The 'NEW' YAQIN MS-20L Integrated Vacuum Tube Amp Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
post #541 of 843 Old 08-24-2012, 03:08 AM
NZAJTG's Avatar
My speakers are 87dB 4 Ohm and the 20L drives them with no issues. I cant comment on your speakers other than they are 86dB and also 4 ohm
so are similar in spec.
NZAJTG is offline
post #542 of 843 Old 08-25-2012, 03:26 PM
cytowing's Avatar
Originally Posted by rntlee View Post
Pot arrived today, Song sent it expedited mail, no charge. For anyone who's thinking about buying a Yaqin, you really need to consider buying through Song. The guy is grade A.
I don't think the pots is Alps'. Looks to be a decent clone though.
I had the same problem with my MS20-L, after having had it for a little over a year, noise in the left channel when adjusting the volume.
I cleaned the pot with isopropanol and it took care of the problem. I used to be a TV repairman in the 70s and that was always the first thing we tried with a noisy pot.
you have to be trusted by the people that you lie to....
cytowing is offline
post #543 of 843 Old 08-25-2012, 07:31 PM
gwestwoodnurse's Avatar
My volume was a bit scratchie as well but a quick shot of deoxit did the trick
gwestwoodnurse is offline
post #544 of 843 Old 08-25-2012, 08:35 PM
rntlee's Avatar
I've never had much luck "cleaning" a pot. Problem always returns in short while. I'm curious how you got the alcohol into this pot without disassembling it, as it's a sealed unit?
CIMG5274.JPG 886k .JPG file
rntlee is offline
post #545 of 843 Old 08-25-2012, 09:56 PM
cytowing's Avatar
Removed the knob, then I took the shaft nut off that holds it from the top. Pushed the pot down as far as it would go and used a syringe to squirt a couple of ml or so of alcohol in through the hole for the locking tab, aiming at the base of the shaft. Then turned the shaft a bunch of times and let it dry for a couple of hours before re assembling.
cytowing is offline
post #546 of 843 Old 08-26-2012, 03:54 AM
FineArts's Avatar
Do not smoke in the room where you listen the music.I f you live near roads,high-ways,keep the window closed.....it can help a lot the pot remain clean !
FineArts is offline
post #547 of 843 Old 08-27-2012, 09:13 AM
rntlee's Avatar
Looking at the pot, there really is no external access to the tracks and wiper. It's sealed up quite tight, but if you're pot is working fine again...who knows?
Mine has mysteriously become silent again, without any intervention on my part! I'm beginning to wonder if it's not a DC offset problem. Yaqin didn't include an input capacitor to prevent the entrance of DC into the amp...or maybe it's leaking back from a higher stage? ap1, is this a possibility?
rntlee is offline
post #548 of 843 Old 08-28-2012, 04:58 PM
cytowing's Avatar
i would think that a cheap pot is the most likely culprit.
I may have gotten lucky and had little alcohol go into the pot, as you say... who knows??
If mine acts up again I may tear it apart and see what happens
cytowing is offline
post #549 of 843 Old 09-03-2012, 12:19 PM
FineArts's Avatar
I would have a question.When biasing amp.,should I disconect CD player and other equipement or leave it conected and just turn volumen pot on 0 ?
FineArts is offline
post #550 of 843 Old 09-03-2012, 12:41 PM
alatham's Avatar
Originally Posted by TrifectoChris View Post
I was wondering if there are any members using this amplifier to drive a larger Magnepan speaker like the 1.6 model? If so what what has been your experience?
I am looking to drive Maggie 1.7 with my 20L. Would love to hear feedback on if I am going to toast my speakers or amp if I try that.
alatham is offline
post #551 of 843 Old 09-03-2012, 06:51 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
There is no reason to disconnect anything. You can even leave volume intact, just do not play anything at that time.
FineArts likes this.
ap1 is offline
post #552 of 843 Old 09-03-2012, 06:53 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
You won't kill the amp, just won't get best sound quality from that combination.
ap1 is offline
post #553 of 843 Old 09-04-2012, 02:40 AM
FineArts's Avatar
Thanks ap1 for your quick answer,I was thinking the same but was not sure
FineArts is offline
post #554 of 843 Old 09-05-2012, 09:02 AM
TrifectoChris's Avatar
Has anyone tried this amplifer with Martin Logan's ElectroMotion speakers?
TrifectoChris is offline
post #555 of 843 Old 09-14-2012, 03:21 AM
NZAJTG's Avatar
I wouldnt bother, I know someone with Martin Logan Vantage and his gigantic Solid state amp has to work hard to drive them.
The little 20L just wouldnt work, probably sound like crap and the amp would be working way to hard.
