Let's see pics of your stereo setup! - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 2826Likes
post #121 of 2608 Old 08-15-2010, 01:31 PM
TheWind's Avatar
Liked: 31
.I've used vases before. I'm sure there will be doubters but, ounce for ounce; I think they improve the sound of stereo or home theater setups more than almost any other costly upgrade available. The resulting holographic imaging and dynamics can be magical. What you do is
TheWind is offline
post #122 of 2608 Old 08-15-2010, 01:40 PM
vinyl's Avatar
Mmmmm - sounds like a lot of wind to me.
crapel413 likes this.
Most people don't know what they want...but, they're pretty sure they haven't got it. ©
vinyl is offline
post #123 of 2608 Old 08-23-2010, 07:43 AM
RayPaganJr's Avatar
The gear.
RayPaganJr is offline
post #124 of 2608 Old 08-26-2010, 07:36 AM
kevinzoe's Avatar
Hi all,
My system is a 'minimalistic' setup: CDP/preamp->tubeamp->speakers. Three components - that's it. Audio Aero Capitole MKII SE->Art Audio PX25 single-ended tube amp->FAB Audio Model1 high efficiency (97dB) speakers.
With a minimum of effort placed in equipment, I turned my attention to room acoustics. I've spent much time and energy building diffusers (Skylines, Hemi-cylindrical) and bass traps, moving them all around the room while taking measurements for each treatment placement combination. The effects of the treatment are phenominal (not because I'm any special carpenter); for example, a 11dB peak at 80Hz is now only 3dB, and the side wall flutter echo is completely gone, and the attenuation of the indirect sounds via diffusion allows more of the direct sound to be heard easier. Room acoustics is really the other half of the equation.
From the sweet spot.pdf 102.318359375k . file
Back Wall.pdf 130.509765625k . file
From the doorway.pdf 97.2451171875k . file
Hemi-Cylindrical Difuser and Bass Trap.pdf 154.86328125k . file
DIY Skyline Diffuser.pdf 172.0263671875k . file
File Type: pdf Hemi-Cylindrical Difuser and Bass Trap.pdf (154.9 KB, 135 views)
kevinzoe is offline
post #125 of 2608 Old 08-26-2010, 10:26 AM
its phillip's Avatar
Quoted: 63 Post(s)
Liked: 117
pdfs? :/
videobruce likes this.
its phillip is online now
post #126 of 2608 Old 08-26-2010, 10:49 AM
kevinzoe's Avatar
Originally Posted by its phillip View Post
pdfs? :/
Alas, the file size restriction would mean I'd have to resize all the pics when it seemed easier and faster to import them into Word and Save As .pdf.
Can you not open a pdf file?
kevinzoe is offline
post #127 of 2608 Old 08-26-2010, 11:01 AM
Quoted: 63 Post(s)
Liked: 117
I can, I just hate them
Anyway, I don't know anything about room treatments or the system you have, but it does look amazing.
In the future, if you feel like resizing your images, there is a free image viewer/converter called irfan view. Very simple to use
post #128 of 2608 Old 08-26-2010, 01:05 PM
Weasel9992's Avatar
Kevin...nice. You DIY'd those skylines, right?
Frank Oesterheld
Weasel9992 is offline
post #129 of 2608 Old 08-26-2010, 02:29 PM
kevinzoe's Avatar
Hi Frank,
Yes, I built the Skylines myself and I've posted how over on the Master Acoustics thread that you may recall reading.
I used http://www.oliverprime.com/prd.php to assist in designing them after hunting for a Prime number that fit my desired wall dimensions of height and width. I plan on re-doing the back wall with 18"depths which would have been deeper had my room been longer to accommodate a sitting distance of 3 wavelengths from its lowest frequency, using cell depth = 50% of wavelength as the guideline. A max cell depth of 18" is 50% of 377Hz.
I'm also a GIK customer in case you didn't catch the stack of 8 GIK Tri-traps in the back left corner of the picture extending from floor to ceiling with a 6" air space extending 30" into the room. Now THAT's a bass trap!
kevinzoe is offline
post #130 of 2608 Old 08-27-2010, 04:48 AM
Rodrigues_Brazil's Avatar
Quoted: 284 Post(s)
Liked: 20264
You just need some free image hosting like eg. Photobucket, ImageShack, etc
Cheers!
Rodrigues_Brazil is offline
post #131 of 2608 Old 08-27-2010, 09:04 AM
Weasel9992's Avatar
Hi Frank,
I appreciate that, but those skylines are the most impressive thing in the room, no doubt about it. Beautiful job.
Frank Oesterheld
post #132 of 2608 Old 09-01-2010, 12:38 PM
taam's Avatar
Sota Star TT, Pass Labs Aleph Ono, Audio Research SP 17L, Threshold 4000 amp, Vandersteen 3a sigs
zuluwalker likes this.
taam is offline
post #133 of 2608 Old 09-01-2010, 01:13 PM
chacruz's Avatar
Wow...wonderful setups!!!
This is mine:
LS9-s (outboard XO), Shanling tube CD, Dodd battery Pre, PSAudio Amp and PSAudio Power Plant. DIY room treatment.
chacruz is offline
post #134 of 2608 Old 09-02-2010, 11:18 AM
HTPC_Engineer's Avatar
Originally Posted by Wardsweb View Post
Here is my 2-channel rig in the living room. The speakers are DIY horns veneered in sapelel pommele.
*Heart Stops*
hotrodguy likes this.
HTPC_Engineer is offline
post #135 of 2608 Old 09-02-2010, 12:11 PM
Weasel9992's Avatar
Beautiful! Those diffusers are DIY as well?
