Headphone Audiophiles - Page 42 - AVS Forum
post #1231 of 1247 Old 12-05-2014, 01:54 PM
noisebeam's Avatar
Originally Posted by emerson1 View Post
So if your parents were about to get duped by some kind of salesman you wouldn't step in just because it's something they think they want? Old people are always wanting to send money to princes in Nigeria.
Beats may not be good value, but that does not mean they are a scam or terrible headphones
One of the more important elements of headphone enjoyment is how they fit and feel, your dad like the fit of Beats.
noisebeam is offline
post #1232 of 1247 Old 12-05-2014, 04:30 PM
pbarach's Avatar
Quoted: 100 Post(s)
Liked: 111
Originally Posted by decibels View Post
Sorry for the late response, I got them locally in Vancouver, NCIX was blowing them out, couldn't resist and love them so far. I am plugging them directly into the SC-85 headphone output and am enjoying them and once they get some hours on them I am sure they will sound better.
Will a headphone amp make a significant difference in the sound quality and do you need a DAC in the amp?
You don't need a DAC in a freestanding headphone amp unless you are sending it a digital signal. I use analog outputs from a CD player into my headphone amp, since I don't have a DAC.
Whether a headphone amp will give you better sound quality than the headphone jack in your receiver depends on the quality of the headphone amp built into that receiver--many receivers have headphone amps that are an afterthought and don't give such great sound. Also, some people feel the HD-700 has a spiky treble and would do best with a warm-sounding amp. I haven't heard the 700s myself...
AT&T U-Verse Northeast Ohio
Denon x4000, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, etc.
pbarach is offline
post #1233 of 1247 Old 12-05-2014, 07:18 PM
Quoted: 28 Post(s)
Liked: 1
Thanks for the advice. I have another question to put out and would love the best way to solve this.
I have two amps that I run, one for my turntable & CD player (this is a warm sounding amp and the headphone output is okay) and the other for HT/TV (this has a much better headphone output and not as warm sounding for the CD player). What would the best way be to have the RCA output from my CD player be able to go into both amps and possibly a headphone amp without compromising the sound? I thought all that was needed is Y cables from the CD output into both amps, however when I set this up the sound from both amps was not good compared to switching one set of cables between the two, which is not ideal.
HT: Pioneer SC-85, PS3
OSD ATM-7
2CH: Technics SU-V7X amp, Pioneer PL 518 turntable, Pioneer PD M455 CD, Pioneer CT-WM77R Tape
Paradigm Studio 60's, Studio CC, Studio 20's SR, Studio 20's SB, Ultracube 10 SW
decibels is offline
post #1234 of 1247 Old 12-05-2014, 07:21 PM
Quoted: 28 Post(s)
Liked: 1
I have not noticed any spiky treble sound at any volume level thus far, if anything they might be a little light on the boominess of the bass, which I am not a fan of anyway. So far I am really really enjoying these.
OSD ATM-7
decibels is offline
post #1235 of 1247 Old 12-05-2014, 07:29 PM
pbarach's Avatar
Quoted: 100 Post(s)
Liked: 111
I have no idea how you can do this, other than some kind of switch box that has one set of RCA cables as an input and a choice of switching between one of two sets of RCA cable outputs. I'm sure you can find something like this at Radio Shack, but who knows what effect the wiring will have on the sound??
pbarach is offline
post #1236 of 1247 Old 12-06-2014, 12:03 PM
Quoted: 28 Post(s)
Liked: 1
Thank you!
Yes that is what I was thinking and also unsure of in terms of sound quality. I am hoping others have had this scenario and found solutions that work without compromising sound.
OSD ATM-7
decibels is offline
post #1237 of 1247 Old 12-06-2014, 12:24 PM
RayDunzl's Avatar
Quoted: 502 Post(s)
Liked: 725
Audio switches are hard to find.
But, "Composite Video Switches" do analog audio too, and are cheap.
http://www.amazon.com/s/ref=nb_sb_no...switch+2%2Caps
I'll be back later...
links::: 1.5RQ > digits > 1177a > OpenDRC-DI > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest > Sweetspot
RayDunzl is online now
post #1238 of 1247 Old 12-06-2014, 05:22 PM
Quoted: 28 Post(s)
Liked: 1
Thank you Ray, saw some good cheap options, however they don't seem to switch between the outputs, which is most important so the signal is not interfering with the amps.