NZAJTG is offline
post #556 of 843 Old 09-14-2012, 10:55 AM
rntlee's Avatar
I think they'd work fine with the 20L. There's a review on ML's website from a guy running a pair on an 8 watt SET. He loves them.]
rntlee is offline
post #557 of 843 Old 09-14-2012, 01:51 PM
ccotenj's Avatar
Liked: 101
that "gigantic solid state amp" must not have too much inside of it then, because the ml vantages aren't particularly difficult to drive... smile.gif
- chris
ccotenj is offline
post #558 of 843 Old 09-17-2012, 07:57 PM
I was hoping that someone on the forum would have real world experience with it. Maybe I will have to be the first.
post #559 of 843 Old 09-19-2012, 02:33 AM
NZAJTG's Avatar
Sorry, must be wrong then
NZAJTG is offline
post #560 of 843 Old 09-23-2012, 04:28 AM
njpozner's Avatar
I have ElectroMotions that I'm driving with a Yaqin MC-100B without any problems. Turning the volume up to 30% is more than loud enough for my space. I've taken them louder without distortion, but my neighbors would kill me if I did so often!
njpozner is offline
post #561 of 843 Old 09-24-2012, 12:50 PM
Ernstmach's Avatar
Quoted: 31 Post(s)
Liked: 728
Anyone blow a fuse in their MS-20L?
Ernstmach is offline
post #562 of 843 Old 09-25-2012, 10:44 AM
Theonetruegreg's Avatar
Liked: 61
I use the MC-100B Kt-88 amp with my Maggie's 1.5, and is the best combo of the amps I've used with them (the big Denon POA4400 class A monos, Emotiva XPA-2). Even though the power output ability is 1/6th of what I'd used previously, at the volumes I listen in my 18x12 room, it sounds beautiful.
TV's ain't theaters buddy.
My junk collection.
Theonetruegreg is offline
post #563 of 843 Old 09-25-2012, 07:08 PM
alatham's Avatar
Thanks True Greg! I actually ended up getting an older pair of 2.7 maggies and so far it's working fine.
alatham is offline
post #564 of 843 Old 09-28-2012, 08:06 AM
Jeff Aguilar's Avatar
Quoted: 16 Post(s)
Liked: 36
Send a message via Yahoo to Jeff Aguilar
I have blown a couple of fuses in my amp! I turned it off and then on too quickly and pop... I ended up going to a professional electronic supply store to find the correct fuses in case I burned a few out. It is an odd sized fuse
Jeff Aguilar is online now
post #565 of 843 Old 09-28-2012, 10:38 AM
Ernstmach's Avatar
Quoted: 31 Post(s)
Liked: 728
Jeff, I was wondering if I were the only person that has had this happen. In my situation it happened while listening to headphones.
I was using my AKG 701's, about an hour into my listening session. The left channel just stopped working. I didn't think that the amp was required to put forth much effort as I wasn't listening at high volume levels.
I contacted Song about it. He responded very quickly and was eager to help. He suggest I look for a blown fuse. I didn't know that each channel was fused.
Replaced it with one of the extras and all is well. Like you I have purchased the correct fuses from a known source to keep on hand.
post #566 of 843 Old 09-30-2012, 06:14 AM
rntlee's Avatar
What power tubes are you guys running in the amp? Just curious.
rntlee is offline
post #567 of 843 Old 09-30-2012, 05:58 PM
cytowing's Avatar
Russian NOS (early 1980s), 6P3S-E
Warning: The 6P3S-E is not a direct replacement, care must be taken when breaking them in.
cytowing is offline
post #568 of 843 Old 10-02-2012, 07:55 AM
FineArts's Avatar
I will be a little bit offtopic but will write any way.If you have turntable with MM cartige then add phono preamp Yaqin MS - 12B to your MS - 20L.Put together this combo sounds so teriffic
that I sold the same day my old preamp from Cayin model Lyric PS 2 that costed me more then 700 $.Yaqin MS - 12B you get for some 300 $ and with stock tubes it beats Cayin in every detail
FineArts is offline
post #569 of 843 Old 10-02-2012, 10:02 AM
rntlee's Avatar
How are they holding up for you? Kinda spec-busting running them in this amp. smile.gif
I've read lots of guys are doing it though. What are you biasing them at?
rntlee is offline
post #570 of 843 Old 10-02-2012, 05:10 PM
cytowing's Avatar
I have been using them for 10 months, no problems.
I am biasing them at .415 - .420
cytowing is offline
Reply 2-Channel Audio
Yaqin Ms 20l Integrated Vaccum Tube Amplifier , Yaqin , Onkyo Tx Sr806 Receiver , Emotiva Xpa 5 5 Channel Power Amplifier , Yaqin Mc 100b Kt88 Tube Integrated Amplifier 2 Mode New Pushpull , Axiom M3 V3 Bookshelf Speaker , Kef Q900wa Floor Standing Speaker , Yaqin King 2a3 Ms 2a3 Vacuum Tube Hi End Tube Integrated Power Amplifier Pus , Yaqin Ms 300c 300b X2 Vacuum Tube Hi End Tube Integrated Amplifier
