speaker cables and jumpers vs bi-wiring - Page 9 - AVS Forum | Home Theater Discussions And Reviews
post #241 of 261 Old 07-11-2012, 08:17 AM
Jinjuku's Avatar
Quoted: 58 Post(s)
Liked: 148
Originally Posted by R-Carpenter View Post
yes "up" "down" smile.gif I am in Brooklyn
BTW you know NY DIY is doing Iron Driver competition "blind" this year.
An audiophile likes to talk about how much they spent and how good it sounds.
A DIY'er likes to talk about how little they spent and how good it sounds.
Jinjuku is offline
post #242 of 261 Old 07-11-2012, 11:29 AM
caper_1's Avatar
Liked: 26
Originally Posted by arnyk View Post
...That's the whole point of bi-wiring.
Wrong. If you draw an electric circuit diagram, bi-wiring is identical to using jumpers. Bi-wiring just moves the 'jumper' further away from the speaker so you in fact use more speaker wire than required, thus draining your wallet of otherwise useful money. There is no 'point' of bi-wiring that I am aware of.
HT: Yamaha RX-V565 | 3 X Energy Take FPS, 2 X VS Surround, 2 X Take LCR | DIY Subs: SDX12 APR15 & TRIO12 Dual APR 12's | 47" LCD
Music: Yamaha RX-V863 | 2 X Energy RC-70 | MA RXw12 Sub
Bathroom: 2 X Energy Take LCR
Car: Sony Xplod HU, Xplod 6X9s, Kenwood 4"s, Alpine 12" Type-S, Rockford Amp,...
caper_1 is offline
post #243 of 261 Old 07-11-2012, 12:48 PM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
And that is what seems to be behind your (generic you, not you personally) typical attempt to expose of the faults of DBTs. Not that DBTs are anything like the perfect solution for every problem.
If you're a lover of magic coils, capacitors, or resistors, cables or biwiring, DBTs provide very little encouragement. Ditto for those who love hours of pontification about jitter or TIM.
I think you'll find he's in agreement with you and not a believer in woo-woo audio. Comment meant that most philes would not like the null result against their pre-existing belief system.
A9X-308 is offline
post #244 of 261 Old 07-11-2012, 01:02 PM
caper_1's Avatar
Liked: 26
caper_1 is offline
post #245 of 261 Old 07-11-2012, 01:23 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
If that were a completely true statement, you wouldn't have to contradict it as follows:
Exactly.
If you write the loop or node equations, biwired and normal wiring yield two different sets of equations that are always different and can't be reduced to the same thing without introducing some approximations or assumptions.
Agreed.
There are slight theoretical differences. If the speaker cable has adequately low series impedance, then the differences are again slight.
If you wire your speakers with something like number 36 wire (as fine as hair), it is possible that biwiring may actually produce a difference in SQ.
It turns out that you get slightly less cable loss if you leave the jumpers in place.
arnyk is offline
post #246 of 261 Old 07-11-2012, 06:07 PM
caper_1's Avatar
Liked: 26
unfortunately circuit diagrams don't include DISTANCE from point to point, so yeah, my statement IS true. The "short" is still in the same place, with the only difference being the length of wires that connect it (either a jumper plate, or long lengths of wire). They still originate from the SAME electrical point...
caper_1 is offline
post #247 of 261 Old 07-11-2012, 06:10 PM
caper_1's Avatar
Liked: 26
Agreed. 200 feet of small gauge wire would in fact be benefited with bi-wiring. But then again, if proper gauge wire were used, then this would be avoided...
caper_1 is offline
post #248 of 261 Old 07-11-2012, 07:58 PM
Jon Middleton's Avatar
Quoted: 188 Post(s)
Liked: 137
caper_1, how much time do you spend in the bathroom? How big is it? How is the soundstage in there.wink.gif
Jon Middleton is offline
post #249 of 261 Old 07-11-2012, 09:08 PM
R-Carpenter's Avatar
Originally Posted by Jinjuku View Post
Mike is a very experienced designer who actually designs, measures and builds systems. Last year he had a first place in NY DIY in the unlimited category. (not last year, sorry, year before that. Last year, Alice took the first place) Why would it drive him bonkers?
R-Carpenter is offline
post #250 of 261 Old 07-12-2012, 06:29 AM
caper_1's Avatar
Liked: 26
LOL @ soundstage biggrin.gif My logic was this: Use a shower radio that gets all static-y because it is never in the right position for FM radio, and listen to crappy FM radio while in the shower and box up my LCR's and store them... OR, do this:
PIC 1
PIC 2
PIC 3
PIC 4
Haven't you tried to crank up the music in the living room and leave the bathroom door open to try and hear it in the shower? It just doesnt work!! Bathroom is small, and the 'throne' is sorta boxed in, above which the speakers are mounted.
caper_1 is offline
post #251 of 261 Old 07-12-2012, 12:28 PM
A9X-308's Avatar
Liked: 951
That's only true if you consider that the drawn lines represent conductors of zero impedance. Draw in the actual impedances of the conductors on the two diagrams and they are different, even if only very slightly so.
