Recommendations for hooking up 6 speakers with one two channel receiver. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-28-2010, 07:54 PM - Thread Starter
p1zaul's Avatar
I currently have a 2Ch receiver with an AB Switch. I am attempting to hook three sets of speakers (a total of 6 speakers) into this unit. I have a few options. Keep in mind I would like to independently select any variation of the three sets of speakers.
1 Run set one into A and run B to a switch with Set two and three connected to the switch.
2 Bridge A&B to the switch and run all three sets of speakers from the switch
3 Run A to the switch and run all three sets of speakers from the switch not using B from the receiver at all
These are the only feasible combinations I could come up with. Feel free to discuss additional options.
Thanks for the help.
p1zaul is offline
post #2 of 8 Old 11-29-2010, 08:01 AM
ccotenj's Avatar
Liked: 101
do you "want" to run more than 1 pair of the speakers at any time? or will just one pair of them be powered at any given time?
- chris
ccotenj is offline
post #3 of 8 Old 11-29-2010, 11:22 AM
Karkus's Avatar
here's another option:
Make a quasi surround sound system. There are lots of options, as shown below:
http://kantack.com/surround/surround2.html#tag2rcv
I use the top setup, but use the A and B outputs.
My A output powers the 2 front speaker.
My B output powers the rear speakers (as shown).
I don't use a volume control on the rear speakers.
Markus
Karkus is offline
post #4 of 8 Old 11-29-2010, 12:02 PM
ccotenj's Avatar
Liked: 101
won't work for the application the op has...
- chris
ccotenj is offline
post #5 of 8 Old 11-29-2010, 05:32 PM - Thread Starter
p1zaul's Avatar
Yes deffinetly need to run any combination of the three
p1zaul is offline
post #6 of 8 Old 11-29-2010, 06:10 PM
lngbruno's Avatar
Why don't you purchase a speaker switch box?
Peace, L
"Wanting to be someone else is a waste of the person you are. "- Kurt Cobain
lngbruno is offline
post #7 of 8 Old 11-30-2010, 05:14 AM - Thread Starter
p1zaul's Avatar
I have one, Trying to figure out the best way to hook it up
p1zaul is offline
post #8 of 8 Old 11-30-2010, 09:54 AM
lngbruno's Avatar
I am referring to something like the Russound SS-4.2 unit....where it doesn't matter if you have one pair of speakers or four pairs of speakers on at the same time. So, you could have all three pairs on "A" without a problem. However, in your case I would hook the primary pair up to "A" and the other two pair via the switch box to "B".
Good luck,
L
Peace, L
lngbruno is offline
Reply 2-Channel Audio
