very simple fix - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-15-2011, 09:21 AM - Thread Starter
mgpt6's Avatar
I thought I had a major problem with my tube amp. I was getting a crackling noise through my speakers Turns out, all it was that one of the power tubes was not seated correctly in its socket. Problem solved, sounds great. Hence, check tube seating every once in awhile
mgpt6 is offline
post #2 of 5 Old 03-15-2011, 11:09 AM
A9X-308's Avatar
Quoted: 823 Post(s)
Liked: 576
I've never had a tube move in it's socket on it's own yet.
A9X-308 is offline
post #3 of 5 Old 03-15-2011, 11:26 AM
Gizmologist's Avatar
Liked: 30
The pins on tubes and the socket contacts can oxidize over time and temperature variations along with humidity can degrade the pin to socket contact.
Simply removing the tube and reseating wipes the surface of the contacts and can re-establish a solid electrical contact. I would suggest that a non abrasive liquid contact cleaner be used on the socket and a light wiping of tube pins with a Scotchbrite pad will further enhance the contact quality and remove more accumulated oxidation.
Gizmologist is offline
post #4 of 5 Old 03-19-2011, 04:31 PM
poogie's Avatar
Quick questions since I just acquired Conrad-Johnson Classic pre-amp, do I need to worry about this one too? There are two miniature tube inside the chassis. Thanks.
poogie is offline
post #5 of 5 Old 03-19-2011, 04:42 PM
A9X-308's Avatar
Quoted: 823 Post(s)
Liked: 576
If it's working fine, leave it alone. If it plays up, then do what Giz suggested. Course black (sandpapery feeling) erasers work well at brightening up pins, as do scrotchbrite pads.
I'm not a fan of removing/replacing tubes more than is necessary as sockets loosen with repeated use, and most people remove the tubes incorrectly which can affect the integrity of the seal between the pins and the envelope. Flexing PCBs during insertion/extraction can lead to cracking if they are not supported correctly.
A9X-308 is offline
Reply 2-Channel Audio
taboola here
