Ground up, $2k 2-channel setup, emphasis on tubes and wood - recommendations ? - AVS Forum
post #1 of 13 Old 02-22-2011, 04:27 PM - Thread Starter
jbrooks's Avatar
I have a 12'6" x 11' reading room that currently has no sound in it.
I'd like to build an all-analog* 2:1 setup in this room, with headphones as an output option.
I'd like to emphasize tubes and wood in the components, as the visual/tactile aesthetics of these devices are at least as important as the sound, for me.
The components I have in mind are:
- 2 speakers and 1 woofer
- preamp
- amp
- turntable
- simple 24/192 DAC w/optical TOSLINK input to connect my sonos zp80 to
Is this possible on a $2k budget ?
Thanks very much.
* except for the sonos zp80 going into a DAC, going into the amp
jbrooks is offline
post #2 of 13 Old 02-22-2011, 05:41 PM
stevensctt's Avatar
Very possible, actually doable, if you buy used. Audiogon will be great source. I would suggest looking at an integrated tube amp to keep you on budget. Here is a good start.
stevensctt is offline
post #3 of 13 Old 02-22-2011, 06:02 PM
mcnarus's Avatar
Liked: 260
Sure. I'd suggest limiting myself to tubes in the preamp. Getting lots of clean power out of tubes is not cheap.
As for wood, I wouldn't put a high priority on that, myself, but if you want a certain look, I suggest you consider Axiom speakers. They offer a lot of custom options, so you can really get the look you want. And they're good sonically, as well.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #4 of 13 Old 02-22-2011, 07:31 PM - Thread Starter
jbrooks's Avatar
Thanks very much to all. When I said wood, I meant in the components themselves as well as the speakers.
When you speak of an integrated tube amp, you mean a single component that does the duty of both the amp and pre amp ?
jbrooks is offline
post #5 of 13 Old 02-22-2011, 08:53 PM
stevensctt's Avatar
Yes, a single component, both amp and preamp. Look around, there are several tube amps/preamps/integrateds that feature wood trim. Some of the trim is retrofitted.
post #6 of 13 Old 02-25-2011, 09:03 PM
cctvtech's Avatar
Something like this?
"Audiowood basic custom tables feature a quality Rega parts kit, and generally have an integral motor/drive system in a single plinth/base structure. These tables can be made to house your choice of tonearms, but are generally offered with Rega arms."
"Through a collaboration with Red Dragon Audio, Audiowood is proud to offer modified class D ICE-powered power amps that can be built into almost any type of enclosure. These great sounding amps are also incredibly efficient, delivering over 80% of consumed power to your speakers."
"In association with Decware, we are able to offer a remote-controlled version of their CSP2 preamplifier. Our version adds a remote Alps volume control to this quiet and full-bodied tube pre. In addition to 2 inputs and a headphone jack, it features adjustable gain to match it with almost any power amp."
http://www.audiowood.com/retail.html
Be seeing you!
cctvtech is offline
post #7 of 13 Old 02-26-2011, 01:55 PM
brubacca's Avatar
Don't think that it is possible for all that for $2k.
Check out Yarland Audio.
Yarland FV34C - 12W per channel Integrated Amp - $600
Emotiva XDA-1 DAC - $350
Rega RP1 Turntable- $450
Rega Phone Stage - $150
That leaves $450 for tube friendly speakers..
I'd say drop the subwoofer and add $500 to your budget. Then you are at about $950 for speakers. Should be VERY possible.
Good Luck
brubacca is offline
post #8 of 13 Old 02-26-2011, 02:05 PM
Eternal Velocity's Avatar
Liked: 48
For speakers that go well with tubes, I gotta recommend building a pair of these 95db efficient beasts:
http://www.troelsgravesen.dk/DTQWT_Tomas.htm
Eternal Velocity is offline
post #9 of 13 Old 02-27-2011, 04:45 PM
milaz001's Avatar
Peachtree Audio makes a hybrid integrated amplifier that combines a DAC, tubed preamp stage and solid-state amp stage, and it's available in two different wood finishes. That would get you your DAC, preamp and amp, and leave you about $800 for speakers.
We live in a society exquisitely dependent on science and technology, in which hardly anyone knows anything about science and technology.
milaz001 is offline
post #10 of 13 Old 02-28-2011, 11:39 AM
aquaphile's Avatar
+1
although that doesnt have the classic "tube gear" look to it
2.0 > 7.1
aquaphile is offline
post #11 of 13 Old 03-01-2011, 08:42 PM
stevensctt's Avatar
Found these wood panelled integrated tube amps at Sound and Vision. Also look at the preowned selections. A good start for keeping it under $2K.
post #12 of 13 Old 03-08-2011, 08:32 PM
stevensctt's Avatar
Can you stretch your budget a little?
MOTH AUDIO EMPIRE SPEAKER SYSTEM & Reps R-1 FULL RANGE
Only need an amp with 2W of power, so you can get some savings!
post #13 of 13 Old 03-08-2011, 11:25 PM
math-geek's Avatar
Sorry, wrong thead! Tubes and wood had me thinking of my girl!
math-geek is offline
Reply 2 Channel Audio
User Tag List