OSD ATM-7
decibels is offline
post #1239 of 1247 Old 12-06-2014, 06:10 PM
RayDunzl's Avatar
Quoted: 502 Post(s)
Liked: 725
Ok, then try a "distribution amplifier"
http://www.bhphotovideo.com/c/buy/Di...5/N/4294548694
post #1240 of 1247 Old 12-06-2014, 11:33 PM
cel4145's Avatar
Quoted: 252 Post(s)
Liked: 784
Niles AXP 1 Aux Input Switcher can be used as an aux output switcher: http://www.amazon.com/Niles-Black-FG.../dp/B00006I5J0
Just plug everything in reverse from how it's labeled. That's what I use it for. Case is all metal (aluminum?), not cheap plastic like most of the lesser expensive audio/video switchers. Since Amazon has it, you could send it back if you don't like it.
HT: Energy RC-50, RC-LCR, Veritas VS Surrounds | Dual CHT SS 18.1s | Denon AVR-888 | modified Dayton SA1000 | Antimode 8033C
Desktop: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | HK 3390
Headphone & Portable HE-400 | K612 Pro | HP150 | DX50 | E12
cel4145 is offline
post #1241 of 1247 Old 12-07-2014, 12:26 AM
RayDunzl's Avatar
Quoted: 502 Post(s)
Liked: 725
Oh, I like that idea.
post #1242 of 1247 Old 12-07-2014, 10:32 AM
Quoted: 28 Post(s)
Liked: 1
Ahh fabulous, this is exactly what I was looking for, thank you!! To confirm you use it with one input and multiple outputs? Have you experienced any crosstalk? The reviews look mostly positive with the occasional person complaining of interference...Thank you!!
OSD ATM-7
decibels is offline
post #1243 of 1247 Old 12-07-2014, 10:40 AM
Quoted: 28 Post(s)
Liked: 1
Niles also has a PS-1 device that seems like it would be good as well, however there website does not give too many details? Unfortunately, Amazon.ca does not have the AXP-1 so I will try directly from Niles or find a local distributor.
http://www.nilesaudio.com/product.ph...rdcdID=FG00012
Thank you!
OSD ATM-7
decibels is offline
post #1244 of 1247 Old 12-09-2014, 09:48 AM
Liked: 0
there is a bluetooth headphone in this list that you might want to check out. http://www.techtapper.com/best-headp...er-200-dollar/
alinasofia1234 is offline
post #1245 of 1247 Old 12-12-2014, 08:35 PM
marjen's Avatar
Quoted: 12 Post(s)
I just got a pair of the Grain Audio OEHPs. SO far so good. I like them better than my Brainwavz HM5s which I love. More low end, more clarity and I think a little more comfortable. Plus they are a little less bulky. Off to a good start.
Mark-
marjen is offline
post #1246 of 1247 Unread 12-18-2014, 09:19 PM
vancouver's Avatar
Quoted: 16 Post(s)
McIntosh MHP1000
Anyone here have the new headphones from McIntosh? I ordered a pair this week from my dealer, and they should arrive first week of Jan. If anyone hear owns a pair I'm curious to know what you use to drive them, and your impressions. Ill be using an Oppo HA-1.
vancouver is offline
post #1247 of 1247 Unread Today, 03:05 PM
ZoNtO's Avatar
Anybody pick up the AKG K7XX from Massdrop recently?
ZoNtO is online now
Reply 2-Channel Audio
Nuforce , Akg K702 65th Anniversary Edition , Sennheiser , Sennheiser Hd 600 Open Dynamic Hi Fi Professional Stereo Headphones Black , Audio Technica Ath Ad900 Audiophile Open Air Dynamic Headphones , Oppo Bdp 83se Blu Ray Player , Hifiman He 6 Headphones , Grado Rs1i , Yamaha Rx V1800 Receiver , Sony Mdr7506 Professional Large Diaphragm Headphone , Sennheiser Hd 650 Headphones , Sennheiser Hd 558 Headphones , Grado Prestige Series Sr80i Stereo Headphone , Sennheiser Hd800 Over Ear Circum Aural Dynamic Premiere Headphone
Gear in this thread - V1800 by PriceGrabber.com
