Asus Xonar Essence STX vs Cambridge Audio DacMagic - AVS Forum | Home Theater Discussions And Reviews
Old 07-09-2011, 05:49 PM - Thread Starter
airman23's Avatar
Hello all. I'm in a quandary regarding whether I should opt for a Asus Xonar Essence STX PCIx sound card for my PC or go with a Cambridge audio DacMagic DAC. The DacMagic is around $450 and the Xonar Essence STX is around $160. Besides being cheaper the Xonar Essence STX has some pretty good specs however the DacMagic has 2 imputs and upconverts everything to 192khz 24bit. I already have a Creative Lab SoundBlaster X-Fi Titanium Fatality Professional PCIx sound card in my machine but I want audiophile quality sound. The Asus Xonar Essence STX also has a headphone amp build in
Please let me know what your opinion is on this matter.
Thank You.
airman23 is offline
Old 07-10-2011, 09:18 PM
aazeez1975's Avatar
It is a true audiophile card. I am using it in my main system. Best part is if you decided to record vinyl you'll have a pretty good system. The snr on the card is great, and you can roll the op-amp to make it sound different.
I am using it with Jriver media center with asio drivers, you can also play with softsqueeze for amazing iOS functionality for just the price of the app
aazeez1975 is offline
Old 07-14-2011, 08:19 PM
WillyJ's Avatar
Quoted: 24 Post(s)
Liked: 84
Do either of you two gentlemen have any experience with this external sound card?
Creative Sound Blaster X-Fi HD Sound Card powered by THX TruStudio Pro
http://support.creative.com/kb/ShowA...tree=obj(26463)
I am looking at it because it has an SPDIF input that will allow me to rip some of my favorite vinyl albums to hard drive at 24 bits/96K. I will use the SPDIF output on the back of my pre/pro running to the sound card. I would then use a program like Audacity to do the heavy lifting. I don't use a desktop computer anymore so I have to use an external card and this was about the only one I found that had SPDIF input and was 24b/96k compatible.
I was wondering if you have an opinion on the sound quality and what kind of results I can expect. I have a pretty sophisticated home theater and audio setup so I want the best sound quality I can get - I really want the same sound OUT and I am get from listening to the vinyl.
Any help and/or suggestions including other product suggestions are appreciated!
WillyJ is offline
Old 07-14-2011, 10:08 PM - Thread Starter
airman23's Avatar
I have the Creative Labs Sound Blaster X-fi Titanium Professional Champion Series PCIx sound card with the external I/O Drive, which is ok for gaming which is is designed for. If your looking for a audiophile quality sound card you might want to look at these 2 http://us.store.creative.com/Creativ...B0041OUA38.htm and this one http://usa.asus.com/Multimedia/Audio...r_Essence_STX/
airman23 is offline
Old 07-15-2011, 01:19 AM
TinyAKtheater's Avatar
I have this sound card in my custom gaming rig and I love it. I run some Sennheiser 595s through it. I noticed a HUGE improvement in sound quality over anything I have used before.
I use this setup for games and music and I can honestly say it is a very good combination. I hear things in my music I never noticed before.
You can actually get the headphones off Amazon for $140. Best deal I can think of for quality headphones.
TinyAKtheater is offline
Old 07-15-2011, 08:46 AM
WillyJ's Avatar
Quoted: 24 Post(s)
Liked: 84
Thanks guys but I am limited to an EXTERNAL sound card or similar device because of the laptop issue......
I also found an M-Audio product which is about double the cost of the Creative product which may be better sound quality. Since I'll be new to ripping vinyl, I am just not sure what level of device I will need to get the best sound reproduction. Both are 24B/96K with similar Signal to Noise ratios but from what I have read about other Creative sound cards in the forums, I am wondering if the sound quality would be up to my liking. Anything from M-Audio is likely to be better than Creative especially since I don't need a 'sound card' per se.........Just need a way to get the digital signal into the computer and save it in WAV format. Probably can't go wrong with the M-Audio especially since it comes with a lite version of ProTools.
WillyJ is offline
Old 07-15-2011, 10:59 AM
Djoel's Avatar
Quoted: 543 Post(s)
Liked: 416
I was just wondering ( then the wondering it stop when I read your post) if these especially the Asus would fit a lap top, I guess not
Djoel
Djoel is offline
Old 07-15-2011, 11:23 AM
WillyJ's Avatar
Quoted: 24 Post(s)
Liked: 84
Djoel
The Creative is an external one - the one I noted in my first post - works via USB and it is a sound card.
The M-audio product I found that also works via USB is this one:
http://www.m-audio.com/products/en_us/FastTrackPro.html
I'm not sure it is classified as a sound card per se, but for my purposes I think it might work. I am probably going to order it from Amazon and try it out and post results when I get time.
I guess it depends on what you are looking for. In my case, I am trying to achieve the best possible sound quality when I rip some of my fav vinyl albums. Don't need a sound card since I don't need to actually PLAY them on my computer as I will be doing most of the playing on my dedicated home AV rig; But I do need a digital INPUT so that I can get it into the computer and manipulate, save and rip as required. There is a built-in sound card on the laptop but the quality is questionable and there is no digital input either.
I think the difference between mixing products and sound cards may be a bit blurry - if not to others then definitely to me.
WillyJ is offline
Old 07-15-2011, 11:48 AM
drewTT's Avatar
Quoted: 574 Post(s)
Liked: 601
Another +1 for the Asus STX. I have been very happy with it.
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is offline
