2 Channel Amp - Driving a pair of Monoprice 4101 - AVS Forum
post #1 of 6 Old 10-28-2010, 10:40 AM - Thread Starter
SabreOfSD's Avatar
Hello collective,
I am presently going through a remodel and have had two Monoprice 4101's installed in the ceiling. I am 99% sure I'll be buying a Squeezebox Touch to stream music to them.
What amp would you all recommend? I was honestly thinking of going to a tube amp since some of the smaller units now sound as good as the their Solid State brothers. Also, this will be on display, so something nice looking would be a plus
My price range is >$300.
Thanks for your advice/wisdom!
Sabre
SabreOfSD is offline
post #2 of 6 Old 10-28-2010, 10:54 AM
twitch54's Avatar
Given your price point as well as the modest speaker investment why would you even consider the need for seperates ??
Just get yourself a nice used two channel receiver and call it a day.
twitch54 is offline
post #3 of 6 Old 10-28-2010, 11:51 AM
kgveteran's Avatar
Liked: 37
Yup, great idea, probably a thousand on eBay !
kgveteran is online now
post #4 of 6 Old 10-28-2010, 01:07 PM - Thread Starter
SabreOfSD's Avatar
What (small) receiver would be able to stream my music over Wifi from my media server? I'm familiar with the Denon line, but I don't see anything that fits the bill in it. They have one that is Internet/Ipod enabled, but it doesn't say that it can stream locally hosted content.
Sabre
post #5 of 6 Old 10-28-2010, 05:20 PM
jettore's Avatar
This would work. Small and cheap, but out of stock at the moment.
http://www.parts-express.com/pe/show...number=300-383
jettore is offline
post #6 of 6 Old 10-28-2010, 05:31 PM
toobwacky's Avatar
In my somewhat limited experience with inexpensive tube amps, I find they usually use insufficient power transformers as a cost cutting measure to meet their price points. This means the PT runs scorchingly hot to the point I was afraid to use them for any length of time.
I agree with the other posters who said buy a good used receiver and run your Squeeze-box through it.
In retrospect, the film Idiocracy seems prophetic.
toobwacky is offline
Reply 2 Channel Audio
User Tag List