Frank Oesterheld
post #136 of 2608 Old 09-02-2010, 12:31 PM
localhost127's Avatar
Quoted: 25 Post(s)
Liked: 60
Hi Frank,
link?
localhost127 is offline
post #137 of 2608 Old 09-06-2010, 01:45 PM
kevinzoe's Avatar
Hi Frank,
Originally Posted by localhost127 View Post
link?
Hi Localhost127 - If I did this correctly, then this link should point you to my post for building a DIY Skyline diffuser found here:
http://www.avsforum.com/avs-vb/showp...postcount=6485
Feel free to send me a PM, if you like.
kevinzoe is offline
post #138 of 2608 Old 09-06-2010, 05:50 PM
Waboman's Avatar
Quoted: 4813 Post(s)
Liked: 11197
I thought I'd try and show my little vintage 2-channel setup. It's really nothing fancy at all. But it does rock, and I do enjoy spinning the wax. Keep in mind all this gear is from the 70's, which was my goal when I started piecing it together. I hope you like it and as always, turn it up!
My vintage, all 70's, 2-channel setup
Nethawk likes this.
Waboman is online now
post #139 of 2608 Old 09-07-2010, 10:20 AM
oOOBillO0o's Avatar
Good video Waboman, definitely the best way to show off your gear, I hope more catch on..
Un related to the thread: What Software do you use and what is your workflow? Can one do this quickly?
Bill
McIntosh Labs! What am I listening to?
oOOBillO0o is offline
post #140 of 2608 Old 09-07-2010, 11:33 AM
Weasel9992's Avatar
Hi Frank,
I remember now. Thanks for the link!
Frank Oesterheld
post #141 of 2608 Old 09-07-2010, 11:25 PM
Waboman's Avatar
Liked: 11197
Bill
Thanks, Bill.
I used iMovie to make & edit the video. It can be time consuming, but it's the fun kind of time consuming.
post #142 of 2608 Old 09-12-2010, 07:16 PM
chacruz's Avatar
Yes, we made the wood diffusers here. Thanks!!!
chacruz is offline
post #143 of 2608 Old 09-12-2010, 09:00 PM
RBFC's Avatar
Quoted: 82 Post(s)
Liked: 66
Here's the front soundstage of my combination stereo/ Home Theater. B&W 801Ds and HTM1D center, driven by a Krell EV403 amplifier (amp hidden in alcove behind center speaker and GIK bass traps). JL Audio F113 subwoofer sits behind right speaker. 6 GIK bass traps in all, hidden behind curtains.
Lee
GoldenEar Triton One speakers (6, for front, side surround, and rear surround), GoldenEar SuperCenter XXL center channel, GoldenEar HTR7000 overhead speakers (4), JL Audio F113 x 2 (subwoofers), Krell Foundation pre-pro, Krell EV403 (front 3 channels), 2 x Krell S1500/4 (one for each side's 2 surround and 2 overhead speakers), OPPO 203D (4K, Blu-ray, SACD, DVD-A), Calyx Audio DAC24/192, MacMini w/ 2TB drive (server), Purist Audio interconnects & speaker cables, Sony XBR-75Z9D monitor.
RBFC is offline
post #144 of 2608 Old 09-13-2010, 08:48 AM
David James's Avatar
Quoted: 40 Post(s)
Liked: 80
Part of my home theater, but I listen using these 2 channels, along with the sub at least as much.
The picture is a bit fuzzy, I have larger and slightly clearer ones. Some other pictures can be found here
David James is offline
post #145 of 2608 Old 09-13-2010, 08:50 AM
williamtassone's Avatar
Vitus pre and power amp, Luxman SAcd/player , Wilson Benesch Speakers and Transrotor TT. The mess is mine
williamtassone is offline
post #146 of 2608 Old 09-13-2010, 01:39 PM
Weasel9992's Avatar
Beautiful. Does it still have that "new speaker" smell?
Frank Oesterheld
post #147 of 2608 Old 09-13-2010, 07:37 PM
sure does , like being in the dealers.
post #148 of 2608 Old 09-18-2010, 07:37 PM
hifihipster's Avatar
I wrote a post on my blog about how I got into hi-fi that has a couple pics of my current system. Check it out:
http://hifihipster.com/2010/09/my-cu...w-i-got-there/
hifihipster is offline
post #149 of 2608 Old 09-20-2010, 12:40 PM
Weasel9992's Avatar
Love that turntable...got one just like it with an OM-30.
Frank Oesterheld
post #150 of 2608 Old 10-01-2010, 04:14 PM
stevensctt's Avatar
Quoted: 23 Post(s)
Liked: 37
Modest bedroom set-up (third system in house) completed today with the addition of the Quads. Pieced together for $1000. Although a 3.1 set-up, primary use is 2.1.
L/R Speakers: Quad 11L2
Center Speaker: Quad L2 Centre
Subwoofer: M&K VX-7 MK II
CD Player: Denon DCD920
Processor: Marantz AV560
Amplifier: Rotel RB976 6 channel bridged to 3 channel (150W/ch)
stevensctt is offline
Reply 2-Channel Audio
Arcam , Auralex , B W , Denon , Emotiva Xpa 2 Stereo Power Amplifier , Infinity , Kef Ls50 2 Way Speaker System , Marantz , Mcintosh Labs , Nad , nikko , Onkyo Tx Nr807 , Pioneer , Polk Audio , Polk Audio Rti A9 Floorstanding Speaker , Psb , Rega , Sansui , Sonos , Sonus Faber , Velodyne , Vienna Acoustics
