Many USB DACs limited to 96kHz - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 09-18-2011, 09:28 AM - Thread Starter
gimp's Avatar
Why is it that so many USB DACs only go up to 96kHz instead of 192kHz? For example I'm very interested in the Classé Audio CP-800 Stereo Preamp Processor but the USB input only supports up to 96kHz. My 192 collection is very limited, but having made the investment and considering the costs of a high-end DAC/Preamp I want the best. Is it a cost issue or some other technical issue?
gimp is offline
post #2 of 12 Old 09-18-2011, 09:48 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Many of DACs (mostly older ones) use USB 1.1. There is not enough throughput to reliably transfer bitstream for 192/24 stereo. Newer DACs use USB 2.0, but sometimes DSP used for processing is too slow too.
But if we talk about new designs, there is no technical reason do not support 192kHz streams.
ap1 is offline
post #3 of 12 Old 09-18-2011, 10:29 AM
weverb's Avatar
Some even only go up to 48kHz. Then they upsample to 192kHz. The popular DacMagic is like this.
Analog: Pioneer SX-950, CT-F9191, AD797MCPS, PL-707, RH-65, RG-1, SR-202, Monitor 10/HE-500 hp's
Digital: Laptop, M2tech Young, Oppo 83, Simaudio i5.3, Dali Mentor
weverb is offline
post #4 of 12 Old 09-18-2011, 01:58 PM - Thread Starter
gimp's Avatar
Thanks everyone.
gimp is offline
post #5 of 12 Old 09-18-2011, 10:19 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 91
buy a hiface they dont cost much
cookieattk is offline
post #6 of 12 Old 09-19-2011, 04:32 AM
firedog55's Avatar
1. As noted, much older less expensive USB hardware doesn't support hi-res.
2. There aren't native Windows drivers for resolutions above 96k on USB; so drivers have to either be written (expensive and difficult) or licensed (expensive).
As a result, most manufacturers have not felt the need to include a hi-res USB solution till recently. Only recently with the beginnings of a real market for hi-res music, and with new USB hardware designed for hi-res, are DACs starting to be made with this in mind.
firedog55 is offline
post #7 of 12 Old 09-25-2011, 11:16 AM
oneway23's Avatar
Would someone be kind enough to post an example of a currently available "Hi-Res" DAC that doesn't up-sample?
oneway23 is offline
post #8 of 12 Old 09-25-2011, 01:01 PM
MSmith83's Avatar
Quoted: 232 Post(s)
Liked: 191
The ASUS Xonar Essence One allows you to disable its DSP's up-sampling. This DAC is currently available outside of the US, but should be here soon enough. It also appears to handle sample rates over 96kHz via USB.
MSmith83 is offline
post #9 of 12 Old 09-25-2011, 01:31 PM
oneway23's Avatar
The product info does explicitly mention a different method of upsampling when compared to similar products, though I'm hoping that the section about the AISO driver indicates that you will be able to not only bypass Windows' processing, but also the DAC's own upsampling.
Anyway, i really appreciate the post, as I now have yet another item to keep an eye on!
oneway23 is offline
post #10 of 12 Old 09-25-2011, 03:51 PM
MSmith83's Avatar
Quoted: 232 Post(s)
Liked: 191
There is a button on the front to enable or disable up-sampling.
MSmith83 is offline
post #11 of 12 Old 09-25-2011, 08:10 PM
oneway23's Avatar
Just saw that in the pics...Thanks for the heads up..This piece looks like a winner.
oneway23 is offline
post #12 of 12 Old 09-26-2011, 10:52 PM
MSmith83's Avatar
Quoted: 232 Post(s)
Liked: 191
It does look very good spec-wise, and it should be reasonably priced.
The headphone output is driven by very high quality op-amps and buffers. One Burr-Brown 1795 DAC chip per channel and Alps volume potentiometers are certain to make tech heads happy.
MSmith83 is offline
Reply 2-Channel Audio