A9X-308 is offline
post #252 of 261 Old 07-12-2012, 01:23 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
PIC 1
PIC 2
PIC 3
PIC 4
This is a variation in the classic soffit mounting of speakers. Predictable effect is a fairly strong increase in bass response, which might actually help if the speakers are thin-sounding to begin with.
Usually you get best results if you bisect the corner with the primary axis of the loudspeaker system. The reflections from the ceiling and wall create 2 more virtual speakers. Try moving the speakers out a little further from the corners which may or may not sound better.
I've done this with NHT Superzeros, and the extra bass helped.
In a different acoustic context with small Infinity monitors, I had to use an equalizer to cut the bass. But you still win, because the speaker is usually cleaner sounding since it has to do less work at low frequencies for the same basic sound.
arnyk is offline
post #253 of 261 Old 07-12-2012, 01:32 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
And just to complete the story, the heavier and more tightly twisted (within reason) the speaker cables, the lower the series impedance, and the closer the wires are to having zero impedance. Using multiconductor cables with many interleaved wires paralleled into two main conductors minimizes series inductance at the cost of more parallel capacitance. However for reasonable wire gauge speaker cables that are under 20 feet long and with speakers that have reasonable impedance curves, there are few if any sonic benefits for any fancy-schmancy, and good old twin feeder does the job.
arnyk is offline
post #254 of 261 Old 07-12-2012, 01:45 PM
Jinjuku's Avatar
Quoted: 58 Post(s)
Liked: 148
I don't believe he is a fan of blind testing from his posts. Didn't say he wasn't a competent designer. The hole grin face was a tongue in cheek (they need that as an emoticon)
Jinjuku is offline
post #255 of 261 Old 07-12-2012, 08:38 PM
caper_1's Avatar
Liked: 26
Try moving the speakers out a little further from the corners which may or may not sound better..
No can do. If you saw the mounting system you would understand. The bracket is flush with the wall. I would have to add a spacer like a 2X4 block or such. I am not going to push it since wifey wasn't too pleased to begin with, and it won't make that much difference with a shower running, etc biggrin.gif Thanks for the ideas though, and you are right, they put out more bass than anticipated in there, for thin sounding speakers.
caper_1 is offline
post #256 of 261 Old 07-13-2012, 01:24 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Makes sense, I was just throwing out ideas. I guess this one didn't stick to the wall! ;-)
arnyk is offline
post #257 of 261 Old 11-05-2013, 08:24 AM
loop7's Avatar
Quoted: 12 Post(s)
I used to be a big believer simply because having more amplifier overhead per driver would offer more control and lower distortion due to to not working as hard. However, I think I've changed my tune for a few reasons:
  1. I attended a few high end shows and noticed $20,000+ speakers designed with a single pair of binding posts. Thiel CS3.7 is one example.
  2. I've also had some issues configuring pre-amps and AVRs for bi-amping but this was likely user error and not the gear
  3. I'm skeptical about manufacturers including dual sets of terminals is a madison avenue gimmick
Sonically, I may have heard slight differences and I'll continue to experiment but I'm not yet sold on it.
loop7 is offline
post #258 of 261 Old 11-05-2013, 04:55 PM
CharlesJ's Avatar
Quoted: 425 Post(s)
Liked: 251
... I guess this one didn't stick to the wall! ;-)
CharlesJ is offline
post #259 of 261 Old 11-05-2013, 05:15 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
The thread is about bi-wiring, not bi-amping.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #260 of 261 Old 11-20-2013, 08:53 PM
ejr1953's Avatar
I have just completed another audio system upgrade.  About three years ago I did my last major upgrade, had to order the electronics, and the dealer sent me home with high-end cabling, while I waited for my order to arrive.  I had been using 14 gauge lamp cord and the jumpers delivered with my B&W CM5's and replaced it with Audioquest cables with bi-wire ends and with my old electronics immediately noticed an improvement in the stereo image, the bass response seemed tighter and the highs just a tad smoother.  Before that I wasn't sold on the higher end cabling.  So I'd recommend spending a reasonable amount on it now.
ejr1953 is offline
post #261 of 261 Old 11-21-2013, 07:24 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Two words, sighted evaluation.
arnyk is offline
Reply 2-Channel Audio
