle requiring a touch more volume to do so.
Since the speakers were mounted so close to the sidewalls to get proper imaging, I was getting some slight bass booming that was rectified with the included Bungs. In addition, I'm using an SVS SB-2000 sub in the rear left corner of the room. This pairs nicely with the Bronze 2's and helps produce a nice soundstage especially since the bungs reduce some bass.
I am impressed with the Bronze 2's since the soundstage and imaging is great considering how far apart they are. Also, break-in is a must. They sounded thin and I was disappointed with them until they reached about 100 hrs.
TronPlayer is offline
post #1452 of 2740 Old 01-20-2016, 12:51 PM
ambesolman's Avatar
Liked: 921
@TronPlayer
Nice setup, really digging the Lego metropolis you've built too.
polbit and TronPlayer like this.
post #1453 of 2740 Old 01-20-2016, 01:14 PM
johnofarch14's Avatar
Quoted: 24 Post(s)
Send a message via Skype™ to johnofarch14
Very nice! And cool lego collection.
Man Cave setup:
65" Wall mounted Samsung smart 3d tv; Pioneer Elite VSX-80 AVR; Sony PS3 Bluray player; 2 Klipsch RF-35 L/R floor standing; 1 Klipsch RC-62 ii Center; 2 Klipsch R-14m front heights; 2 Klipsch R-14m surround back; 2 Klipsch R-14s surround sides; 12" Mirage FRX-S12 subwoofer; 12" Klipsch Sub12 subwoofer
johnofarch14 is offline
post #1454 of 2740 Old 01-20-2016, 04:22 PM
Pacodutaco's Avatar
Quoted: 365 Post(s)
Liked: 1836
Nice setup. What model are the three Marantz units and the Turntable? I see the Marantz PM8005 Integrated Amplifier but I can't tell what the other units are. Oh, nice choice in speakers too. I love the Bronze 2 line.
Marantz PM5005 Integrated Amplifier | Marantz CD5005 Compact Disc Player | Music Hall USB-1 Turntable | Onkyo TA-R240 Cassette Tape Player
Monitor Audio Bronze BX2 Bookshelf Speakers | Audio Technica AT95e MM Cartridge | AudioQuest Evergreen Interconnects
"My CD's don't earn interest...they play sweet music."
Pacodutaco is offline
post #1455 of 2740 Old 01-20-2016, 04:57 PM
Liked: 701
Unless I'm mistaken, Paco, the turntable is an Audio-Technica AT-LP1240 (I have its little brother, the AT-LP120 ).
post #1456 of 2740 Old 01-20-2016, 05:06 PM
Liked: 701
Like everyone else has said, nice Marantz gear; I, too, am rocking one of their components in my two-channel system, one of the last CD changers they made, the CC-4001.
Is that an SACD or CD player? And is the turntable an Audio-Technica AT-LP1240-USB?
post #1457 of 2740 Old 01-20-2016, 07:29 PM
Quoted: 24 Post(s)
My cheapo 2.1 mancave setup. 60% music, 40% karaoke.
JBL CST55 and a 10" boston subwoofer
Pioneer cd player
Audio technica TT
Magic sing karaoke system
Pyle receiver with a microphone input for my sennheiser mics for karaoke.
Those Klipsch 9.1 speakers are for my movie time and a pioneer elite receiver.
Man Cave setup:
post #1458 of 2740 Old 01-20-2016, 09:09 PM
postrokfan's Avatar
Quoted: 602 Post(s)
Liked: 3648
Nice setup Tron. You should probably have the PM8005 at the top of that stack for sufficient ventilation.
Blacklightning likes this.
Eastern Shore Audio Collective-E.S.A.C. Member, www.esac.club
postrokfan is offline
post #1459 of 2740 Old 01-20-2016, 09:31 PM
The turntable is an Audio Technica AT-LP1240. I think it sounds fantastic. I had the vintage wood Pioneer PL-570 and the AT sounds better in every way. The unit on top is the NA6005 Network player. I'm still working out the kinks on it and the only remaining issue is that I have to do a factory reset every few days or Spotify Connect & Airplay quit working.
post #1460 of 2740 Old 01-20-2016, 09:33 PM
Liked: 701
Pioneer cd player
Audio technica TT
I have the same turntable, the AT-LP120-USB...
What are you tracking your AT95E at?
post #1461 of 2740 Old 01-20-2016, 09:35 PM
Liked: 701
The turntable is an Audio Technica AT-LP1240. I think it sounds fantastic. I had a Pioneer PL-570 and the AT sounds better in every way. The unit on top is the NA6005 Network player. I'm still working out the kinks on it and the only remaining issue is that I have to do a factory reset every few days or Spotify Connect & Airplay quit working.
