A friend of mine is totally new to stereos and needs some help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-25-2011, 08:17 PM - Thread Starter
RoundWounds's Avatar
Hey guys,
I'm posting this for a friend of mine. He was an old, old receiver with an old turntable that's connected to a little set of bookshelf speakers and he wants to upgrade. He lives at home and wants a set up in his room, he wants this/looking at how much it's going to cost:
- An affordable receiver (one that can support 5.1 audio, and has inputs for a CD player, turntable and iPod)
- Complete 5.1 speaker set
He wants surround sound and wants optimal sound quality. Can you give some suggestions? Should he have surround sound in his room? If so, what do you reccomend? Should he just upgrade his current two channel audio? If so, what do you reccomend in that area? He said his budget is 800 dollars.
RoundWounds is offline
post #2 of 10 Old 03-26-2011, 12:18 AM
pistonengine's Avatar
800 bucks = 2.1 imho
pistonengine is offline
post #3 of 10 Old 03-26-2011, 01:20 AM
walbert's Avatar
He could re-cycle the existing speakers as surrounds, and purchase new speakers and build up to 5.1 from there; might even be content with the existing speakers as surrounds indefinitely.
No idea what your space requirements are, so have a look at bookshelf and tower speakers from Energy, Yamaha, Klipsch, Mirage, Polk, etc - when you find something that looks like it will fit; then build from there (doesn't mean you have to buy that product).
Receiver-wise, Pioneer's new VSX-521 looks nice, Sherwood's RD-7502 is my general stand-by for suggestions (it's really just quite versatile), would also look at Yamaha and Sony. You'll be hard pressed to find a phono pre-amp on an entry level unit, but you can probably add a preamp for not too much (unless the turntable has a preamp built-in).
walbert is offline
post #4 of 10 Old 03-26-2011, 01:25 AM
Why would you need a preamp if you have an avr?
post #5 of 10 Old 03-26-2011, 01:37 AM
walbert's Avatar
Many turntables cannot be connected to line-level inputs, you need a phono pre-amplifier to sit between the line-level input and the turntable. Newer turntables will integrate this, but older models do not. Your average AVR in 2011 has no idea what a phono input is, and probably doesn't even have a common-point ground; you want that little box to sit between it and the line-level inputs on said AVR, or the sound from your turntable will be crap due to the mismatch. Here's a much more in-depth article that explains what I just said in ~5 pages: http://en.wikipedia.org/wiki/RIAA_equalization
Now go back and re-read my post; I specifically said "phono pre-amp" - it's amazing what happens when you don't just pick jargon words out of the block and comment on them .
walbert is offline
post #6 of 10 Old 03-26-2011, 01:56 AM
Whoa, no need to get all defensive bro. I asked the question in honest ignorance and curiosity.
post #7 of 10 Old 03-26-2011, 02:05 AM
walbert's Avatar
Not defense, just being sarcastic .
No harm in questions; ask away.
walbert is offline
post #8 of 10 Old 03-28-2011, 12:48 PM
kgallerie's Avatar
Quoted: 43 Post(s)
Liked: 79
Might I also suggest Jamo speakers.....they typically have a very good bang for the buck.
There is a full 5.0 set at vanns for a decent price: http://www.vanns.com/shop/servlet/it...speaker-system
kgallerie is online now
post #9 of 10 Old 03-29-2011, 04:58 AM
walbert's Avatar
Sure why not, lets throw Athena in and we'll complete the Klipsch Audio Technologies tour .
walbert is offline
post #10 of 10 Old 04-05-2011, 09:09 PM
HelloCDClub's Avatar
The Onkyo home-theaters-in-a-box aren't bad at all.
HelloCDClub is offline
Reply 2-Channel Audio
