Upgreading my Rega RP1 cartridge - AVS Forum | Home Theater Discussions And Reviews
Old 02-10-2011, 01:47 PM - Thread Starter
BuzzT1's Avatar
I'm looking for a new cartridge for my Rega RP1 turntable.
I have a the OM5e on my Rega, I looked at the Ortofon 2 M Blue and the Rega Bias 2.
If any of you guys have any suggestion from experience it will be very helpful to make a decision, my budget is $200.
BuzzT1 is offline
Old 02-10-2011, 04:17 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Add AT440 to the list.
ap1 is offline
Old 02-10-2011, 06:47 PM - Thread Starter
BuzzT1's Avatar
Thanx I will take a look, are you using this cartridge with your turntable?
BuzzT1 is offline
Old 02-10-2011, 08:52 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
I use AT150, but its price is in $280-300 range. It seems that main difference from 440 is stylus material (boron vs. aluminum).
ap1 is offline
Old 02-11-2011, 08:30 AM - Thread Starter
BuzzT1's Avatar
Can't find the AT150 any where for $300
BuzzT1 is offline
Old 02-11-2011, 08:41 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
It was on sale at $280 from two major on-line retailers just few days ago. Wait for another opportunity.
You can also look at Denon DL-160.
ap1 is offline
Old 02-14-2011, 06:59 PM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 316
I use a Ortofon 2m Blue on my Linn Sondek LP 12. Both the Rega and the Linn are similar in that they are warm sounding TTs. The Ortofon has some very nice top end detail and will add some dynamics to your sound.
The Ortofon did wonders for my Aerial 6's which are rolled off on the top end.
Price is ar $199.
Class A is offline
Old 02-15-2011, 06:42 PM - Thread Starter
BuzzT1's Avatar
Price is ar $199.
Thank you, after looking at reviews at the Internet I think that I will buy the Ortofon 2M Blue this week, I will let you guys know how the Ortofon is.
BuzzT1 is offline
Old 02-15-2011, 11:45 PM
adamanteus's Avatar
AT440 can be had on Amazon - through Amazon for $99 shipped. Good deal. They are out of stock for another week but, you can place your order.
adamanteus is offline
Old 02-19-2011, 09:42 PM
Drew_N's Avatar
Quoted: 13 Post(s)
I upgraded my Rega P1 with that cartridge and really like it. Install was fairly easy even though it was my first cartridge swap.
Drew_N is offline
Old 02-21-2011, 11:01 AM
chadnliz's Avatar
I have a AT150 I keep for a spare incase of emergency. Its really a pretty good cart offering about 80-85% of what my Dynavector 20L can do, but the Dyna is over twice as much. The 440 is a decent cart too, they both have a crisp lively sound that I like (Idont care for more rolled bacl carts like say the Benz carts sound.)
chadnliz is offline
Old 02-22-2011, 07:00 PM - Thread Starter
BuzzT1's Avatar
Man the Dynavector 20L look amazing but The price is $800 out of my range I'm ordering the Ortofon 2M Blue, hopping to hit the jackpot for the price and reviews.
BuzzT1 is offline
Old 02-22-2011, 08:51 PM
chadnliz's Avatar
I have a friend with a $2500 cart from Clear Audio I believe and yes its better than the Dyna but IMO $200 better if I had to put a number on it. The trouble is squeeking out that last bit gets real pricey.
chadnliz is offline
Old 02-23-2011, 06:26 AM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 316
I have been very pleased w/the 2m blue. Also after about 40-50hrs of break in it will really hit its stride.
What type of speakers are you matching up the cart with??
Class A is offline
Old 02-23-2011, 02:06 PM - Thread Starter
BuzzT1's Avatar
I have the Dali ikon 6 and REL T3 sub, Cary 308T cd player and Exposure 2010s2 Amp.
BuzzT1 is offline
Old 02-23-2011, 03:37 PM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 316
I heard the Exposure w/matching CD player hooked up to a pair of Spendors
a few months ago at the dealer I frequent. Nice smooth top end, good soundstage w/out any digital grain. Typical British very few bells & whistles,
all the money was spent for quality parts. On par w/the Naim philosophy. The
Ortofon should match up well with (as the British say) your kit.
Class A is offline
Old 02-24-2011, 10:40 AM - Thread Starter
BuzzT1's Avatar
Hii Caramba
BuzzT1 is offline
Old 02-24-2011, 06:55 PM
Jive Turkey's Avatar
Quoted: 216 Post(s)
Liked: 135
The Blue is a very nice cartridge with the right system. I have been very pleased with what $200 gets you with this one. I agree that it takes a number of hours to really settle in.
Think I'm going to try the Bronze on the next lap.
See ya. Dave
"High Fidelity audio has been like a dog chasing his tail. High Fidelity in my marriage has been much more rewarding because she knows where I sleep."
Jive Turkey is offline
Old 04-05-2011, 08:20 PM - Thread Starter
BuzzT1's Avatar
I got my Ortofon 2M Blue and it's unbelievable what a deferent in sound from my Ortofon OM 5 E, one of the best decision I ever made for my turntable, highly recommended.
Thanx to all for helping me to make this decision.
BuzzT1 is offline
Old 11-24-2012, 02:42 PM
Siddhant Johri's Avatar
Hi,
There are two versions of the Ortofon Blue
Ortofon 2M Blue and 2M Blue Verso
Which one would I need to buy for the Rega RP1?
Siddhant Johri is offline
Old 11-24-2012, 07:54 PM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 316
Class A is offline
Old 11-25-2012, 08:27 AM
thanks!