Knew it was the 1240...
I have its little brother, the AT-LP120...
What cart are you running on the 1240?
post #1462 of 2740 Old 01-20-2016, 09:36 PM
It's the CD6005 (CD only). I was contemplating getting the SA8005 for SACD playback. The reason I didn't is because I have a fairly decent CD collection and I knew that once I start listening to SACD's my CD collection would seem inferior. For now, the CD6005 makes my current CD collection sound better than I've ever heard them. Maybe down the road I'll think about SACD again.
Besides, eventually Spotify, Apple Music, etc will have SACD quality. It's only a matter of time
IntelliVolume likes this.
post #1463 of 2740 Old 01-21-2016, 02:22 AM
Quoted: 24 Post(s)
It's a pretty well known entry level TT. works great and it sounds good. Haha.Been playing journey lps lately. Planning on upgrading my cart do you know where to look for the best cart for our TT?
Man Cave setup:
post #1464 of 2740 Old 01-21-2016, 08:45 AM
bgtighe23's Avatar
Liked: 949
I'll go ahead and delete the pictures for the quote
So legos, a 2000 series SVS sub, and no issues?
Those legos wouldn't survive a song in some of the rooms on this forum
post #1465 of 2740 Old 01-21-2016, 09:33 AM
Wink
The Legos survive just fine! The MEGA BLOKS on the other hand crumble at the lowest of volumes.
TheNightwisher likes this.
post #1466 of 2740 Old 01-21-2016, 01:22 PM
Liked: 701
Indeed; though I wouldn't necessarily classify it as "true entry level" -- there are plenty of others in this realm that I would deem much less worthy than the AT-LP120, including the Ions and Crosleys of the world...
I have Journey's Greatest Hits on vinyl...the sticker is still on the wrapper around the LP jacket...
I plan on upgrading the stock AT95E soon as well, due to excessive inner groove distortion and other issues; from what I understand, the Audio-Technica 440MLa is a great replacement,
post #1467 of 2740 Old 01-21-2016, 01:24 PM
Liked: 701
Indeed, Marantz has been known for making some good all around CD players. My changer has given me issues with regard to recognizing discs and not keeping a multi-disc programming order (very annoying when I'm trying to make my own mixed compilation CD off five different discs I program in the changer) but I think this has more to do with the mechanism of a changer...
post #1468 of 2740 Old 01-27-2016, 05:30 AM
callas01's Avatar
Quoted: 956 Post(s)
Liked: 584
Here is my setup:
Dynaudio Focus 260s
Naim Uniti 2 Integrated Amp All-in-One Network Streamer
Pro-ject 2xperience TT w/ Stock Sumiko Blue Point No.2
Naim Stageline phono preamp
Mac Mini w/ M2Tech HiFace USB to spdif converter running JRiver
My system integrates the HT setup also, but the HT bypass on the Naim allows to separate 2-ch from HT. The rest of the gear is a Marantz 7007, Oppo 103, Hsu VTF3 MK5 HP, Dynaudio Focus 210C and DM2/6 and a 55" Panasonic Plasma.
Dynaudio Focus 260s, Focus 210C, DM 2/6, Hsu VTF3 MK5 HP, Oppo BDP-103, NaimUniti 2, Naim Stageline N, Pro-ject 2xperience Classic, Marantz SR7007, 60" 4K Samsung LED LCD
callas01 is offline
post #1469 of 2740 Old 01-27-2016, 08:15 AM
bgtighe23's Avatar
Liked: 949
Originally Posted by callas01 View Post
Here is my setup:
Dynaudio Focus 260s
Where are your Acoustic Panels from? They look very nice and integrate with the room well.
A great choice in gear. Though I will admit I have never knowingly heard a speaker from Dynaudio.
post #1470 of 2740 Old 01-27-2016, 09:29 AM
callas01's Avatar
Quoted: 956 Post(s)
Liked: 584
I bought them through ATS Acoustics. Thank you for the compliment.
Well if you ever get a chance, do listen, they have a smooth top-end with clean mids and punchy low-end. I really enjoy them.
callas01 is offline
Reply 2-Channel Audio
Arcam , Auralex , B W , Denon , Emotiva Xpa 2 Stereo Power Amplifier , Infinity , Kef Ls50 2 Way Speaker System , Marantz , Mcintosh Labs , Nad , nikko , Onkyo Tx Nr807 , Pioneer , Polk Audio , Polk Audio Rti A9 Floorstanding Speaker , Psb , Rega , Sansui , Sonos , Sonus Faber , Velodyne , Vienna Acoustics
